Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 6th, 2012, 11:45   #1
sydneycb
Fuel Economy: 40 MPG
Default Fuse Location
Could someone tell me where the fuse for the cigarette lighter is located? I usually charge my phone through this outlet but it is not working. The power outlet for the backseat is also not working. Same fuse I'm guessing???
sydneycb is offline   Reply With Quote
Old July 6th, 2012, 15:47   #2
Cesar
Cesar's Avatar
Fuel Economy: Best 4.1L/100kms, Worse 7.5L/100kms
Check bottom left side of the steering wheel.
Or even better go on youtube I am pretty sure you can find someone with some mods already done ;p
Cesar is offline   Reply With Quote
Old July 6th, 2012, 16:45   #3
mo_focus
mo_focus's Avatar
TDI(s): 84 944
F30, its a 20A fuse and its 13th from right upper row.
1984 Porsche 944- New Toy
2009 Acura RDX Turbo
mo_focus is offline   Reply With Quote
Old July 9th, 2012, 10:23   #4
sydneycb
I'm assuming you mean the fuse box inside the car? There is only 12 fuses in the top row. I'm attaching a pic of the fuse box. Can you tell which one is for the lighter?
Old July 9th, 2012, 11:03   #5
solid19snake
solid19snake's Avatar
i believe mo_focus is saying it's the ORANGE 20A between the 1A and the 30A, which is 13 SLOTS from the right. since there are 3 empty slots to the right, it would be the 10th fuse from the right
i cannot confirm this is correct, just clarifying what i think he meant to say
2012 VW Jetta TDI (6MT) - DG Panzer Plate
solid19snake is offline   Reply With Quote
Old July 9th, 2012, 17:29   #6
CDN TDI
CDN TDI's Avatar
F30 is circled below.
CDN TDI is offline   Reply With Quote
Old July 16th, 2012, 09:04   #7
sydneycb
Thanks guys. That was indeed the correct fuse.
Fuse Location eyetdiman VW B5 Passat TDIs 2 November 6th, 2010 15:24
Fuse location ? Tailgunner VW MKIV-A4 TDIs (VE and PD) 2 November 2nd, 2007 17:37
Fuse location ? Tailgunner VW MKIII-A3/B4 TDIs 1 October 31st, 2007 12:43
Need help! fuse / cable location jrock TDI 101 6 December 21st, 2006 09:40
ABS Fuse location aerobatika TDI 101 0 November 9th, 2001 04:31
Page generated in 0.13387 seconds with 10 queries
[Output: 78.12 Kb. compressed to 67.67 Kb. by saving 10.45 Kb. (13.37%)]
