Old June 23rd, 2012, 19:05   #1
DubFamily
Fuel Economy: It's still a diesel!
Default Driver's Side Fuse Panel layout?
Hey all,
Trying to find a diagram of the interior side fuse panel for a 2012 Golf TDI. I have searched already, and found lots of talk about fuses, fuse panels, and wiring various items in but no actual discussion or images of the diagram itself.
Anyone have one?
-Jason G
Originally Posted by kjclow View Post
Dub said it better.
2014 BMW 328d xDrive
Member SSBMWO
DubFamily is offline   Reply With Quote
Old June 23rd, 2012, 19:25   #2
Plus 3 Golfer
Plus 3 Golfer's Avatar
I don't have one but if I had a 2012 Golf, I'd look in the owner's manual.
Plus 3 Golfer is offline   Reply With Quote
Old June 23rd, 2012, 19:35   #3
DubFamily
I did; no panel layout there. According to the manual the specifics are "constantly changing" so no permanent layout can be printed...
-Jason G
Dub said it better.
Member SSBMWO
Old June 27th, 2012, 04:53   #4
DubFamily
Bump, anyone?
-Jason G
Dub said it better.
Member SSBMWO
Old June 27th, 2012, 05:56   #5
cd_booth
Fuel Economy: 35/45
I don't think anyone will share a diagram from the Bentley manual. Believe me, I've tried. Try going to your dealer and asking for one.
cd_booth is offline   Reply With Quote
Old June 27th, 2012, 10:39   #6
db252
Try this link and pan down till you see the diagram. Might help for your needs.
http://forums.vwvortex.com/showthrea...-fuse-location
2012 Golf 6 Speed Tech
2005 Jetta 5 Speed
2003 Jetta 5 Speed
2001 Golf Auto
db252 is offline   Reply With Quote
Old June 27th, 2012, 10:46   #7
DubFamily
Awesome, thanks!
-Jason G
Dub said it better.
Member SSBMWO
Old June 27th, 2012, 19:01   #8
Rapshire
Ask the guy at the parts counter to print a fuse map for your VIN. Mine handed me a stack of paper that totaled 83 pages. There was a lot of redundancy so got it down to about 25 pages of fuse layouts so far.
Rapshire is offline   Reply With Quote
Old June 27th, 2012, 20:26   #9
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
As I understand it, you DO need to know the VIN to get an accurate fuse block map.
BEFORE WORKING ON YOUR CAR....
Take a few good pictures of the fuse block. It needs to be good enough to see the fuse values.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old June 28th, 2012, 04:20   #10
DubFamily
OK thanks all; I'll talk to the parts guy then.
-Jason G
Dub said it better.
Member SSBMWO
Old August 31st, 2012, 19:14   #11
ElectricMayhem
TDI(s): None!
I had the same problem tonight and eventually found somebody's GTI map online that happened to match mine closely enough to be useful. Next time I go to the dealer they are going to get an earful about the $30k compact car they sold me without anything resembling useful documentation.
It was nice not having to contort yourself into the footwell to change fuses like you have to in my Volvo though.
ElectricMayhem is offline   Reply With Quote
Wanted: Driver's Side Door Panel HealthEdMan Private TDI Items for Sale/Wanted 0 May 18th, 2011 08:09
How to remove driver's side door panel CONCHOJACK TDI 101 2 October 4th, 2007 19:51
Fuse panel layout fivestringcooper VW MKIII-A3/B4 TDIs 1 July 24th, 2007 09:27
cigarette hole in the driver's side door panel! almeizy VW MKIV-A4 TDIs (VE and PD) 4 February 24th, 2004 10:59
1996 Passat Driver's Side Kick Panel Removal Ed Thomas VW MKIV-A4 TDIs (VE and PD) 4 June 13th, 2002 19:44
Page generated in 0.14876 seconds with 10 queries
[Output: 102.16 Kb. compressed to 86.43 Kb. by saving 15.73 Kb. (15.40%)]
