Old August 13th, 2012, 08:35   #1
1Bad87gn
TDI(s): 1998 Jetta
Default 98 Jetta hard starting when cold
I have a 98 Jetta with 248,000 miles on it. Whenever it's moderately cold out it is hard to start, and the colder it is the harder it is to start even when I have cycled the glow plugs 4-6 times. It started just fine until I had the injection pump replaced. I have replaced the following parts:
Timing belt and associated parts, glow plugs and harness, glow plug relay, injector nozzles (Bozio nozzles). The only way it will start easily is plugging the block heater. I keep up on the maintenance religiously so I can't figure out why this problem continues to plauge me. Any help would be greatly appreciated.
Mike
1Bad87gn is offline   Reply With Quote
Old August 13th, 2012, 08:47   #2
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
Mike
check your static timing with vag com, it may be off
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old August 13th, 2012, 09:05   #3
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Agreed! I would bet it's retarded.
How long ago was the belt and pump changed?
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old August 13th, 2012, 10:24   #4
1Bad87gn
TDI(s): 1998 Jetta
Thanks for the help, I took it to a shop today and I let the shop owner know what you'all said, and he also agrees.
Thanks for the help.
Old August 16th, 2012, 10:45   #5
GPS Tech
TDI(s): 1998 Jetta
I just ran a post a couple of weeks ago about replacing my injection pump and then the car would not start if cold. I had to disconnect the temp control sensor to start the car if it sat for a more than 4 hours. after much trouble shooting My solution was to replace the pump again.
GPS Tech is offline   Reply With Quote
Old August 16th, 2012, 10:47   #6
GPS Tech
TDI(s): 1998 Jetta
I am not suggesting you change the pump, just letting you know my outcome.
Old August 16th, 2012, 11:50   #7
TonyJetta
gps_tech,
Did you ever check the timing, before replacing the pump?
Tony
98 Jetta TDI Problems Solved Smoking Hard Starting Danny W VW MKIII-A3/B4 TDIs 4 February 26th, 2011 00:38
Hard "cold" actually cool Starting - 2006 Jetta TDI 5 spd jsb VW MKV-A5 Golf/Jettas 2 January 5th, 2011 18:37
Hard starting cold 99 jetta stillcrazyinlaw VW MKIII-A3/B4 TDIs 1 November 16th, 2010 20:19
98 Jetta TDI hard to shift when cold tdi_torgs VW MKIII-A3/B4 TDIs 7 June 8th, 2006 12:42
Hard Starting when Cold, etc. JackSoot VW MKIV-A4 TDIs (VE and PD) 15 November 4th, 2002 20:06
Page generated in 0.08180 seconds with 10 queries
[Output: 80.40 Kb. compressed to 70.04 Kb. by saving 10.37 Kb. (12.90%)]
