cymroboi
vw caddy BLS engine non starter ???
hi all my name is keith and im new to this forum...
my old man has a 57 reg vw caddy with the 1.9 pd bls engine ,hes been having some starting issues over the last few months ,may be today it will fire up all day and may be tomorrow shell crank over a bit before she starts this happens hot or cold ,but last few days of last week she went worse ,finaly on sturday she packed up ,she will cranck over but no rpm signal ,ive checked with my works scanner (snap on solus and the texa axone 3) im a mechanic by trade .. large vehicles.. i was getting cam sensor coming up every time but on saturday no fault code so ive changed the cam sensor ,no different ,so i decided to change the crank sensor WHAT A BOL*****KS OF A JOB but still the same ,and still showing no rpm signal on the live data ??? any one here had a similar problem ,and could it be the crank seal not giving off ,the signal to the sensor ???? could you please help !!!!!
oh and i run a 2002 passat 1.9 tdi 130 my self
