Old July 25th, 2012, 18:38   #1
Deadend
TDI(s): 2001 Jetta
Fuel Economy: 40 mpg :S
Default ABS Pump Bleeding with Vag-Com
So it looks like I need to get ahold of a vag-com and bleed the abs pump after having the reservoir run dry during bleeding (don't ask...).
Evidently, the software will instruct me to open the *front* bleeder screws on demand. Problem is... they're siezed, one is even broken . I know I know, I should (pardon the pun) screw around with them and try to get them open, but my priority is just getting the car back on the road right now.
So I'm wondering if anybody knows enough about the ABS pump to tell me if opening the back ones will work for the procedure. The (supposed) air bubble in the abs pump is currently preventing the rear right caliper from operating (or receiving any hydraulic pressure), so it makes sense that whatever air may be in there would be in a circuit connected to that line alone.
But hey, I'm kind of an internet hobbiest at best when it comes to this stuff. So if anyone can enlighten me as to if this plan is a horrible, horrible idea (opening the back bleeders when the computer tells me to open the front ones), I'm all ears .
Deadend is offline   Reply With Quote
Old July 25th, 2012, 19:41   #2
Curious Chris
Fuel Economy: 47/42/38
VagCom now known as VCDS due to copyright issues does a lot more than tell you to open bleeders. It runs the the pump, tells you to pump the brakes, yeah yeah open these bleeders.
You cannot bleed the ABS pump without VCDS.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old July 25th, 2012, 19:44   #3
Deadend
TDI(s): 2001 Jetta
Oh I know it does everything. My question here is that when it says "Open front bleeders", and I open the back bleeders instead; is that going to mess up my ABS pump or anything, or will that work just as well to bleed the ABS pump?
Old July 25th, 2012, 21:18   #4
RacerTodd
RacerTodd's Avatar
Fuel Economy: about 50
I'm gonna say that you have to open the front bleeders. When doing the ABS bleeding procedure, the pump runs and pumps fluid (& air) out to the front brakes. Opening the rear bleeders won't do any good, since the pump isn't pumping fluid to the rears.
Todd
Seattle,WA
'86 GTI, Red of course. (exciting racey car) 274,000 miles
'01 Golf TDI, silver. (new work car) 558,000 miles!
'87 Golf, Polar Silver. (retired work car) 654,000 miles <- Gone to a new home
RacerTodd is offline   Reply With Quote
Old July 25th, 2012, 22:54   #5
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Vcds basically walks you through the process of bleeding each circuit at a time. If you know the right rear circuit has the air then you can just hit next/done until you get to that circuit. I would be a little nervous about not bleeding every circuit though
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old July 6th, 2013, 07:16   #6
pcjr
Fuel Economy: 42/38/33
Procedure for Bleeding the ABS Brake Pump in many older VW Golf, GTI, Jetta, and Audi TT with Mk20 or Mk60:
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 001 (may be group 002 in Mk3 VW Golf/Jetta)
[Go!]
This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.
Click the [Done, Go Back] button and you're all set.
pcjr is offline   Reply With Quote
How to bleed ABS pump through Vag.com? MAXRPM TDI 101 17 December 28th, 2010 16:45
ABS Light After Brake Job, VAG-COM: Hydraulic Pump Implausible Signal Intermittent FirstOrbit84 TDI 101 10 March 23rd, 2009 07:08
ABS pump bleeding question RacerTodd TDI 101 4 November 23rd, 2008 06:03
abs pump bleeding doc_m VW MKIV-A4 TDIs (VE and PD) 7 March 9th, 2008 10:29
Bleeding ABS System, is there a How To ? ninedee_golf_tdi VW MKIII-A3/B4 TDIs 4 January 25th, 2007 14:35
Page generated in 0.13376 seconds with 10 queries
[Output: 75.26 Kb. compressed to 66.13 Kb. by saving 9.14 Kb. (12.14%)]
