Old June 21st, 2012, 09:54   #1
ba843
TDI(s): jetta 02
Default P1562 "Fuel quantity adjuster upper limit reached"
When this error occurs what exactly is happening? or not?
What is that ring around the #3 injector with the single wire coming out?
And what does it do?
ba843 is offline   Reply With Quote
Old June 21st, 2012, 10:06   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
The QA has reached it's limit while trying to provide the requested value. The QA is an internal part of the injection pump. Possible causes include worn pump, bad ECU (unlikely) and wiring.
The wire to #3 is for the needle lift sensor
Old June 21st, 2012, 10:33   #3
ba843
TDI(s): jetta 02
Would it help if I cleaned the top of the Fuel quantity adjuster ?
Where can I get a replacement Fuel quantity adjuster?
Old June 21st, 2012, 10:59   #4
BobnOH
not-a-mechanic
Welcome to TDI CLub!
Normally, the injection pump is serviced as a unit. Some folks have replaced seals and certain parts to varying rates of success. Keep in mind it is likely other internals causing the error code. Wiring is the first thing I would check. There are a couple resistance tests for these components (see Bentley manual).
I believe IDParts carries the quantity adjuster.
Old June 21st, 2012, 11:26   #5
ba843
TDI(s): jetta 02
I have the following codes
P0672 glow plug
P1562 Fuel quantity adjuster upper limit reached
P0182 I changed the fuel temp sen.
This is where I saw a lot of crud and rust on top of the fuel quantity adj.
I cleaned it off
P0402 I replaced the EGR valve because it was leaking form the weep hole.
I need to check some vac lines here.
The only noticeable change is a little lurch at idle.
I have a rough idle when cold but could be glow plug issue.
Old June 23rd, 2012, 17:42   #6
saucer
Did you find a source for a new QA?
saucer is offline   Reply With Quote
Old June 23rd, 2012, 18:07   #7
ba843
TDI(s): jetta 02
I do not and I have not been able to find the IP gasket kit.
Do you have any leads?
Old June 24th, 2012, 03:06   #8
hgsmith
TDI(s): 2003 Jetta
diesel geek has the gasket kit.
hgsmith is offline   Reply With Quote
quantity adjuster p1562 HELP jdbrinkman VW MKIV-A4 TDIs (VE and PD) 12 April 25th, 2013 04:49
Emission: P1562 Quantity Adjuster (N146) upper limit reached NutnBolt TDI 101 3 March 20th, 2011 18:26
P1562 quantity adjuster upper limit reached?? help mk2 cosworth TDI 101 3 October 28th, 2008 09:40
Quantity adjuster upper limit reached Deezel76 OBD Scanners 2 April 16th, 2006 20:15
DTC code 17970 Quantity Adjuster upper limit reach clukich VW MKIV-A4 TDIs (VE and PD) 2 November 16th, 2003 05:27
Page generated in 0.14464 seconds with 10 queries
[Output: 82.15 Kb. compressed to 70.73 Kb. by saving 11.41 Kb. (13.89%)]
