Old July 10th, 2012, 17:46   #1
Roadhog_
Default Monsoon AUX input?
Any aftermarket adapters to add an AUX input or Bluetooth to an OEM Monsoon stereo?
A while back I think I found some kind of adapter that goes on the back of the unit that you plug into the antenna port and then plug the antenna into the adapter. So basically you have a nice aux port then.
That would be pretty nice if I could find what it was again. If not how about some Bluetooth adapters? I also don't want one that has to go in the trunk where the CD changer is. Though, if there is a Bluetooth one that can go there that would be fine too.
Roadhog_ is offline   Reply With Quote
Old July 11th, 2012, 11:14   #2
toolongtospell
Fuel Economy: 35-38mpg (auto)
Might look into this
http://cdchangeremulator.com/vw-audi...l?review=write
toolongtospell is offline   Reply With Quote
Old July 11th, 2012, 11:45   #3
ALL4AMD
TDI(s): 02 Jetta GLS
Fuel Economy: Fuelly
I use a tape adaptor to connect to my cell and listen to Pandora but then again I have the GLS
ALL4AMD is offline   Reply With Quote
Old July 11th, 2012, 12:32   #4
toolongtospell
Tape adapters are fail... they ususally give a fuzzy sound to the music.
Old July 11th, 2012, 15:17   #5
ACHTUNG TDI
Here's another possible adapter from www.enfigcarstereo.com
http://enfigcarstereo.com/VW_AUX_DMX_V5.html
ACHTUNG TDI is offline   Reply With Quote
Old July 11th, 2012, 17:30   #6
Tahada
TDI(s): 2005 Golf
I have one of the adapters I used previously with my monsoon. For sale if you need it.
Tahada is offline   Reply With Quote
Old July 11th, 2012, 18:58   #7
ksdavi3
TDI(s): 2002 Jetta
www.gromaudio.com has several adapters that plug into the factory system either behind the dash or in the trunk, allows you to play devices thru USB, AUX cable, bluetooth, etc
ksdavi3 is offline   Reply With Quote
Old July 11th, 2012, 19:01   #8
theantirice
TDI(s): none
Originally Posted by ACHTUNG TDI View Post
I've been using the BlitzSafe in my car for about 2 years...I love it.
Did a quick google search and found an install thread:
http://forums.tdiclub.com/showthread.php?t=283994
theantirice is offline   Reply With Quote
Old July 13th, 2012, 21:08   #9
Roadhog_
Thanks for all the links.
This one looks like what I would want the most.
Any retailers for it in the USA?
Though the Grom one does have bluetooth so I could just slap that in the trunk. hmm
Old July 14th, 2012, 12:21   #10
deejaaa
deejaaa's Avatar
Fuel Economy: 59 latest mpg
http://cdchangeremulator.com/index.p...9&review=write
RIP Grams, 6-27-16
Originally Posted by stamar View Post
I am a tdi expert now.
A wise man told me "Cut Twice, Measure Nunce."
deejaaa is offline   Reply With Quote
Old August 5th, 2013, 22:04   #11
intendwithin
Cheaper or just the same cost to purchase a new head unit which will interface with iPhones and iPods waaaay better. Pandora, hands free calling. Why spend $100 on cable adapters when I can spend $70 on a head unit that has all the bells and whistles...
intendwithin is offline   Reply With Quote
Old January 2nd, 2014, 08:47   #12
FloridaMutt
Fuel Economy: '04--> 42 mixed driving
can you suggest one?
FloridaMutt is offline   Reply With Quote
Old January 3rd, 2014, 08:32   #13
romad
romad's Avatar
Start here: http://www.crutchfield.com/g_300/All-Car-Stereos.html
If it works, this is a list of 169 stereos that fit my 2005 Jetta Wagon (which is identical to the 2004 Jetta Wagon). Have fun!
The fleet:
romad is online now   Reply With Quote
Old January 3rd, 2014, 09:13   #14
FloridaMutt
thanks
I actually went there after I asked the question.
I found that I would need a $80 adapter in order for the steering wheel controls to work. So even with the least expensive unit, I am back in square one having to buy an adapter.
At least for my wife's 2005 which has the monsoon and steering wheel controls it seems the adapters suggested here might be a better option.
Old January 3rd, 2014, 09:23   #15
trailhead
trailhead's Avatar
I installed the 12 pin Denison from Enfig. Cost $70, works great!
You just need to determine if your car has 8 pin or 12 pin on the back.
Mine, 05 jetta wagon has 12 pin.
http://enfigcarstereo.com/DENSION_GW1LVW1.html
2005 Jetta Wagon, VNT-17 5spd, Short Shifter, Stage 2 w/D Idle, Muffler delete,
GLI Brakes, GTI interior, 2" Receiver, Frost Heatr, 4 note Cadillac horns, LED's, Skid plate.
My car; http://forums.tdiclub.com/showthread.php?t=387234
trailhead is offline   Reply With Quote
Lost AUX Input 325_Guy VW MKV-A5 Golf/Jettas 10 November 14th, 2011 05:51
Aux input for a Monsoon pungey Upgrades (non TDI Engine related) 10 May 4th, 2010 19:44
aux input cubanforever16 TDI 101 2 June 23rd, 2009 18:44
Aux input to Monsoon radio? Calif05Passat VW B5 Passat TDIs 10 January 24th, 2008 14:50
Adding Aux input to Monsoon DayOhTdi TDI 101 6 October 27th, 2003 12:55
Page generated in 0.16026 seconds with 10 queries
[Output: 122.55 Kb. compressed to 102.17 Kb. by saving 20.38 Kb. (16.63%)]
