Old July 15th, 2012, 17:49   #1
monkfarm
Question ?Type/Brand Oil for 2012 Jetta TDI sportwagon
I'm sorry, after reading many threads on oil types (I discovered I will not change oil at the current 5400 miles, (I will wait until 10k) and I will not use the oil I use in my 06 TDI Bug (Rotella 5-40 T-6 Synthetic).
I am thoroughly confused still on what oil to buy (for 2012 Jetta TDI Sportwagon), and where people are buying it. Is there newer regs from VW on oil (rather than the 507 that was mandated by VW)?
I live out in the Sticks, so usually when I fire up the Jetta, I drive 30 to 80 miles, or more. . .
I'm also wondering if the first 3 oil changes are still free (She (the salesgal) might have mentioned it but I was dealing with my wife's "New Car Panic".)
Also, what is the best Oil extraction unit (through the dipstick holder) and where is a good place to buy it. . .
(I should perhaps study the current threads further, but I have already spent a couple hours in confusion. . .)
Thank You, Dean
monkfarm is offline   Reply With Quote
Old July 15th, 2012, 18:20   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Dean, welcome aboard!
The oil requirement to maintain your new vehicle waranty is incredibly simple. If it doesn't state 507.00 on the label, it isn't suitable
Old July 15th, 2012, 18:27   #3
TDiSkater
Fuel Economy: 35 Winter/41 Summer
Yes, VW is still offering the first 3 services as part of the sale. Each at 10K miles or annually if you drive under 10K miles per year (as unlikely as that sounds given your location).
PS. Lots of threads of topside extraction or going underneath. Arguements on both side, so it's fine whichever you prefer. The underside crowd would remind you to get under the car to inspect if you chose to extract via dipstick.
VW-OEM European Steel Skidplate | 35% LLumar Tint all around | Pano Sunroof | ScanGauge II | WeatherTech Weatherflectors and Digital Fit Floorliners l Faux TDI Mirror Etching l RGM Bumper Guard | Conti PureContact | Non-OEM Aspherical Mirrors - $3 Blind Spot Mirror | 70,000 miles |
TDiSkater is offline   Reply With Quote
Old July 15th, 2012, 22:18   #4
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Dean,
Welcome to TDIClub and the world of Diesels.
There are several vendors that can supply you with the correct oil including but not limited to RiversideVwParts.com, IdParts.com, Bleached Bora, and several other trusted TDIClub vendors.
Whatever you decide to get, make absolutely sure it meets the 507.00 specifications.
Also, as long as you are in the United States, your first 3 services (10k, 20k, and 30k) are included free of charge under the CareFree Maintenance program.
Fixmy59bug is offline   Reply With Quote
Old July 16th, 2012, 06:04   #5
monkfarm
Thank you all, you have made me feel most welcome!!
Old July 24th, 2012, 07:15   #6
Niner
duplicate account, banned
Try to find one of these on the internet and order it.
Pela 6000 oil extractor. http://www.jerrybleach.com/pelaapplications.html
http://www.youtube.com/watch?v=su5kYzAyFt4
Niner is offline   Reply With Quote
Old July 24th, 2012, 08:53   #7
UberVW_TDI
UberVW_TDI's Avatar
A couple widely available 507.00 spec oils:
1. OEM fill: Castrol Professional SLX LL-03 5w-30.
Available at the local VW dealer.
2. Mobil 1 ESP 5w-30. Available at Pep Boys.
Both prices / liter are about the same.
I tried the Mobil 1 on my first oil change and my engine started
Using oil. ~ .5 liter in 1000 miles. I switched back to Castrol SLX
and the oil consumption stopped. Weird.
I've got 62,500 miles on the odometer so far and have been happy
with Castrol SLX Professional LL-03.
CP3 HPFP, Valeo SMF Clutch Kit, Dieselgeek Sigma6 Sport Shifter, H&R Premium Performance Coilovers, H&R 24mm Rear Stabilizer Bar, H&R 26mm Front Stabilizer Bar, 17" VW Goal Wheels, Michelin Pilot Sport A/S 3 (245/45R17)
UberVW_TDI is offline   Reply With Quote
Old July 24th, 2012, 08:56   #8
UberVW_TDI
UberVW_TDI's Avatar
And now I notice your not in the USA.
Anyway, I'm sure there are more European brands
widely available to you then.
Old July 24th, 2012, 16:00   #9
tdiatlast
Weird is right. I bet you didn't put in as much as you thought you did when you used the Mobil 1. I can't believe an engine could burn .5 liter in 1k miles, and then not burn oil.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old July 24th, 2012, 16:18   #10
Niner
Probably got sucked up filling the oil filter cannister... after a filter change.
Old July 24th, 2012, 19:48   #11
Fixmy59bug
Fixmy59bug's Avatar
Are you sure the ESP formula comes in quarts as well?
Every google image search I could find of the ESP formula 5w-30 showed a liter bottle.
I searched this because I was gonna suggest the same thing, but decided to search first...
Old July 24th, 2012, 20:00   #12
geodug
I have done two oil changes using Mobil 1 ESP 5W30 oil. The oil both times came in 1 Litre plastic bottles. Also, both times the oil was purchased from Pep Boys.
Not to say that it isn't possible that Mobil may decide to sell it one day in quart bottles.
geodug is offline   Reply With Quote
Old July 24th, 2012, 20:05   #13
Plus 3 Golfer
Plus 3 Golfer's Avatar
Your right it's Mobil 1 ESP Formula M that comes in quarts which I used for my 60k OC. I deleted my previous post.
Plus 3 Golfer is offline   Reply With Quote
Old July 24th, 2012, 20:36   #14
Derrel H Green
Derrel H Green's Avatar
Arrow A Good Choice
Originally Posted by Plus 3 Golfer View Post
Your right, it's Mobil 1 ESP Formula M that comes in quarts which I used for my 60k OC.
To clarify, you are using the same oil recommended for my MBZ.
It is Mobil 1 ESP Formula 'M', a 5W-40 and it is available in
quart containers and not in liters to the best of my knowledge.
I get mine from the MBZ dealer. It costs MUCH less than Pep Boys!
Unless of course the oil is on special and you can get the Pep Boys manager to honor that special?
The 'other' Mobil 1 oil the Mobil 1 ESP Formula (not Formula 'M')
is a 5W-30 grade and it is sold in liters only.
It is recommended for the TDIs, but the factory VW oil is very close to being a 5W-40,
so why not just go ahead and use ESP Formula 'M' and be done with it?
DHG
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old July 24th, 2012, 21:29   #15
Plus 3 Golfer
Derrel, yes that's correct. NAPA had it for $5.79 per quart in June ( bought 12 quarts). Drivbiwire says MB dealers sell the 5 quart jug and I think he pays less than $5 per quart. I'll check a MB dealer the next time I need some.
Towing - 2012 Jetta TDI Sportwagon loonytuna TDI 101 19 August 18th, 2015 12:43
2012 Volkswagen TDI Jetta Sportwagon Tornado Red coletraim00 TDI Cars for Sale/Wanted 4 May 25th, 2012 11:02
2012 Jetta Sportwagon oil changes familyman831 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 May 1st, 2012 12:42
Picked up 2012 Sportwagon for the wife grwoolf VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 August 30th, 2011 10:01
What diesel brand and type should be used on 2002 tdi? amitsekhon Fuels & Lubricants 11 September 28th, 2008 12:33
Page generated in 0.16368 seconds with 10 queries
[Output: 130.44 Kb. compressed to 108.87 Kb. by saving 21.57 Kb. (16.53%)]
