Old June 30th, 2012, 12:41   #1
Addamsonflint
TDI(s): 1999.5 Jetta
Default What happens post new injector nozzle install but BEFORE vag-com tune?
Hey everyone,
I am looking at putting in some new Bosio injector nozzles soon. I am going to do the install myself, but don't have access to vag-com, so I was gonna do the install, and go see my mechanic (whose a TDI specialist) for the vag-com tuning afterward.
My first question is:
Should I get the Power Plus 520's, 502's, or the 764's?
They are all the same price on IDparts right now. It says the 502's simply "flow more fule" than the 520's, so if I wanted to generate the best power, I wouldn't see why one should go with the 520's.
And I am going to be doing this in conjunction with a new FMIC setup and upgraded intake, which it says is the optimal setting for utilizing the 764's.
My second question is:
If I can't get up to see my dude for a week or two (his shop is kinda far), are there any issues with driving around on the new nozzles without the vag-com tune?
Will I have more smoke?
Will I have more power even before tuned up with vag-com?
Are there any other issues with my engine that I need to be concerned with?
Any help is appreciated.
Thanks!
Addamsonflint is offline   Reply With Quote
Old June 30th, 2012, 18:15   #2
Ed's TDI
Ed's TDI's Avatar
Fuel Economy: 5.7 / 5.1 / 4.5 L/100km
First of all, there's not much that can be done with Vag-com in regard to tuning your car. You'd need to get a proper software tune from any of the major players in the tuning business Like Malone Tuning, TD Tuning, Rocketchip, Unitronic, etc. They will be able to change your ECU's configuration to adjust for the extra fuel you'll be getting with the bigger injector nozzles, as well as add more boost (limited by the stock turbo).
As for your car running with bigger injector nozzles without having any software upgrades will cause your car to smoke more as your ECU doesn't know how much fuel is flowing through the nozzles, only how long the injection "window" is based on its fuelling maps. You will notice more power but also more smoke.
First documented MK4 VNT20 Installation in North America!!
Done by JS Performance in Abbotsford, BC, Canada
Ed's TDI is offline   Reply With Quote
Old June 30th, 2012, 18:40   #3
Addamsonflint
I guess I could have used a better term than "tune." From what I read, it was said that should you decide to change injector sizes "you will need vag-com."
Do I not need vag-com then?
I do want to get my TDI chipped as well. But first I need to upgrade my clutch, and another mod or two as well.
Old June 30th, 2012, 19:35   #4
JERMS
JERMS's Avatar
You do need vag com, but not for a tune. You'll need vag com to adjust injection quantity (IQ). Basically, what this does is adjust the fueling for the entire fuel map, kind of like adjusting fuel pressure on a fuel injected gas engine. With bigger nozzles you will be dumping more fuel into the cylinders which will cause the engine to smoke, when you adjust the IQ, you'll back off the fueling a bit to decrease the excess smoke. You'll still have more power but you won't leave a black trail everywhere you go.
For your other question on which nozzles to get, it kind of depends on what mods you have. Some nozzles are made for stock hardware, some are made for aftermarket hardware like bigger turbos intercoolers, manifolds etc. If you go too big on the nozzles with stock hardware, you'll smoke too much.
JERMS is offline   Reply With Quote
Old June 30th, 2012, 20:27   #5
duwem
Fuel Economy: Used to get 45, but big wheels, big brakes and a roof rack, 36mpg now
You might want to do some research about having an expert pressure/flow test and balance your injectors as I dont see that on your list of steps.
2002 Golf GLS TDI 5spd-288,000 miles
Panzer FMJ Skid Plate, PP520's on Flow Balanced Injectors, H&R 28mm Rear Swaybar, Eurosport X Brace, TT Shifter, 42DD shifter Bushings, exhaust restriction reduction, Eibach Pro Kit Springs, Koni STR.T Struts/Shocks, TT front control arms, spindles and brakes, 17" wheels w/ Potenza Summer Tires
duwem is offline   Reply With Quote
Old June 30th, 2012, 21:00   #6
LNXGUY
LNXGUY's Avatar
If you've got a lot of smoke, you might wanna increase the IQ a bit. If not, drive and enjoy.
Bill
LNXGUY is offline   Reply With Quote
Old July 1st, 2012, 10:12   #7
Addamsonflint
Thanks for the explanation on that- while I'm a decent mechanic and familiar with most aspects of my TDI after working on it the last 2 years, I am still fairly novice when it comes to all the aspects involved in our engines, and don't know much about diesel adjustment and vag-com.
I guess I'm trying to base my decision for injector nozzles, based on what mods I am implementing now, and the few others I will be doing in the very near future.
I swapped out my half-shafts for VR6's while doing my R32 brake upgrade, to better accomodate for the increased power. I'm currently fabbing up my FMIC setup, in concert with a better intake.
I will be upgrading my clutch shortly. I wanted to do it myself, but it is a hefty amount of work, so I'm probably just gonna have my TDI specialist do it- although it won't be cheap, I know it will be done right and w/o problems. I will be either upgrading or simply replacing my turbo in the near future.
I will probably wait on a custom chip, until I have both of those two items complete.
That all being said- any thoughts on which way to go, based on my current setup, where my intercooler and intake will be very shortly, and the other mods in the fairly near future?
http://www.idparts.com/catalog/produ...roducts_id=500
http://www.idparts.com/catalog/produ...roducts_id=879
http://www.idparts.com/catalog/produ...roducts_id=771
Old July 1st, 2012, 13:22   #8
JERMS
JERMS's Avatar
Out of those 3, I'd probably go with the pp520, the others might be too big for use with a stock turbo.
Old July 1st, 2012, 15:37   #9
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
I think you should go with the .216um version of these
If you are only considering Bosio, go for the PP764 and a reduced fuel map
Not sure who your mechanic is, but I would strongly recommend Jon Hamilton in Marysville....he's close to you and worked on my car several times
02 Jetta, 17:1 CR 81mm ASV, block girdle, ported head, custom Colt cam, IE rods, TT springs, cryo gears, Peloquin LSD, Raxles, FueLab Prodigy pump, 12mm/DE143, HFLOX 5 x 0.013, R32 intake, NX nitrous, 6+6 billet BatMo turbo, Bilstein PSS9 coilovers, BFI mounts
MKVII GTI 6MT, full build, 525hp daily driver. Soon EFR 9174 or PT 6870
loudspl is offline   Reply With Quote
Mileage Post nozzle RC3 install.... SyNtAxx TDI Fuel Economy 1 May 24th, 2007 19:56
Injector Nozzle Install 00JettaTDI TDI Power Enhancements 2 June 7th, 2006 12:58
Having Post Injector Nozzle Swap Problems jameswolfe VW MKIV-A4 TDIs (VE and PD) 3 June 14th, 2005 21:47
post-nozzle install ECU adjustments Diesel_Knievel TDI Power Enhancements 13 July 15th, 2004 13:59
New injector nozzle install link? vwsandman TDI Power Enhancements 10 May 23rd, 2004 19:33
Page generated in 0.10913 seconds with 10 queries
[Output: 98.85 Kb. compressed to 85.34 Kb. by saving 13.50 Kb. (13.66%)]
