Old July 21st, 2012, 13:14   #16
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
isn't it an oxidation cat, IBW?
DPM is offline   Reply With Quote
Old July 21st, 2012, 13:23   #17
Don't think so. Only a screen.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old July 21st, 2012, 16:52   #18
Seatman
Seatman's Avatar
Fuel Economy: No idea
Originally Posted by Niner View Post
You still have a catalytic converter on your tdi, that you are destroying with 2 stroke motor oil.
No, you're presuming I have a cat on my car, I destroyed that with a metal bar and a big hammer
Anyway fired the car up from cold and the engine is a lot quieter.
Seatman is offline   Reply With Quote
Old July 21st, 2012, 16:55   #19
Scratcher
Scratcher's Avatar
How do you get that through its MOT?
2011 VW Sportwagen TDI
1984 Ford F250 6.9 IDI (Diesel)
2012 Subaru Outback Premium 6sp MT
Scratcher is offline   Reply With Quote
Old July 21st, 2012, 17:03   #20
Seatman
Seatman's Avatar
Don't have that problem over here
Old July 21st, 2012, 17:45   #21
Scratcher
Scratcher's Avatar
No MOT in Scotland?
Old July 21st, 2012, 18:09   #22
Seatman
Seatman's Avatar
Yeh but my car's emissions aren't that important due to it's age. It's the newer ones that need have their cats and dpf's etc.
I also fine tune things though so as not to smoke like a tyre on fire. Even with my bigger nozzles i don't get loads of smoke if any.
A lot of the newer cars get really cheap road tax based on the emissions but not me, I pay full price.
Old July 21st, 2012, 19:09   #23
Scratcher
Scratcher's Avatar
Yeah I paid through the nose too when I lived there and ran my Ford Escort 1.8D van.
Old July 22nd, 2012, 01:56   #24
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Hm Seatman, check out post #5 here:
http://powerstrokenation.com/forums/...d.php?t=110205
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old July 22nd, 2012, 07:26   #25
Scratcher
Scratcher's Avatar
I've given some thought to precombustion deposits from adding oil/2 stroke. My conclusion is that 2 stroke at least is designed as a precombustion lubricant since it is normally mixed with petrol/gasoline, If it was going to stick I think it would stick a carburettor before it would stick a high pressure diesel fuel injector.
Old July 22nd, 2012, 09:46   #26
Abacus
That helpful B4 guy
Abacus's Avatar
I did this for a long time at HermTDI's recommendation. Its major benefit is to lubricate and quiet the rotary pump. I think it's a good idea. He cautioned me to be sure to use ashless oil to make sure it doesn't harm the CAT (such as it is).
I have been doing this for many years, and hundreds of thousands of miles on this engine, also at Herm's recommendation.
I still have the original cat and the original injection pump, although I did reseal the QA seal at around 386K. Even with the original cat, my B4 moves very well down the road, as anyone who has driven it can attest.
Here are some pictures of when I took the head off it at 393K to replace a blown head gasket (due to a failed water pump) and of the IP at 386K. There was no wear lip at the top of the cylinder and you could still read the original writing on the pistons.
I'm a believer and add 14 oz of 2-cycle oil (Wal-Mart asheless TC-W3) and 7 oz of either Power Service gray or white bottle (depending on the time of year) at every fillup (I have a 21 oz bottle and mix if before fueling), which is usually 16-18 gallons. I do this will all the B4's we have and they run great.
Click on pictures to enlarge:
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old July 22nd, 2012, 09:59   #27
Honeydew
Like Abacus I run 2-stroke mixed with power service, about 3:1. Both our diesels get the additive.
Honeydew is offline   Reply With Quote
Old July 22nd, 2012, 11:51   #28
Herm TDI
Herm TDI's Avatar
The ashless 2-cycle oil is (in my opinion) an effective lubrisity additive.
The often over looked issue is lower aromatics (ULSD) thus affecting seal performance (shrinkage).
The wear Scar lubrisity test is a valid scale to measure different products in relation to lubricity. None of the products listed address aromatics and that is where adding an actual OIL to the fuel helps with improved aromatics.
Adding the 2-cycle oil will improve the aromatic content of your fuel. This is one of the reasons to use 2-cycle oil at every fill up.
Lubricate your pump and engine top end and it also helps to keep seals and fuel lines from shringage and becoming brittle (leaking).
I run ashless 2-cycle oil in every diesel I've owned...even my generator is diesel.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old July 22nd, 2012, 12:09   #29
Herm TDI
Herm TDI's Avatar
2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
CREDITS:
This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
HermTDI@Yahoo.com
Old July 22nd, 2012, 12:25   #30
ncroadwarrior
ncroadwarrior's Avatar
TDI(s): 04 JSW bew
I've been running this mixture in my powerstroke for the last 4 yrs...
1 oz marine ashless syn 2 cycle oil (walmart tc-3)
4 oz powerservice
have it mixed up in old stanadyne 12 oz plastic bottles....add one b/4 filling up
no issues...
I may start in my JSW but for right now I run powerservice and a qt of B-80 in a mixture...
04 jetta wagon, BEW, 09A
RC2, F06 Stg 2 cam,17 turbo, E-codes, Koni's, TT LCA's,
Skid Plate, tint, cat/vent/muffler/intake B'fly'd..frostheater..cat 2micron FF.
ncroadwarrior is offline   Reply With Quote
Two stroke with diesel....??? Milord VW MKIV-A4 TDIs (VE and PD) 14 December 31st, 2013 13:32
Suggestion on 2-stroke oil in diesel for a 2003 Jetta TDI? Kim Kerns Fuels & Lubricants 12 December 26th, 2007 17:05
2 stroke oil in your diesel? boulevard VW MKIII-A3/B4 TDIs 7 November 24th, 2006 16:15
Six stroke diesel MAW General Automotive 0 March 10th, 2006 13:05
Diesel Smiles on Us jchagtdi Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 0 January 9th, 2004 06:33
Page generated in 0.19285 seconds with 10 queries
[Output: 140.78 Kb. compressed to 118.96 Kb. by saving 21.82 Kb. (15.50%)]
