Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old July 5th, 2012, 20:08   #1
jimmyto
Default What drives A/C Compressor?
Hi,
My A/C stopped working last Friday. It stopped working like this every 18 months as the Fan control module simply burned. Appears to be an electrical problem every time. I replaced the module and A/C worked fine again.
I replaced both fans last year.
This time is different. Both fans still work when I press the A/C button but no cold air comes in. Engine RPM drops slightly. I assume because both fans kick in. Problem is I don't think the compressor kicks in. Any suggestions what the problem might be?
Is the compressor driven by a belt and activated by the clutch? I smelled burnt right before A/C failed. Is it possible that the belt broke?
TDI MK4 Golf 2001.
2001 Golf TDI manual silver 340 000 kms.
jimmyto is offline   Reply With Quote
Old July 5th, 2012, 20:23   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
The same belt also drives your power steering and alternator. You'd have a dummy light as well as a very difficult time turning the steering wheel if the belt broke.
Time to figure out why your AC fan control module keeps burning up!
-tom
autos: 15 Volvo V60, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old July 5th, 2012, 20:30   #3
jimmyto
Thx.
I put a new module that I had bought for $30 and cracked open with a hammer the old module but it wasn't burnt this time so I guess I need to find out why the clutch is not engaging.
Old July 5th, 2012, 20:30   #4
jimmyto
I'm looking for some posts on how to manually activate the clutch.,,
Old July 5th, 2012, 23:49   #5
imo000
imo000's Avatar
Fuel Economy: Good enough
Put the +-12V from the battery to the clutch connector and it should engage. But ypu can chwck for lower at the connector too. If there is one, the clutxh is fired. My bet is that it is.
imo000 is offline   Reply With Quote
Old July 7th, 2012, 14:02   #6
stoutguru
I am betting that the A/C clutch is no good. I normally see cars come in with the small rad fan not working and a bad A/C clutch. If you replaced the fans because they were not working it might have put extra load on the A/C system.
stoutguru is offline   Reply With Quote
Old July 7th, 2012, 17:35   #7
RDA3440
RDA3440's Avatar
TDI(s): None
I replaced the coil in the clutch last year because a used coil just happened to come my way. I had the same symptoms - burning smell, no a/c.
It was the coil that burned out causing the clutch to no longer engage.
Anyways the used coil I had put in was iffy so I got a year out of it and now I am going to replace the entire clutch assembly which turns out is pretty inexpensive. The clutch assembly includes a new coil.
The coil is just an electromagnet that engages the clutch magnetically. You can wire a switch and relay to it. I don't know if there an any ill side effects as the car reads throttle position, temp, at the least before allowing the clutch to engage.
2010 BMW 335D JBD, M3 Upper/Lower Control arms, ECS Tuning Trailing Arms, INPA, BMWhat - more mods to come!
2005 Golf TDI GLS - Many Mods - RIP 02/03/2014
RDA3440 is offline   Reply With Quote
Old July 10th, 2012, 18:44   #8
imo000
imo000's Avatar
You hardwire that AC to a relay and you will fry the system in a short time. There are pressure switches in the system and many other parapmeters that dictates how the system operates. Find the cause of the problem and don't just bypass it.
Old July 26th, 2012, 05:07   #9
TOPTRUK
TOPTRUK's Avatar
TDI(s): 01 Golf TDI
Fuel Economy: 47-50
Not to highjack the thread, but I have a very similar issue….
I checked the low side fitting for the ac and it buried the needle on my cheapo ac filling valve. The clutch is fried on the ac compressor (smelled like burnt lining as well) and there is no resistance at the coil. I know I need a new clutch and coil, but when I turn the compressor it takes high efforts to turn. I have checked a buddies TDI and his is easier to spin. Is it because there is too much pressure in the lines that the compressor is hard to turn or is there debris in the compressor?
I also probed the line going to the compressor coil and it is surging….. There will be a split second of power, cut out for 3-5 seconds, then another split second of power. Does the fan control module send a signal to the coil like that if there is too much pressure in the line? Or does it sense that the coil is an open circuit and fault to this setting?
Any ideas would be obliged.
TOPTRUK is offline   Reply With Quote
Old July 26th, 2012, 05:11   #10
DanG144
If the compressor is hard to turn, then it is bad.
Old July 26th, 2012, 05:22   #11
TOPTRUK
TOPTRUK's Avatar
TDI(s): 01 Golf TDI
Fuel Economy: 47-50
Is there anyhting else that needs to be R&R'd in the ac system when doing a compressor? I dont want shavings if it went bad getting into the new compressor.
Also, should the power feed going to the compressor be surging like that with the symptoms mentioned? Thanks for the help,
Curtis
Old July 26th, 2012, 06:30   #12
DanG144
If there are metal shavings, you need to have a very good flush done.
You may want to replace the condenser, rather than depend on the flush.
You will still need the flush.
You will need a new filter drier.
A professional would also replace the TXV (I usually do not.)
The power to the clutch often cycles when it is bad, apparently a protective feature of the FCM. If the clutch is working and it is cycling off and on, that is abnormal, and is often a sign of a bad High pressure sensor.
Old July 26th, 2012, 13:15   #13
2ManyKMfor1Tank
TDI(s): 2000 Jetta
Ok, here's a question for you then Dan. I sit at idle sometimes in my car at lunch time. I keep the A/C on, and do hear and feel it engage and disengage. Should it not cycle at all when the a/c is on? Or is there an acceptable time period that should pass between cycles?
I had a new compressor installed last year, if it is cycling like I think you are saying, I want to fix the problem before it happens again.
Is there a diagnostic for the High pressure sensor besides this?
Aaron
2000 Jetta TDI - Ventectomy, Defender Skid Plate, Bilstein TC Comforts, Audi TT bushings, Newsouth Boost gauge, Recaro GLI's, Frost Heater, FK Depo headlights with HID's, PP502's, DG Racepipe, Malone Stage 3, ScanGauge II.
2ManyKMfor1Tank is offline   Reply With Quote
Old July 27th, 2012, 11:58   #14
DanG144
You can check the output of the HP sensor by watching a pressure gauge and looking at the duty cycle on a meter.
Make sure that both of your fans are working. Your fans can shift to high, but then pressure should come down.
I have never seen a properly charged, healthy system on a mk IV cycle off due to overpressure.
Old July 28th, 2012, 12:51   #15
imo000
imo000's Avatar
If your clut h is cycling too often, the pressure is probably too low.
Replaced my A/C compressor clutch WITHOUT pulling the compressor. firehawk618 VW MKIV-A4 TDIs (VE and PD) 2 June 14th, 2012 13:28
2 years post rebuild my AC compressor died(bearings), How about electric compressor? josh8loop VW MKIV-A4 TDIs (VE and PD) 6 January 9th, 2012 18:54
Short drives? somepunk22 TDI 101 17 July 30th, 2004 13:00
Short Drives / Long Drives tgoetzman TDI 101 11 August 28th, 2002 00:04
It actually drives around... TDI Holland New Beetle TDI Picture Gallery 9 November 9th, 2000 11:27
Page generated in 0.12289 seconds with 10 queries
[Output: 125.69 Kb. compressed to 104.75 Kb. by saving 20.93 Kb. (16.65%)]
