Old July 20th, 2012, 09:37   #1
Default 2006 Jetta TDI BRM Turbo Actuator Replacement
I'm a newbie and hoping i got the correct forum for this question.
I've got a 2006 Jetta TDI engine code BRM, 5 spd manual trans. The entire car turbo and all are stock. I started hearing air/vacuum leak coming from the engine compartment. This was about 1 year after I had major engine repair. I lost two valves, and the camshaft at 117,000 miles then about 150,000 miles this actuator started leaking. The car now has 170,000 miles on it.
Regarding the air/vacuum leak I noticed the car didn't seem to have much power until about 1,800 rpm then you could feel it pull really hard. After the 1,800 rpm range the leak seemed to be less. Upon investigation I could feel air leaking from around the waste gate actuator rod. I looked for a replacement actuator then decided to wait due to the high cost of the turbo and began some searching which is how I found your forum and some threads about the actuators.
I know the engine code is BRM but I have no idea what the turbo is. I'm not even sure if there are multiple manufacturers in 2006 for the turbos. I saw mention of Borg Warner and Garrett in the thread but don't know if that was the turbo or actuator or both.
Anyone know how I can find out which one?
Anyone know how I can find out if the actuator works on vacuum or pressure? I'm kinda thining pressure since I can feel air blowing around the actuator rod.
REEDBR is offline   Reply With Quote
Old July 20th, 2012, 09:46   #2
Vacuum operated.
At least one person reported fixing an actuator rod seal leak on a BRM on this website. He took it apart and put an oring seal around the shaft.
There are no aftermarket actuators available, sometimes you can find used ones.
Old July 20th, 2012, 20:53   #3
MyAvocation's Avatar
If you do an advanced search in this section you'll find that someone recently sourced a replacement CR actuator and even more recently another member successfully implemented it on a BRM. Is much cheaper than a full BRM turbo assembly.
To diagnose your actuator, just put a vacuum pump on it.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old July 21st, 2012, 02:42   #4
You are correct. I forgot. You can buy and modify the mount for a Common Rail turbo actuator, which are available.
It almost sounded to me as if he was feeling exhaust from this vane control shaft lever.
Perhaps he needs to check to see if he needs to adjust the vane lever stop set screw?
If we knew where Ripley was, we might be able to suggest some local help, or find a VCDS owner that would help out.
I do agree that he needs to do more diagnosis.
Old July 23rd, 2012, 07:31   #5
No sure, but Ripley sounds like WV.
2003 Jetta TDI 200,000 mi. Horrible fuel milage? Check your thermostat: http://forums.tdiclub.com/showpost.p...49&postcount=7
dieselfuel is offline   Reply With Quote
Old July 26th, 2012, 13:05   #6
Salmonbum's Avatar
TDI(s): '06 Jetta
I think I need an actuartor on my BRM (202k). I watched the arm and its not moving when throttle is applied. Anyone in Michigan wanna tackle this?
2015 Challenger Scat Pack; 2014 Silverado LTZ
2014 Subaru Crosstrek; 2003 GMC 2500HD Duramax SLT
2006 VW Jetta TDI
Home of GMPR, HR Mackinaw's Wild "Wyatt"
Salmonbum is offline   Reply With Quote
Old December 4th, 2012, 11:02   #7
I think I'm having the same problem with my 2006 BRM. I seem not to have any power under 1800 and then I have more power. The cam is already replaced, and has been inspected. Does anyone have a step by step I can follow to test the Vane Actuator with a vacuum pump?
Thank you for your help
BioJetta2001 is offline   Reply With Quote
Old December 4th, 2012, 12:09   #8
Fuel Economy: 46.2 from the paper and pen.
Have someone start the car and see if the actuator rod pushes down upon car start...if not, then pull the vaccum hose off the actuator and using a vaccum gage, see if you have vaccum with the engine idling. If you do have vaccum, the N75 is good and the actuator is toast. idparts just started selling the actuators last week (they weren't available before that) see link below. Also, with your exhaust is noticably louder if your actuator is toast.
2006 Pkg. 2 TDI Jetta - BLACK: 2.5 inch straight pipe from cat back, 35% tint, GLI grille w/fogs, Green TDI badge, Monster mats, Gorilla Gear trunk liner, Euro Cupholder, LED Interior Lights, Yakima Roof Rack w/ Cargon Basket, Euro Taillights (Amber Club/Rear Fog), Alligator Custom Chip Tuning!
scrichy84 is offline   Reply With Quote
Old December 21st, 2012, 04:24   #9
Fuel Economy: 4.4 per 100KM's
Just incase one did not see before posting by scrichy84, idparts just started selling the actuators at a cost of $279.00
FXDL is offline   Reply With Quote
Old December 21st, 2012, 17:07   #10
Moderator at Large
Hissing noise from the engine compartment is commonly a leaking EGR cooler on these cars - not necessarily the turbo.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old March 8th, 2016, 04:03   #11
dae06's Avatar
Update: now it's $369.00
2005.5 Jetta 1.9 TDI, Manual Transmission.
206,000 miles as of 11/14/2017; New Cam and TB as of 12/1/2014, New EGR valve and EGR cooler as of 3/29/2016
dae06 is offline   Reply With Quote
Old July 23rd, 2016, 15:20   #12
jay.sejkora2011's Avatar
It's now up to 369
Anyone have a solid set of instruction for a DIY install? About to make a long distance cross country trip and I would prefer not to let this slide until afterwards.
jay.sejkora2011 is offline   Reply With Quote
Old July 24th, 2016, 03:12   #13
Originally Posted by jay.sejkora2011 View Post
It's now up to 369
That $279 price was nearly four years ago. There's a fair amount of fabrication and labor in swapping the bracket. And the actuator is subject to VW's parts pricing, which often changes, sometimes significantly.
If you have more than 150K on your turbo it may be more cost-effective to replace the turbo.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old January 7th, 2017, 12:00   #14
Fuel Economy: 37city 59 highway
Default Actuator
My mechanic says the actuator is bad and that he cannot find one and that it is better to change out entire turbo, i had put new turbo on at about 90,000 miles ago, do you think i should just change it out
overdoz73 is offline   Reply With Quote
Old January 17th, 2017, 12:45   #15
Moe_mkvtdi's Avatar
TDI(s): Mkv jetta
The same thing happened to me and honestly it's better to do the turbo swap because just to take the actuator off is a pain in the ass. It is pretty pricey but it's better to swap out the whole thing. I replaced the actuator and after everything was done it ran for about 100 miles and then the turbo blew up so I had to do all that work again.
Moe_mkvtdi is offline   Reply With Quote
BRM Turbo Actuator Replacement Experiment? cevans VW MKV-A5 Golf/Jettas 71 August 12th, 2017 14:22
Want to buy an Actuator for a 2006 Jetta Tdi brm mk5 turbo ecaddy Private TDI Items for Sale/Wanted 2 May 4th, 2015 19:47
2006 Jetta BRM Turbo Actuator Replacement REEDBR VW MKV-A5 Golf/Jettas 5 September 15th, 2013 08:33
BRM Turbo Actuator Replacement flyvsdrive VW MKV-A5 Golf/Jettas 9 June 2nd, 2013 05:47
2006 BRM TDI - Turbo Actuator delslo VW MKVI-A6 Jetta Sedan (~ 2011+) 2 March 8th, 2011 20:10
Page generated in 0.16753 seconds with 10 queries
[Output: 124.46 Kb. compressed to 103.67 Kb. by saving 20.79 Kb. (16.71%)]
