Sand Bag
- Joined
- Jul 24, 2009
- Location
- Michigan, USA
- TDI
- '06 Silver Jetta TDI manual & '11 Audi Q7 S-Line V6 TDI
I have an interesting situation. I've done some searching but can't seem to find any posts that are exactly the same occurrence as mine.
On my way into work this morning and about 1/3 of the way through my normal commute (45miles one way) my car just stops running. Beings it's a manual I simply tried to start it again while coasting. I get nothing, and there are no indicator lights illuminated on the dash. So I signal to pull over. My exterior turn signals work, but nothing on the dash or normal clicking noise from the turn indicator flashing. After I come to a stop I try a couple more times to restart the car. No success, however my DRL’s are working (and that is indicated on the dash) along with the interior lights. So I pop the hood get out and do a quick engine compartment inspection, & check the battery. There is nothing out of place or suspicious. So I hop back in, still nothing. I do a double check under the hood. Get back in, fires right up, just like normal. However to my surprise there is no CEL or MIL light indicated at all. Instead of going to work I head back home. I encounter the same quit and start procedure one more time before I get home. It seems you have to give the car 5 minutes to reset itself before it will entertain starting again.
Now I do have an air bag MIL on and had the car scanned about 2 weeks ago and found out the following code:
Address 15:
Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000
Serial number: 003B6D075UE3
Coding: 0013889
Shop #: WSC 00066 000 00000 VCID: 6CDC23F04F90D69
1 Fault Found:01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - Intermittent - MIL ON
That though should have nothing to do with the car shutting down like it is. Any suggestions or info would be of great help!
Address 15:
Revision: 05034000
Coding: 0013889
