Old August 1st, 2012, 19:56   #1
AppleTechTN
TDI(s): 2010 Jetta
Default Help with VCDS codes
Any help identifying this would be most appreciated! It seems to be recurring pretty often: "Fault Frequency: 60"
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
Shop #: WSC 00066 000 00187
ASAM Dataset: EV_Climatic A01001
ROD: EV_Climatic_VW36.rod
VCID: 3851F2EA8348AA9
1 Fault Found:
13701888 - Function Restriction due to Received Malfunction Value
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 60
Reset counter: 172
Mileage: 118145 km
Date: 2030.14.14
Time: 15:48:56
2010 Jetta TDI
1996 Toyota Land Cruiser
1993 Ford F-150
AppleTechTN is offline   Reply With Quote
09 Jetta, VCDS, codes........oh my EJS VW MKV-A5 Golf/Jettas 30 August 21st, 2012 08:23
need help with VCDS codes dsmith6598 VW MKV-A5 Golf/Jettas 20 September 25th, 2011 11:26
AC VCDS codes Rob71zilla TDI 101 9 June 21st, 2011 05:32
Readiness codes in VCDS Measuring Block Group 17 volmaniac OBD Scanners 4 September 30th, 2009 11:17
ABS Light ON But VCDS Shows No Fault Codes mike VW MKIV-A4 TDIs (VE and PD) 7 July 23rd, 2009 09:19
Page generated in 0.11092 seconds with 10 queries
[Output: 47.43 Kb. compressed to 44.48 Kb. by saving 2.95 Kb. (6.22%)]
