Old July 29th, 2012, 16:31   #1
wal1809
Fuel Economy: 45 mpg in both tdi's
Default Need help car not starting
2006 Jetta 1.9 tdi
I went to trouble shoot the car as my wife told me the driver door locks, trunk opener and fuel door flap were not working. I checked all the fuses and that was ot the problem. I did search on here and found the problem was broekn wires in the door boot. Sure enough that was it. I took the panels off and fixed the wires. That problem is fixed.
Now the car will not start. OBD2 scanner shows P0600 code. I did a search on that code and found another guy had trouble after pulling fuses as well.
The battery is new but I checked it and it is good to go.
Any and all help is appreciated.
Oh by not start I mean everything turns on but it will not turn over. It makes no sound when the key is turned to start.
wal1809 is offline   Reply With Quote
Old July 29th, 2012, 16:47   #2
whitedog
OK, so it doesn't start. What does it do when you turn the key to start?
Old July 29th, 2012, 16:53   #3
wal1809
Sorry I was editing when you were asking. It does nothing. The dashlights light up, the dinger sounds off but nothing from the starter. Just like the key has been turned to a dead zone.
Old July 29th, 2012, 17:31   #4
whitedog
2006 Jetta 1.9 tdi
You need to find out if you are getting power to the signal wire on the starter solenoid.
If you are, jump power to the terminal from the battery (be sure the transmission is in neutral). If it doesn't start, your starter is toast. If it does, you have trouble between the key and the starter.
Old July 29th, 2012, 17:47   #5
wal1809
With the key turned on or off I can not put it in neutral. The shifter will not come out of park. The steering wheel unlocks but the shifter will not.
The check engine light does illuminate when the key is turned.
Old July 29th, 2012, 17:48   #6
wal1809
I checked every fuse under the hood and the dash. All good.
Old July 29th, 2012, 18:43   #7
whitedog
I don't know this system very well, but it sounds like something in the Neutral switch circuit, possibly. I'll try to look into the wiring and see what I find.
Old July 29th, 2012, 18:59   #8
whitedog
Here it is:
You will need to go in and start finding where you are missing voltage.
Old July 29th, 2012, 19:33   #9
wal1809
Man I sure thank you fellas. I have to walk away from it right now. I ave been working on this since 10 am. I will get back at it tomorrow. Thank you again for trying to help.
Old July 29th, 2012, 19:36   #10
whitedog
Please let us know what you find and how you found it. This is the first no start on an 06 that I recall and I would like to know more. According to the wiring diagram, the signals all go through controllers, so I don't know what all is involved in the logic circuits on this system, but I hope to learn.
Old July 29th, 2012, 20:02   #11
wal1809
I promise you I will report back. I owe this forum that at the very least. I can't help but think it has something to with pulling fuses. Or something to do with me starting the car with the OBD still hooked up. I didnt see it and then noticed it. After I shut it off again was the last time it started.
Old July 30th, 2012, 14:14   #12
wal1809
Had a wrecker come get it and it is headed fo V-Dubs in Houston. He seems highly regarded by others on this forum. I will report back.
Old July 31st, 2012, 09:46   #13
wal1809
Ok well the car is fixed. It was never broken in the first place. I have to show my hiney for all to see. I put one 30 amp fuse in the wrong slot. It controls the transmission. The car recognized nothing was in the slot and would not allow the start. I can't believe I did it but apparently I did. My stepson and I went back through the book before it went to the shop and checked all the fuses for the right slot. The probelm is the book doesn't cover all the fuses.
Old July 31st, 2012, 11:13   #14
whitedog
I knew that too and thought about mentioning that the fuse locations you find aren't always correct. I failed to say anything though, so that part is my bad.
Glad that all is well now.
Old July 31st, 2012, 17:27   #15
wal1809
I remember getting confused on one 15 amp fuse as there were two empty slots after I took it out. I tried it in both and of course nothing. I never suspected the 30 amp. I am going to take a picture of the fuses in place and just file it somewhere. Thank you guys for trying. Thank God it wasn't a huge deal.
Car not starting..... konkapot TDI 101 15 July 9th, 2009 12:07
car not starting, any help out there please? shufti VW MKIII-A3/B4 TDIs 15 August 9th, 2007 18:59
HELP-Car stalls after first starting jimoilrell VW B5 Passat TDIs 7 May 29th, 2007 16:14
Car not starting....HELP!!! tverhoeven VW MKIII-A3/B4 TDIs 30 May 19th, 2006 14:10
Trouble starting car aherold VW MKIV-A4 TDIs (VE and PD) 24 September 1st, 2003 21:15
Page generated in 0.16766 seconds with 10 queries
[Output: 120.25 Kb. compressed to 99.62 Kb. by saving 20.63 Kb. (17.15%)]
