Old July 5th, 2012, 06:57   #1
97Jedi111
Fuel Economy: 50 mpg
Default How much CCA does the 1.9 TDI engine require?
I am buying a new battery and I was wondering how many cold crankjng amps (CCA) should the battery have to effectively start the TDI? The one that is in the car has 650. I want just a little more than is required. Also I was told to buy an interstate battery. Any thoughts?
97Jedi111 is offline   Reply With Quote
Old July 5th, 2012, 07:20   #2
jettawreck
jettawreck's Avatar
CCA is less important than amp hrs. Load from the GPs etc make some high CCA batteries fall short. The OEM VW battery has actually been a pretty good buy at the dealership (just make certain they get you the TDI/not gasser battery). Not sure about the '97 in your sig, but the MkIV were a group 94 size/type. They are not stocked everywhere, so you may have to search a bit.
And in the search dept, this has been hashed over a ton, so give the search feature a try and you will get a bunch of reading and facts.
2004 Cadillac SLS (wife's)
Old July 5th, 2012, 07:24   #3
Powder Hound
Powder Hound's Avatar
If you can find a dealer who has one reasonably priced (~$125), just get the battery from the dealer. It is a good unit; get one rated at 80 Ah. It displays european specs, so it won't list CA and CCA. So make sure you see the 80 Ah. If that number is lower, it will be either one for a NB (a little less - in the 70s) or a gasser. If they show you the gasser battery, just insist on one for a 2000-2003 Golf or Jetta TDI. Insist. If they act like you don't know what you are asking about or they claim not to have one, walk out and tell them they are a disservice to customers like you.
Then you'll be stuck in the world built for other cars, but not quite yours. The battery you have now will be OK in the summer, but it will be iffy in the winter. During a cold snap you may have severe difficulties running the glow plugs sufficiently and then cranking the engine fast enough to start. So get as many CCAs as you can - I'd go for more than 900 if at all possible.
Then do a search to see what case you need. IIRC (and that is suspect these days) a 94 will work, as should a 48, but the 48 will be too low in capacity most likely.
Good luck!
Old July 5th, 2012, 07:48   #4
97Jedi111
I apologize if this issue has been delt with before in another post. I am a newb...lol... But thanks for the info. I have actually never bought a battery from the dealer. Funny thing is I always buy OEM parts but never a battery $120 doesnt sound too bad. My battery right now has failed me once since I bought the car so I am gonna put it in another car of mine thats a gasser before I kill it completely.
Old July 5th, 2012, 09:15   #5
Rual817
Rual817's Avatar
Many mfg use simular #'s, I believe 94R is as large as posible. Here is what I have on my '00 Jetta TDI; EverStart Maxx 94R, 910a/765cca. Temps got down to 8f this past winter in NTexas, and I had no prob with cranking.
(add)
Did some searching and your car is asking for a style 41. Everstart is a Maxx 41-4 (?/?cca) and Interstate Mega-Tron 41 (815/650)
214K all stock 4spd auto., vented, 205/65/15H LRR Discount Tire RoadHugger
Really want a 5sp, tune, VNT 17/22, injectors, exhaust...
Rual817 is offline   Reply With Quote
Old July 5th, 2012, 18:33   #6
jettawreck
jettawreck's Avatar
(add)
8*F?? That's a nice seasonal fall day around here....
But, yes the NeverStart group 94 (which I have in the winter driver '01 Jetta) is a decent buy with a three year replacement warranty. They did go up in price a fair amount last year, they were $75 prior to then. The nearest dealer is 85 miles for me, so alternatives sometimes have to do.
Old July 5th, 2012, 19:33   #7
AndyBees
AndyBees's Avatar
I've been using the Wa*mart 94 for about three years. I'm thinking it was "weak" right out the gate......still seems weak. A really cold winter would take it under. Anyway, prior to the 94 battery, due to circumstances beyond my control, I made an emergency purchase ........regular Everstart Gasser battery. It did extremely well for about three years. It now resides in my Vanagon!
So, depending on your geographic location, you could probably get away with something less than EO specifications!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old July 5th, 2012, 19:34   #8
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
...Did some searching and your car is asking for a style 41. Everstart is a Maxx 41-4 (?/?cca) and Interstate Mega-Tron 41 (815/650)
I don't think this is right. I believe the early tdi had group 48.
You may be able to get a 94R in the A3 Jetta.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old July 5th, 2012, 19:47   #9
AndyBees
AndyBees's Avatar
I have a 94R in my old 1984 MK1 with the 1.6 diesel engine.........tight fit, but does work.
Old July 6th, 2012, 04:09   #10
Alchemist
TDI(s): '04 Golf
The 4 MK 3s I have use a group 41. I haven't had any trouble starting because of battery capacity, so this battery is up to the job. I think the group 48 is for the NB.
The following dimensions are from Exide:
Group 41 11 3/16L 6 7/8 W 6 7/8 H
Group 94R 12 7/16 L 6 15/16 W 7 1/2 H
Group 48 11 L 6 3/4 W 7 7/16 H
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old February 21st, 2017, 09:19   #11
justa1.9
TDI(s): Mk4 1.9
I live in a hot climate area will a H8 900 cca work
justa1.9 is offline   Reply With Quote
Old February 21st, 2017, 13:08   #12
drucifer
Sure it will work just measure to make sure it'I'll fit or ask if you can test fit the battery before you buy.
drucifer is offline   Reply With Quote
Old February 21st, 2017, 13:24   #13
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Recent discussion
Bottom line is the H8 will fit, no cover, possible minor mod to the tray.
Could be a good option in cold climates.
BobnOH is online now   Reply With Quote
Old February 21st, 2017, 16:33   #14
jettawreck
jettawreck's Avatar
Maybe a bit of overkill for warm areas. The New Beetles get a smaller battery than the Golf/Jettas and seem to start fine.
Five year old thread brought back to life.
Old February 22nd, 2017, 04:05   #15
scooperhsd
And the 2015's are also using the Group 48 / H6. If you can't find the 94R, the Group 48 will work fine.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Do 18" BBS RC's require spacers on my TDI? Skullbag Upgrades (non TDI Engine related) 5 April 27th, 2012 19:56
Canadian supplier for Group 94R battery with 765 CCA? Vince Waldon VW MKIV-A4 TDIs (VE and PD) 34 November 17th, 2009 17:00
What is the CCA of an original TDI VW battery? Diesel924 TDI 101 12 June 13th, 2005 10:28
Battery: Minimum CCA??? Stealth TDI VW MKIII-A3/B4 TDIs 21 December 29th, 2004 12:23
Minimum acceptable battery CCA? Steve Addy VW MKIV-A4 TDIs (VE and PD) 6 August 14th, 2002 10:27
Page generated in 0.17658 seconds with 10 queries
[Output: 131.57 Kb. compressed to 109.92 Kb. by saving 21.64 Kb. (16.45%)]
