Old June 29th, 2012, 07:31   #1
Dana B
TDI(s): 2003
Default Keith Harley of KMH Motors
Keith thank you for the great job you did on our jetta tdi the dealer could not find the problem 'you spent 10 min. on it and found the problem and fixed it. I am so glad we found the tdi club and the mechanics your the best!!! I was wondering for cleaning the fuel injectors what product would you suggest to clean them? Thank you again for the great service and professionalism. Dana B
Dana B is offline   Reply With Quote
Old May 1st, 2013, 05:07   #2
k_harley
k_harley's Avatar
Wow, just found this by accident, glad to hear I was able to save the day (and the TDI).
I like seafoam for fuel system cleaner for the older TDI's personally.
www.kmhmotors.com
Specialized VW / Audi Service, Sales, & TDI Conversions
MALONE DEALER
k_harley is offline   Reply With Quote
Old May 1st, 2013, 05:11   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Good job! I love happy endings!
oilhammer
www.cardocautomotive.com
Old May 1st, 2013, 12:56   #4
JB05
Fuel Economy: 43/41/40
Which problem was fixed? Was it the gelled fuel or the MAF?
JB05 is offline   Reply With Quote
Old June 24th, 2013, 18:21   #5
k_harley
k_harley's Avatar
IIRC, I think this guy had a turbo replaced to fix an underboost problem by dealer or other independent shop. Well, still no boost....
What I found in my highly productive 10 mins I spent diagnosing it is that it did not have any vacuum to the turbo...or other items in the engine bay.
I knew what this was. Got my thin dentist pick, pulled the small hose off the brake booster nipple and let her have it.
The small nipple on the boost was clogged with rust particles and dirt that most likely was sucked in by the failing vnt on the old turbo.
yay!
www.kmhmotors.com
MALONE DEALER
Old June 27th, 2013, 20:44   #6
TornadoRed
TornadoRed's Avatar
yay!
Shouldn't the weak brakes have been a clue for the dealer techs? Even if they didn't know much about TDIs?
'03 Golf with 785k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat fuel filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, Delvac1
Become a TDI Club Contributor. http://forums.tdiclub.com/payments.php
Old August 6th, 2013, 20:31   #7
k_harley
k_harley's Avatar
No, brake booster is fed by main hose, not nipple going to N75, N18, etc.
www.kmhmotors.com
MALONE DEALER
Old August 11th, 2013, 17:31   #8
TDI love
TDI(s): 02 Jetta
The best way to clean the fuel injectors is to use biodiesel. Biodiesel is a natural solvent that cleans the entire fuel system. It removes gunks and clogs created by impurities in diesel. Before biodiesel was sold as a fuel, it was sold as cleaning agent to mix with diesel. The scientific name for biodiesel is methyl esters which is a natural solvent.
You can mix any quantity of biodiesel to your diesel. The higher the better. Make sure you have an extra fuel filter because all the gunk that it unclogs gets filtered in the fuel filter. So eventually you will have to change the fuel filter. You can get biodiesel at almost any major city. Just do a search.
In Houston, biodiesel is about $0.25 cheaper than gas! Yes gas! So I rather just fuel my car with biodiesel as it cleans my engine and I save money!
Biodiesel also burns much cleaner than diesel.
TDI love is offline   Reply With Quote
Old August 11th, 2013, 17:40   #9
TDI love
TDI(s): 02 Jetta
I thought I should also warn you that if you have been running diesel in your car for 100,000 or more, your intake manifold is clogged with a thick build up of soot from the petroleum residue. At 100,000 miles your car is due for a regular maintenance of cleaning this crap. However, if you use biodiesel it cleans the manifold of this thick nasty gunk.
Many times people bypass the EGR because of this. Using 100% biodiesel prevents this.
The downside is that if you been running over 100,000 miles with diesel and just started using B100 (100% biodiesel) it will clean the intake manifold and leave a nasty gunk, dissolved as oil in the intercooler. Your car may start choking and become difficult to start. To fix this, just undo the right front tire and find the tubes leading to the intercooler. Disconnect the tube and collect the nasty oil that collects from the cleaning of the intake manifold. Do this at least once a month until you find no more collection of oil.
This cost me $1000 to clean manifold then another $600 to find the collection of oil in the intercooler from the cleaning from the B100.
Old August 11th, 2013, 17:55   #10
coolvdub
Fuel Economy: 54.7 Best so far
Please help me understand how bio diesel cleans the intake manifold. I thought it was a dry manifold. Correct me if I am wrong. Just thinking out loud right now.
SMF, PD150 Intake,VNT-17 with PP764's with more to come
coolvdub is offline   Reply With Quote
Old August 11th, 2013, 17:59   #11
Good Ol' Boy
VeeDubTDI's Avatar
Exclamation
No offense, but you need to do a little research on how this stuff actually works so you can avoid being ripped off in the future. $1000 to clean a manifold is ridiculous and $600 for an intercooler cleaning is nothing short of highway robbery. I really hope whoever did this work is not on the TDIClub Trusted Mechanics list.
Old August 11th, 2013, 18:07   #12
roadhard1960
Fuel Economy: 48 mpg
I agree with VeeDubTDI. Intake manifold is the last thing before air gets in the head. The intercooler is 3 feet before that and downstream. Oil in the intercooler comes from leaky turbo and crankcase vent. Some say driving car hard once in a while blows that oil out of the intercooler.
Another by the way observation from others. The low sulfur diesel seems to eliminate intake manifold clogging. It will not clean dirty manifolds just as B100 will not clean an intake but it will not contribute to increased deposits.
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 571,000 miles and counting, original turbo. 2004 Dodge 2500 Cummins HO.
roadhard1960 is offline   Reply With Quote
Golf RPM's @ 100 KMH ?? cod Non VW Group Diesels 0 October 25th, 2011 11:40
KMH Motors is moving! k_harley Eastern USA 15 October 20th, 2011 03:52
KMH to MPH Capo-GTI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 October 6th, 2011 11:13
KMH Motors gains recognition with NPR as VW diesel advocate k_harley General Automotive 6 July 2nd, 2009 21:17
TB Change Recommendation: Keith LWB053 3wl South Eastern USA 1 July 13th, 2006 14:01
Page generated in 0.16062 seconds with 10 queries
[Output: 113.26 Kb. compressed to 95.61 Kb. by saving 17.65 Kb. (15.59%)]
