Old June 9th, 2012, 02:33   #1
fredrik-wahlgren
Default Passat 1,9 tdi 1999. Problems.. Fuel?
Hi I have recently purchased myself a VW Passat 1.9 tdi,
110 BHP 1999th The car dies without warning,
sometimes after a few hundred meters and sometimes at 1 mil.
After it dies, it is hard to start but after a while (few minutes) then start again.
Then it will run as normal for a little while then it dies again.
Does anyone know what the problem might be? Can it be fuelrelated?
Grateful for all answers.
fredrik-wahlgren is offline   Reply With Quote
Old June 10th, 2012, 04:34   #2
fredrik-wahlgren
Default Passat 1,9 tdi Help me...
Then it will run as normal for a little while then it dies again like I turned the key.
Old June 10th, 2012, 07:05   #3
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Check the fuel filter as a first and inexpensive start, it may be clogged up.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old June 10th, 2012, 09:23   #4
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
He also could have a lift pump going. Go where it is quiet and have someone turn on the key, but not start the car. You should be able to hear a whirr of something under the back seat area. If it failing it might not make any noise. But as Tony says, go fuel filter first. Don't buy any thing off the rack. Get a good quality one.
2015 Golf SE TDI with DSG, 50k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old June 10th, 2012, 09:39   #5
johnboy00
Here's a good thread to check out:
http://forums.tdiclub.com/showthread.php?t=199398
John
2005 Passat Wagon
1999.5 Golf
johnboy00 is offline   Reply With Quote
Old June 10th, 2012, 10:11   #6
fredrik-wahlgren
I have changed the fuelfilter, I noticed that it had punctured one of the fuel return hoses between the injectors. Could this be the reason for my problem?
Old June 10th, 2012, 10:12   #7
fredrik-wahlgren
thanks I noticed that it had punctured one of the fuel return hoses between the injectors. Could this be the reason for my problem?
Old June 10th, 2012, 10:12   #8
fredrik-wahlgren
Thanks I noticed that it had punctured one of the fuel return hoses between the injectors. Could this be the reason for my problem?
Old June 10th, 2012, 10:17   #9
fredrik-wahlgren
Default Where is "relay 109" on my passat tdi 1999??
Enyone know where is this relay? Thanks
Old June 12th, 2012, 01:04   #10
fredrik-wahlgren
This is the 110 hp engine, I dont think there is an diesel forepump? It is a dieselpump in the engine driven by a camshaft... Or I might be wrong.?
Old June 12th, 2012, 01:06   #11
fredrik-wahlgren
Iv changed the filter to a new one, have also changed the hoses between the injectors and pump.
Old June 12th, 2012, 02:07   #12
fredrik-wahlgren
Default Passat -99 Where are the relays? 373, 219
Anyone knows where they are, where are they located on the car?
Reley : 373 fuel relay?
Relay : 219 data controller?
tdi 110 bhp engine 1999
Old June 12th, 2012, 09:00   #13
fredrik-wahlgren
The car is still not working... I changed the hoses betwen the injectors, It was NOT working
Old June 12th, 2012, 09:10   #14
fredrik-wahlgren
I just bought my passat tdi, 1999 and its not working. The car dies without warning,
Iv change fuel filter, hoses to injectors. The car is still not working...
My local vw dealer told me to by relay 373 and 219. I belive it is the same typ of relay as "relay 109" on anouther cars?
Old June 12th, 2012, 09:32   #15
fredrik-wahlgren
Default passat trouble code 00550 (Start of injection - control)
Hi I have purchased myself a VW Passat 1.9 tdi,
When I test it on vag computer this code shows..
I changed fuel filter and the hoses between the injectors.
1999 Passat Auto box problems XpatTech VW B5 Passat TDIs 1 July 28th, 2011 07:56
FS: 1999.5 Golf TDI with mech problems in Columbus, OH eigers TDI Cars for Sale/Wanted 26 March 20th, 2009 07:50
05 Passat TDI having weird problems (hard to tell if fuel-related) ybiofuels Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 17 October 25th, 2006 20:48
1999 Jetta TDI Engine problems ktronind TDI 101 6 October 17th, 2003 12:24
Surging problems with early 1999 TDI HELP!! Curious Chris TDI 101 6 November 22nd, 2001 18:30
Page generated in 0.25407 seconds with 10 queries
[Output: 123.35 Kb. compressed to 102.95 Kb. by saving 20.40 Kb. (16.53%)]
