Old June 14th, 2012, 13:46   #1
n1d0n
Default p0544 Sensor 1 for exhaust temp bank 1 (G235)
Good day everyone.
I have done a lot of research but am Still trying to get more information.
I have a check engine with a glow plug warning light that is on now and I got the car scanned and I got the p0544 sensor 1 for exhaust temp bank 1 G235 code twice and from what I've seen so far it comes up twice for everyone for some reason..
I have found that the G235 sensor is part number 03l-906-088-l but I want to make sure if someone could actually confirmed that this is the right part number for that Check engine that would be really appreciated..
I am not sure if I am allowed to post a link like this but on that site theres a schema and I was wondering witch one is the right one for the G235 sensor
http://www.jimellisvwparts.com/showA...ssembly=742271
Thanks everyone in advance.
Marc
n1d0n is offline   Reply With Quote
Old June 15th, 2012, 04:26   #2
n1d0n
Bump. Can anyone help?
Old June 15th, 2012, 14:31   #3
n1d0n
Do I need to provide more information or is it just something that hasn't been done often?
Old June 15th, 2012, 15:23   #4
STRANGETDI
You might be the first! Keep us posted. Give it some time, some of our experts will chime in....
Chris
CURRENT: 2012 GOLF w/ TECH, 4DR, 6SP MANUAL, 116K miles
OLD: 1999.5 Golf GL TDI,Up'd,.216s,17 OZ Rims,Eibach Pro-Kit&Dampers,TT SS 2.5" Exst. 222,000 - Sold to Rossman83
STRANGETDI is online now   Reply With Quote
Old June 15th, 2012, 19:07   #5
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
Mark,
I'm in the same boat. The "L" sensor looks like the correct one. I've been doing lots of google and tdiclub searches on this and there are not a lot of clear concrete answers on it other than people that had the dealership do it.... so that doens't help me.
Told my dealership about it after the car cut out while passing someone. Had to duck back in before oncoming traffic made it to me coasting helplessly. Normal acceleration and it was back again:no code. Next day the ol lady borrows my car cause her Yaris spit the water pump. She told me the code started, but no issues with the car.
Result of scan: P0544 code for G235 sensor pre turbo temperature sensor. Called dealership: they won't tell me if it's a warranty item or not until THEY hook it up and read it. $50 later, they give me P0544 and tell me it's not under warranty. Gee, thanks. They also called it an exhaust "pressure" sensor and pointed to a sensor to the left of the valve cover with 2 hoses coming off it. I'm sure that's the exhaust pressure sensor, but that ain't what the code is!
Have you looked at this thing? I can BARELY feel it from the top of the engine reaching around the valve cover on the passenger side of the turbo. I got underneath and dropped the passenger drive shaft. I can barely make it out up there... it will definately need the DPF yanked to ever get to it.
Hoping this isn't hijacking since we're both looking for answers: does anyone know how to test this thermocouple? Is it an RTD or a J/K sensor generating a mV signal? can I still test the sensor from the connections with a multimeter? and uuuuuuh... where is that connection again??
-09 VW TDI Loyalty Edition, DSG, FrostHeater, Black, lightened exhaust,snappier than stock, only air goes in, all exhaust goes out. 77k miles, build date 06/08
-Bunch of Cummins and various other diesel creatures lurking about the dooryard.
DZL_Damon is offline   Reply With Quote
Old June 15th, 2012, 20:08   #6
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
FYI Post I found from NutsnBolts:
DPF temp sensors 2, 3 and 4 are labelled in the Bentley on Page 26-10. G495 should say sensor #3, but in my book it was labelled as #2. Temperature sensor #1 is located in the exhaust manifold. Here's the part numbers:
G235 Temperature sensor #1, black connector- 03L 906 088 L
G448 Temperature sensor #2, orange connector- 03L 906 088 T
G495 Temperature sensor #3, brown connector- 03L 906 088 J
G648 Temperature sensor #4, post DPF, orange connector (same as #2)- 038 906 088 G
Old June 15th, 2012, 20:36   #7
n1d0n
Thanks DZL for that information.. I actually got the part number from there too but the place where I thought the sensor was is just before the turbo.. but again I am not sure that's why I was hoping that someone could show a diagram or confirm with the one I have put in my first post.
Old June 16th, 2012, 11:14   #8
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
n1d0n: I'm not sure if you scanned with an OBD scanner or VCDS, but my VCDS did in fact say "Pre turbo temperature sensor". I know that's not a lot of confirmation. I found a post somewhere else of what the blocks were for VCDS to monitor to confirm/deny if it's the right one. I will do this as soon as I put the axle back on and take it for a ride and let you know. if the pre turbo sensor is pegged at 930*C, then I know its the impossible to reach sensor. And with that, I'll have to remove the entire exhaust/emissions system just to GET to it!
Old June 17th, 2012, 09:02   #9
n1d0n
Ok thanks a lot again for all the help and if you have time and only of you want to, take a picture of the location of the sensor one it's
Accessible it will difenetely help other people and I will difenetely do the same if I do it but for some reason when I cleared the code it still hasn't come back yet and all the power came back.
Old June 18th, 2012, 19:31   #10
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
I just got in from trouble shooting. The exhaust temperature sensors are mounted right on the firewall by the battery (closest to the engine). Under the aluminum wrap is a orange (top) and black (bottom) connector. I found this by doing enough wiggling of the wires from under the car holding the impossible to reach G235 pre turbo temperature sensor. The G235 is the black connector as one of the links before stated. It's directly below the orange one in this picture (which is the pre filter or post turbine sensor). The aluminum protective cloth is removed here. Pull straight out on the whole unit and they come out of their clip. Insert a small screwdriver in the back notch and lightly push down on the handle as you easily slide the connectors apart.
On VCDS under Engine blocks, go to block 99 (at least for my 09 TDi) and you will see the pre turbo temp sensor and the pre filter temp sensor (thats the orange one). My Pre turbo sensor was pegged at 930*C while the other read 18*C (car off and cold).
I swapped the 2 connectors to verify my sensor was dead and not my connections to the ECU (Had to shave a small tit off the orange sensor to allow it to plug into the black). Sure enough, the readings switched. So I now know my G235 sensor is done. I also tested resistance across the 2 wires to the sensors. My good one (orange) would give a resistance reading for a minute, then go like it was open. I assume this is because these are J/K sensors that produce a mA or mV signal vs and old school RTD. The small induced amperage from the multi meter in resistance mode caused it to eventually act like it was open. If you let go of the meter for a second then touched the connectors again, it would show some climbing resistance, then go open again.
It would not do this on the bad sensor.
So, now it looks like I'm yanking the DPF to get to this thing for certain.
EDIT: I got pictures, but they don't do much good. If you're under the car, look along side the driver side of the DPF downpipe and you will see a wire coming out under the turbine. It has a 90* steel tubing bend with the wire run in it, then the wires run down. My pictures are so zoomed in you can't really tell what you are looking at. You do not have to remove the axle to see it, set your head just a little aft of the axle and look up there with a good flash light.
Old June 19th, 2012, 04:49   #11
n1d0n
Wow thanks for all that information and I am pretty sure that I've seen that wire when I did an oil change last week but I'll look again for the time being the issue didn't come back yet and I really don't understand why. I really hope that it will help other people to find it so that they can save a lot of money. Dealer wanted 360$ for that sensor and you can have it online for 108$. I can't even imagine what they would charge to do the job.
Thanks again and if the issue comes back for me I will also document it.
Old June 21st, 2012, 04:21   #12
n1d0n
I have also logged block 99 this morning on my way to work and the thing is all over the place. It is reading ok but when I barely press on the accelerator it shows 930 and sometimes when I put the pedal to the floor 1 time out of 3 it will start climbing normally then hit 930 until I let go.
Not to sure how to troubleshoot this?
Does anyone have any ideas?
Old June 24th, 2012, 19:12   #13
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
Got mine off today. I see how mine failed. This EGT probe has a perforated cage (like a muzzle break on a machine gun) around a small element in the middle that appears to be made of a type of ceramic. Mine on the G235 sensor was broken in 2 with a piece hanging off the main piece. All 3 of the other sensors had a solid piece in the middle. I bet with your flickering like that it is cracked and in the process of coming off completely....
FYI for people that have gone as far as I have and have torn the DPF and EGR filter down... the G235 sensor is NOT left hand thread. It has the notches on the nut where your 17mm wrench goes on it (like an propane or acetylene bottle), but it is NOT LH thread.
Oh yeah... have fun taking that dang DPF out without dropping the subframe. It comes out, but BARELY. You will have to add a little clearance on the aluminum heat shield that is running through the exhaust tunnel. Taking the O2 sensor off the top helps give a hair more clearance as well. After lots of wiggling, swearing, and speaking to our Lord a few times she finally came out. No problem to reach up there to spray a little PB Blaster on the G235 threads.... have a choice beverage (or Diet 7up as an old captain I knew used to always joke about), then pop it right out. I snipped the wire so I could put my box end on the nut just to be safe.
I plan on doing a write up on how to do this when I'm finished. I've been taking pictures, but when I re assemble I'll take better ones so people don't have to shoot in the dark so much on this.
Old June 25th, 2012, 04:11   #14
n1d0n
Wow so you really to remove that dpf? Ouch that's a tasks.
Thanks a lot for all that information. Where did you order your sensor?
The best price I found was
105$ but I am not sure if they ship to Canada.
Old June 25th, 2012, 19:34   #15
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
I got it from the jim ellis site.... $148 after shipping. Still not here... looks like tomorrow it will though.
I think any of those sensor would work (I proved the pre filter one did). I think the only differences are the color connectors, length of wire, and if they have slightly different nubs to avoid accidentally plugging one into the other.
I don't know why VW chose to use such rickety sensors. EGT Sensors I've installed on other diesel engines are solid and are fully protected j/k thermocouples. This one is delicate and lightly protected from FOD or heavy vibrations. I supposed it is more reactive than a fully covered one... but at what expense??
G235 EGT Sensor Replacement Procedure walt_mink VW MKV-A5 Golf/Jettas 34 June 18th, 2016 16:34
wanted broken exhaust gas temp sensor smartuki Private TDI Items for Sale/Wanted 0 June 3rd, 2012 17:41
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235): Circuit Malfunction (Help!) Jeffmx5 VW MKV-A5 Golf/Jettas 6 December 12th, 2011 15:36
Coolant temp sensor vs. fuel temp sensor Jimwsea TDI 101 0 May 16th, 2006 06:54
Exhaust Gas Temp or Turbine Inlet Temp gauge Mike Morriss VW MKIII-A3/B4 TDIs 2 April 9th, 2004 00:15
Page generated in 0.15723 seconds with 10 queries
[Output: 130.67 Kb. compressed to 109.59 Kb. by saving 21.09 Kb. (16.14%)]
