Old August 2nd, 2012, 09:00   #16
curtis75
TDI(s): none, yet
Originally Posted by greengeeker View Post
Sorry Curtis, I'm not selling prints.
No problem, I actually looked into it more, and my bellhousing is different so it won't work for me anyway.
curtis75 is offline   Reply With Quote
Old August 2nd, 2012, 09:03   #17
JFettig
JFettig's Avatar
Remote oil filter setup coming later?
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old August 2nd, 2012, 09:55   #18
Vince Waldon
Vince Waldon's Avatar
Originally Posted by oilhammer View Post
But if you do successfully make an adapter to mate the ALH to the Ford 2.0/2.3/2.5L "Pinto" engined Mazda R5 gearbox, let me know and I'll buy a second one from you.
If for the 4.0l SOHC Ford/Mazda I'll buy one... would drive my Mazda B4000 everywhere if only it got even close to the fuel economy my two TDI Jetta's do.
The truck takes me 350 km (220 miles) on a 70l (18.5 US gallons) tank of gas... if I'm lucky. Gas that's 10 cents a liter more expensive than diesel.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old August 2nd, 2012, 10:18   #19
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yep, the Cologne V6 is a bit of a pump-sucker. I had one.
oilhammer
www.cardocautomotive.com
Old August 2nd, 2012, 10:19   #20
Alchemist
TDI(s): '04 Golf
I am about to start a Ranger conversion from 4L V6, so if the plate will work put me on the list. I also think I have found a way to make the Ford Cruise switches work with a VW ECU. More on that later if there is any interest.
Paul
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old August 2nd, 2012, 11:25   #21
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
As far as making adapters for the other bellhousing patterns I am entertaining the idea. For the time being I'm going to stick to the manuals. One could always purchase a used transmission out of lima motor Ranger to use in any v6 or duratec Rangers. They are so plentiful in the bone yards they go for $200-300. This was actually part of my development process - I bought three trannys to get four separate outputs from the CMM. That way I'm not left with a one-off bolt pattern that fits perfectly for one transmission ( the one measured) and fits like crap for the rest.
Paul, yes I am interested in how you plan to do this. I have my own way but I'm sure yours will be better. I'm still trying to understand the components in the CEL circuit you designed for Jimmy.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old August 2nd, 2012, 11:42   #22
Alchemist
TDI(s): '04 Golf
Does anybody know if the 4 cyl has a different bell housing than the V6? Mine has a 5 Sp manual, but I don't know what the bell housing is like yet. First I need to get a safety inspection, then the fun begins.
Paul
Old August 2nd, 2012, 12:19   #23
oilhammer
oilhammer's Avatar
The Rangers only over got the Cologne V6 or the Vulcan V6, no Duratec. I am not sure of the different bellhousing patterns, but I am thinking they are all different, because the 4cyl has backwards mounting bolts on each side of the crankcase, which would be impossible on any V6 engine.
oilhammer
Old August 2nd, 2012, 14:01   #24
Lone Ranger
TDI(s): TDI Ranger
Well I have an adpter plate and motor mounts already made for this. Msg me for pics if you need photographic proof.
ps. my 2nd tdi ranger is almost done. See my other threads to see it and what happened to it
Lone Ranger is offline   Reply With Quote
Old August 2nd, 2012, 14:44   #25
greengeeker
Paul
The v6 is most definitely different. I need to go back through my notes but I believe the old 2.8 and 4.0L (not sure if both OHV or SOHC) have the same pattern and the 3.0L is again something different.
I was refering to the 2.3L Duratec.
- Nick -
Old August 2nd, 2012, 14:46   #26
greengeeker
I've been following your swap since you first posted and was pretty disappointed (as I'm sure you were) of how that ended up. I look forward to seeing your next truck.
- Nick -
Old August 2nd, 2012, 14:50   #27
jimbote
jimbote's Avatar
I'll post up some pictures of the completed CEL gizmo on "the alchemist's CEL functionality fix thread" .... made an extra "just in case" I fried the first one
Old August 2nd, 2012, 14:52   #28
greengeeker
Sweet. thank you.
- Nick -
Old August 2nd, 2012, 23:05   #29
greengeeker
Default Out comes the motor
Nothing earth shattering here just the obligatory swap pictures of removing the old drivetrain. I was disappointed I couldn't remove the engine and tranny together. My load distribution bar only allowed so much of an angle so maybe it would work but I just found it easier to separate them and pull them out separately.
Time to remove the VW drivetrain: 30min (I will admit drivetrain removal is made easier when the radiator/header panel is sitting in the back seat when you start)
Time to remove Ranger drivetrain: 3 hours
- Nick -
Old August 3rd, 2012, 08:59   #30
Freestyle72
Keep up the good work. Any reason you are opposed to doing a drawing/print of an adaptor plate?
Freestyle72 is offline   Reply With Quote
Tdi Ranger Lone Ranger TDI Conversions 137 May 1st, 2018 21:53
TDI to Ford Ranger Swap. JarHead TDI Conversions 9 April 4th, 2012 08:55
Ford Ranger TDI wanted bfloyd4445 TDI Cars for Sale/Wanted 6 December 29th, 2010 19:48
ranger tdi- what do you guys think? terry_01vw TDI Conversions 5 March 29th, 2007 17:37
TDI into Ford Ranger ? ? Brett77 TDI Conversions 6 March 15th, 2007 06:32
Page generated in 0.18889 seconds with 10 queries
[Output: 138.87 Kb. compressed to 116.31 Kb. by saving 22.56 Kb. (16.25%)]
