Old July 17th, 2012, 05:54   #1
N8rbug
Question Need: Airlift 1000 Part # for '03 Jetta Wagon
I've recently installed a Curt hitch to pull my trailer. I'm looking for the correct Airlift 1000 Load Assist Kit part # for my 2003 Jetta TDI WAGON. These red bags go inside the springs to help maintain correct ride height.
I've searched the forum but only found one poster stating he used # 80777.
An email to Airlift has gone unanswered. Anyone else done this mod? Which kit is the right one for the '03 Wagon?
N8rbug is offline   Reply With Quote
Old July 17th, 2012, 06:31   #2
Ian F
Try searching in the Upgrades (non TDI Engine related) forum. I think you'll find what you need.
'03 Jetta GLS TDI Wagon, Indigo Blue, Tan leather, Monsoon, W.E. BBS RXII's. (purchased new 5/03)
'08 Dodge Caravan
('64 Mini Cooper, '72 Triumph GT6, '73 Volvo 1800ES, '79 Spitfire 1500)
Ian F is offline   Reply With Quote
Old July 17th, 2012, 09:38   #3
deejaaa
deejaaa's Avatar
Fuel Economy: JETTA IS FOR SALE!
i am sure he did a search in the general area, not just one specific area.
i too had a hard time locating the info you seek, this search engine leaves a lot to be desired.
if you want to go a diff route, give this a look:
air shocks on back of Golf from 04 caddy deville. Nice lift/ride. Small mod to shocks, but bolted right up.*
monroe MA822
http://www.amazon.com/Monroe-MA822-M.../dp/B000C55T7W
http://www.partstrain.com/ShopByDepa...DILLAC/DEVILLE
http://forums.tdiclub.com/showpost.p...ostcount=12267
it was suggested to me to try this spring insert, Air Lift Kit # 80753, but it wasn't listed for the VW. it was suggested to read this post but i found no useful info there:
http://forums.tdiclub.com/showthread...=air+lift+bags
post your results when you find out what you want. i will be using the Monroe airshocks for mine.
THE 2002 jetta IS for sale. PM FOR DETAILS.
deejaaa is offline   Reply With Quote
Old July 17th, 2012, 16:24   #4
N8rbug
I did indeed search to no avail..........I need an '03 Wagon owner who has done this mod........with the red airbags from Airlift that fit right inside of the rear springs.......to see this post and tell me the part number.
Old July 17th, 2012, 17:47   #5
deejaaa
deejaaa's Avatar
i am sure you did, as did i. did you look at the airshocks?
Old July 18th, 2012, 04:40   #6
N8rbug
Okay "Ian F" and "deejaaa"........You infer that the answer to my question is readily available by using the search function..........Just for S&G.....I'll bite.......
Results from searching "airshocks" under "Upgrades non-TDI Engine related":
http://forums.tdiclub.com/search.php?searchid=10939347
Results from searching "airshocks" on entire forum:
http://forums.tdiclub.com/search.php?searchid=10939361
Anyone else actually have the correct part number ????
Old July 18th, 2012, 05:06   #7
Ian F
Ok.
http://forums.tdiclub.com/showthread...t=Airlift+1000
Scroll down to post #13.
Oh... and I did a search for "Airlift 1000" basically doing a copy-paste from your post.
'08 Dodge Caravan
Old July 18th, 2012, 05:22   #8
deejaaa
deejaaa's Avatar
Originally Posted by N8rbug View Post
Okay "deejaaa"........You infer that the answer to my question is readily available by using the search function......????
not at all fella. i WAS on your side. if you would of READ what i posted, i GAVE you the info on the airshocks. good luck in your search without the help from ME!
Old July 18th, 2012, 10:00   #9
N8rbug
For Ian F.......thanks for that info!.......that led me to three other relevant posts.........and it boils down to this.....
#80753 is 3.44" diameter......8.75" high
#80777 is 3.44" diameter......7" high
An email finally, from Airlift themselves suggested measuring these two parameters with the car level.....unloaded.....to choose which would be the better application. (One poster indicated Airlift told him too short was better than too long.)
For deejaaa........Ok Mary.....you can un-wad yer' panties now!
Old July 18th, 2012, 12:02   #10
blazen71
blazen71's Avatar
Fuel Economy: 36.6mpg
Try referencing this thread. I saved it just for this reason.
http://forums.tdiclub.com/showthread.php?t=202381
I'm your Huckleberry
blazen71 is offline   Reply With Quote
DIY: Airlift 1000 for Lowered Car (or how to adjust rear height in seconds with coilo kilimats Upgrades (non TDI Engine related) 10 December 4th, 2010 06:52
03 Jetta Gls Wagon All Or Part (az) WRECKEDJETTA Private TDI Items for Sale/Wanted 64 November 15th, 2010 14:07
04 Passat TDI with Airlift 1000 system YES! Embs VW B5 Passat TDIs 48 June 20th, 2007 18:30
FS: Brand New AirLift 1000 vwtdi04 Private TDI Items for Sale/Wanted 10 October 30th, 2006 22:53
Airlift 1000 Installed, questions for the Experts dave333 Upgrades (non TDI Engine related) 10 December 13th, 2005 10:00
Page generated in 0.13476 seconds with 10 queries
[Output: 96.58 Kb. compressed to 82.16 Kb. by saving 14.42 Kb. (14.93%)]
