Old August 20th, 2012, 12:26   #1
bhodgkiss
Default Common weight save items on tdi engines
HI guys
Not looking for expensive items like carbon bonnets and bucket seats.....
But cheap or free weight save off the front end of our tdi's
Any weight off the front end has to be good.
Items I have so far:
Engine cover remove 0.75kg
Egr valve delete 0.5kg
Air con remove (mine didn't work anyway) 20kg
Bonnet insulation remove 0.5kg
Battery in boot 18kg
washer bottle in boot 2kg
Decat pipe 2kg?
Ported head
Lightweight airbox heatshield 0.25kg
Things I thought might be good:
Smaller oil filter 0.5kg
Alloy cam cover. Do these exist? Surely they must? 0.3kg?
Alloy front uprights off audi a6 (for my PASSAT) 6kg lighter then steel
Alloy upper suspension mount plates " " 1kg
Sensible thoughts please!
I've probably done the biggest gains already but good to check I'm not missing anything obvious
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old August 20th, 2012, 12:33   #2
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
De-turbo must be a good weight save :P.
m1ketdi is offline   Reply With Quote
Old August 20th, 2012, 12:43   #3
Lex4TDI4Life
Lex4TDI4Life's Avatar
Rear seats weigh a ton. Ditch em.
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old August 20th, 2012, 12:55   #4
bhodgkiss
50kg is not to be sniffed at!
Looking at front weight save not rear!
Old August 20th, 2012, 12:56   #5
joseluis.17g
I've done almost all of what you have and I honestly didn't feel the difference until I drag race vs a friends tdi same year and everything.
You could also do a lightweight flywheel I don't think you'll mind the extra rattle and could save 10 pounds easy
07 Mexican MKIV PD AXR engine 40,000 miles, Malone Tune, vr6 clutch, eibach pro kit, Upgraded SMIC, VNT 17/22 trunk mounted battery, mufflerectomy..
joseluis.17g is offline   Reply With Quote
Old August 20th, 2012, 13:03   #6
bhodgkiss
With rear mods like no back box and no spare wheel etc its easily 70kg lighter than stock so call it 5% or 7HP plus the weight distribution and braking improvements. All good fun and looks stock which is what I want
Oh roof rails gone too for a cheeky 4kg high up save!
Old August 20th, 2012, 15:22   #7
joseluis.17g
Maybe ditch the front swaybar,
Engine undertray
Old August 20th, 2012, 15:50   #8
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
Rear battery....
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old August 21st, 2012, 03:26   #9
VWBeamer
Fuel Economy: 42.79 mpg Woot!
How do you fit a smaller oil filter? and how can it save .5 kg when the stock filter doesn't weigh that much?
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old August 21st, 2012, 04:09   #10
m1ketdi
TDI(s): Leon BKD
On the screw on type oil filters you can get shorter filters. Half the length of the filter saves some weight and you need less oil in your engine with less filter to fill...
Old August 21st, 2012, 04:40   #11
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Ditch the front sway bar, It will only be more fun to drive with out it!
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old August 21st, 2012, 04:45   #12
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
Braile has a battery it is small. Indeglobulewagon had a thread going some time back on weight saving. might do a search for that.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old August 21st, 2012, 05:12   #13
bhodgkiss
Thanks guys,
- Yes battery is already in the boot, I don't mind it being full size as I need more weight in the back.
- Rear sway bar will go on too to help reduce understeer and add weight in the back.
- Yes the oil fill can be less with a smaller filter
- Removing the front sway bar, is this a serious suggestion? surely the whole car becomes a rolling mess (albeit balanced) This can't be good??? Think I'd rather add a rear instead.
- Front undertray removal just allows the engine/ancilliaries to be covered in crap (salt etc) and reduces mpg as the undertray helps a lot with aerodynamics (and noise.)
Old August 21st, 2012, 05:49   #14
devonutopia
devonutopia's Avatar
Carbon bonnet is worth having seen how heavy the original bonnet is - in my case it was about 25kg VS 5kg....
Lighter flywheel helps. Not sure what a dual mass weighs - I am guessing about 30lb, maybe 35lb? My flywheel weighs 16lb, so thats in theory over 8kg saved just in the transmission.
You could remove the front crash bar?
Jason - Skoda Fabia TDI project
http://www.youtube.com/watch?v=TOE4nbT5NGY 315bhp dyno run video of my car.
http://www.youtube.com/watch?v=8R5c496IG1Q Skoda Fabia GTB2260vk in-car acceleration video!
http://www.devoncardetailing.gb.net/
devonutopia is offline   Reply With Quote
Old August 21st, 2012, 06:32   #15
joseluis.17g
Removing the front swaybar it is a serious suggestion.
I ran with the front disconnected, it balances the car, less understeer and the extra body roll is not that big
And about the front crash bar, well that seems a little bit to drastic for safety reasons but you could always drill some holes.
And if you end up with a light front maybe you could also ditch the power steering
Jettas with common rail engines jsiff210 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 8 March 17th, 2012 08:04
08 Common Rail engines plus other tasties! Scott_DeWitt Vendor & GroupBuy items for sale 3 January 8th, 2009 22:39
Anyone have part numbers for the common maint. items for our new cars? dhdenney VW MKV-A5 Golf/Jettas 11 April 19th, 2006 17:38
Part number of common maintenance items tongsli VW MKIV-A4 TDIs (VE and PD) 22 May 3rd, 2005 11:23
How do you save energy (and save precious resource RCmodeler General VW Discussion 27 January 4th, 2004 16:21
Page generated in 0.19204 seconds with 10 queries
[Output: 128.93 Kb. compressed to 107.36 Kb. by saving 21.57 Kb. (16.73%)]
