Thanks for the kind words. I'm a car designer at Kia motors. I work at a state of the art design center in Irvine CA. In some ways, this project is my personal "showcar" as I believe america needs a timeless, efficient, 4-seater vehicle. A 2002 that gets 50+ mpg fits the bill.....now convincing the company to design and build it is another matter.Such a fantastic build, can't wait to see more. Good fab skills too, what do you do that provides you with access to the proper tools and nice table?
Next time you're talking to the CEO.. we could use a nice 40 mpg diesel van as wellThanks for the kind words. I'm a car designer at Kia motors. I work at a state of the art design center in Irvine CA. In some ways, this project is my personal "showcar" as I believe america needs a timeless, efficient, 4-seater vehicle. A 2002 that gets 50+ mpg fits the bill.....now convincing the company to design and build it is another matter.
That would explain it, and pretty cool to see the company allowing some tinkering of other brands within their workspace.Thanks for the kind words. I'm a car designer at Kia motors. I work at a state of the art design center in Irvine CA. In some ways, this project is my personal "showcar" as I believe america needs a timeless, efficient, 4-seater vehicle. A 2002 that gets 50+ mpg fits the bill.....now convincing the company to design and build it is another matter.
No, not a TII. Just an original 1975 socal 2002. TII's should probably stay as TII's.Is your 2002 a Tii?
Nice job. Would love to see it in person!
df
Thanks for the kind words and YES I want to mod it. But the plan is to get it running first and work out the bugs. Modifications in the future will not be too extreme...vnt17, DLC 1019 nozzles, ECU tune, already have the 11mm pump, possibly a bigger intercooler but that will require hacking up the radiator support. I'd be happy in the ballpark of 150hp/250tq....but i'd be happier if my mileage is 50 mpg+.This build is amazing. Coupled with the light weight and RWD, this build would be amazing with a built ALH. Any plans for big turbo/injectors/pump?
Probably about 1-2 inches. The limiting factor being the bellhousing also lowering with the engine and interfering with the center track rod. Also, going lower might would not work with my motor mount design.Hey mate luv the build, how much lower do you think you could have mounted the engine if you had used a dry sump setup?
Cheers
Probably not anytime soon.....So when should we expect to see some numbers?
That's exactly how I approach it. I label every last plug. I then create a list of what I want and don't want. Then I unwrap the entire harness to expose all the wires/junctions/splices. Then you just pick a plug that you don't want and do as greengeeker said.The very basic method for trimming down your harness is to identify EVERY connector in the harness. Start with your lighting connectors and follow them up stream until you run into a splice (VW loves splices) and clip the wire going to that connector. Repeat with all the wires in the connector until the connector can uncerimoniously chucked over your shoulder. Swig of beer. Repeat on more connectors that you KNOW you won't need again. Eventually you will find the last wire that goes to that splice (you've already clipped 2 other wires at the splice for instace) so now follow the wire up stream where it will usually end up at the fuse panel or a ground. This will help you trim down the harness to circuits that are necessary for engine operation. jimbote and I are working on a how-to to help with the rest of those.
That's what friends are for. To bring the beer and laugh at your situation. At least mine seem to think so.Don't forget the beer.
