Old July 21st, 2012, 06:46   #1
Clarko
Default 2006 Jetta TDI A/C condenser fan not running
My a/c stopped cooling at idle or low speed. I took car to loacal not vw mechanic. He said cooling fan needs to be replaced. Said one of the two fans was not running. They found a blown fuse and replaced that but then the fan would not turn off. I'm not sold that it's the fan problem. Seems if that were the case then when the fuse was replaced it would have blown again without the fan starting to run. I think it might be some type of sensor problem. Can anyone help here?
Clarko is offline   Reply With Quote
Old July 23rd, 2012, 12:57   #2
Powder Hound
Powder Hound's Avatar
If the fan runs when connected directly to 12 volts, then it is possibly the fan control module. But usually, if the a/c is on, and one fan runs while the other does not, then the other fan needs replacement.
There is also the open the fan motor and see if it is repairable, as some of them are. Your choice.
Old July 28th, 2012, 11:42   #3
Franko6
Default Fuses can be a problem...
The fan control module is built into the big fan... if your small fan is non-operational, it needs either the brushes fixed, the bearings oiled, or the fan replaced.
The little one is a bit of a problem to diagnose. The whole fan support needs to be removed. Run a jumper wire to the leads on the small fan. If it does not run, either the brushes are sticking or the bearings are fried. If the brush support is not totally melted (why they make them out of plastic is beyond me...), then you can use graphite and a bit of whittling with a knife to fix the brushes until the slide freely. Otherwise, replace the fan.
The fuse panels under the hood and in the left side of the dash by the driver's door are both problems. Corrosion and burnt out connectors. Spray something like WD-40 or CRC over the panel and check each fuse connection for arcing, burnt spots or corrosion. The 40amp fuse that is in the front passenger side of the power fuse block is very prone to melting. Resistance from the spade in the fuse box will heat the fuse until it melts the fusible link.
Other than that, there are several other things that will kill the a/c. It's a very detailed study.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old June 5th, 2016, 15:58   #4
The_Wood
Reviving an old thread here - have been searching for some replacement fans for my 06 Jetta, and I've been informed that the GLI fans will fit. I found a set from a 2007 GTI - does anyone know if the fans are the same and/or will fit? Waiting to get part numbers back from the seller. Any feedback or guidance is much appreciated!
Current Stable:
-2014 Jetta TDI - Malone Stage 1, MK7 Austin Wheels, DG SSK
-2006 GTB1749V, PD150 injectors, Darkside RP, MP, Koni, Eibach, MK6 GLI Wheels
-2015 f80 AB/SO M3
-2013 e92 AW/FR M3
The_Wood is offline   Reply With Quote
Old June 18th, 2017, 22:51   #5
Lba2
Hi,I have same problem, did you solved it
Lab2
Lba2 is offline   Reply With Quote
Old June 19th, 2017, 12:15   #6
tadawson
No fan giving no cooling when standing is a solid diagnosis. Hard to speculate on the why without seeing it.
tadawson is offline   Reply With Quote
Old June 22nd, 2017, 17:31   #7
SpeedKing
Fuel Economy: 42-49 mpg
My a/c fan hasn't worked since I got my 2002 Jetta TDI last summer. Car would still stay cool . The other fan would come on after parking. Decided to install Fan Control Module. Got one on e-bay $14.80, 1yr warranty , made in USA. Now neither fan works and lost A/C. A friend told me he has bad luck with US made electrical parts. SO, do I try the $98 FCM from WorldPac or try switching out the Thermo-sensor? in the radiator ? Thanks for any and all help
SpeedKing is offline   Reply With Quote
A/C Condenser Fan Replacement jables VW B5 Passat TDIs 3 July 2nd, 2012 15:59
2010 Jetta TDI - Radiator Fan running NovaScotian TDI 101 1 December 14th, 2010 15:11
Rad fan stays running on Jetta TDI gerpeters VW MKV-A5 Golf/Jettas 4 July 5th, 2009 20:38
WTB 96 Passat TDI condenser/Rad. fan dieselherb Private TDI Items for Sale/Wanted 0 November 23rd, 2007 20:27
Condenser fan question Mrs Roundhouse VW MKIV-A4 TDIs (VE and PD) 0 August 5th, 2007 12:45
Page generated in 0.12693 seconds with 10 queries
[Output: 79.64 Kb. compressed to 69.12 Kb. by saving 10.51 Kb. (13.20%)]
