Old June 8th, 2012, 14:16   #1
werewolf
werewolf's Avatar
Exclamation code P0236?
Just pull a code P0236 and P0238 what do i need to change or look at?
Any problem driving with this code?
Bob:
Jetta's 03 & 04 TDI (GLS)
Golf 04 TDI (GL)
New Beetle 03 TDI (GLS) & Looking!
werewolf is offline   Reply With Quote
Old June 8th, 2012, 14:25   #2
oilhammer
oilhammer's Avatar
Look here:
http://www.bentleypublishers.com/tec....dtc.table.htm
oilhammer
www.cardocautomotive.com
Help out the TDI club raffle car! :http://forums.tdiclub.com/showthread.php?t=362827
Old June 8th, 2012, 14:31   #3
werewolf
werewolf's Avatar
I see its a Turbocharger Boost Sensor looked on IDparts can't seem to find one.
And can you tell me where its located.
Bob:
Golf 04 TDI (GL)
Old June 8th, 2012, 14:39   #4
werewolf
werewolf's Avatar
Is it on top of the intercooler? MAP Sensor ?
Bob:
Golf 04 TDI (GL)
Old June 11th, 2012, 04:59   #5
oilhammer
oilhammer's Avatar
You've skipped a few diagnostic steps there. What does the ECU see the boost as? MAP sensors rarely fail, you may have some other issue.
oilhammer
04 Jetta BEW Fault P0236 yatzee TDI 101 7 October 24th, 2011 13:29
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent Fuels & Lubricants 4 February 21st, 2011 04:21
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent VW MKIV-A4 TDIs (VE and PD) 5 February 18th, 2011 14:39
P0236 + P0237 = limp mode (searched, been there done that) mk4st3 TDI 101 2 July 29th, 2010 06:52
P0226 Throttle Pedal code went away and was replaced with a glow plug code. Fixed. thordehr VW MKIV-A4 TDIs (VE and PD) 0 June 6th, 2010 21:11
Page generated in 0.13710 seconds with 10 queries
[Output: 69.19 Kb. compressed to 60.71 Kb. by saving 8.49 Kb. (12.27%)]
