Old June 12th, 2012, 19:47   #1
firehawk618
Fuel Economy: unknown, will track on fuelly
Default Replaced my A/C compressor clutch WITHOUT pulling the compressor.
I recently acquired my car and right away noticed that part of the air conditioning compressor was missing. The nut had been lost off the hub which caused part of the clutch to disappear.
I ordered a new clutch assembly on ebay and I must say it's top notch. It sure appears to be OEM and even has vw cast into the electrical connector for the coil.
I managed to replace this without removing the compressor.
All I did was jack the car up, my whole plastic belly pan has been missing so I didn't have to remove that but most of you will.
Grabbed some c-clip pliers and removed the clip that retains the bearing / pulley. Next took 2 long screwdrivers and carefully worked the pulley back and forth and it came off fairly easy.
Next: removed the c clip holding the coil to the compressor and slid it off.
Just do the opposite to re-install.
I honestly don't see where the issue is with space? I can see there being an issue if you end up using a puller but mine came off pretty easy. Gentle back and forth with the 2 screwdrivers.
A/C works great! I was hoping the fan module and charge were good. Today I found out they were.
New: 2006 Jetta TDI, M5, tune, base model. Swapped in highline cluster, CCM, CECM, puddle light mirrors, MFSW, RCD510. To install: rain sensor & parcel shelf with sunshade.
Old: 2003 Golf M5, Malone Stage 3, PP520's, .658 5th gear, Stock early ALH clutch, FIS cluster, W8 overhead console, Windows up/down via remote, Trailer hitch.
firehawk618 is offline   Reply With Quote
Old June 13th, 2012, 08:02   #2
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
The hardest part for most is finding a set of snap ring pliers that will work in that space. Most 90 degree pliers don't have a deep enough reach to get to the snap ring.
Well done!
-Rich
574,500 miles now and counting...25,500 until cluster swap!
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old June 14th, 2012, 13:28   #3
firehawk618
Edit:
I didn't realize it had to be shimmed. Today I heard a funny noise and noticed the clutch was turning even though my A/C was off.
I pull off the clutch hub and it had been HOT!!!
I cleaned it up, shimmed it and ran A/C for 1/2 hour, so far all is good.
Beware, you must shim the hub.
2 years post rebuild my AC compressor died(bearings), How about electric compressor? josh8loop VW MKIV-A4 TDIs (VE and PD) 6 January 9th, 2012 18:54
Mechanic friend replaced AC Compressor clutch wont engage Abishop TDI 101 18 June 28th, 2010 13:20
Just replaced compressor and drier.Did I put too much 134a in? TDIfarmer TDI 101 6 August 15th, 2009 05:45
WTB MkIV AC Compressor clutch or trashed ac compressor (with good clutch) Ironforger Private TDI Items for Sale/Wanted 0 December 1st, 2007 17:24
Follow-up: Has anyone replaced A/C Compressor? tdibigd VW MKIV-A4 TDIs (VE and PD) 1 June 11th, 2004 20:48
Page generated in 0.12755 seconds with 10 queries
[Output: 59.95 Kb. compressed to 54.53 Kb. by saving 5.42 Kb. (9.04%)]
