Old June 12th, 2012, 10:03   #61
keaton
keaton's Avatar
TDI(s): 2005 Mk5
Originally Posted by Fix_Until_Broke View Post
keaton - thats pretty cool.
If we know what frequency the bus runs at and what node addresses the turbo actuator and ECU are, the rest is easy(ish). Record all can messages on the bus and pick out the messages to/from the actuator over a wide range of commands to get a feel for the data range and resolution of the messages and if there are any enable messages or checkup bits that need to be set.. The controller (yet to be designed) then just needs to take a physical input (from N75 command) and spit out CAN messages (which is the easy part).
iirc CAN runs at 250kbs & 500kbs... i would have to go back and look at the code header files.. I wanna say 500, i think that what i'm running at in all my stuff...
if someone has a CAN based controller they can send my i can start working on it. tried to do this once before the the shipping was like $60+...
also got a bunch of Attiny167 with build in LIN support & a munch of CAN chips.
2015 MK6 Jetta S TDI w/DSG
2005 Chevy Corvette, 1-7/8 long tube headers, 3" Catless X-pipe, NPP Dual mode mufflers, tuned.
1996 Chevy Silverado, Headers, tuned
1960 El Camino (project)
keaton is offline   Reply With Quote
Old June 12th, 2012, 13:03   #62
chapelhill
If eventually the ecu is not going to be used for all the control strategy (probably more relevant to two turbo set up), then if we use boost to give some feedback, how is the boost signal to be processed. When logging boost, emp and AFR using a logger at 50 samples per second it is easy to see that the instantaneous boot pressure fluctuates by around 10% on 2260 at full boost, and a 65mm compressor wheel had nearly double that. As far as the control system is concerned this is noise.
I am not sure how the ecu deals with that, either through the I element of the PID, or if there is some other pre processing of the signal. Indications are that we may have substantially higher fluctuations than OEM.
As I have pointed out earlier I have seen some instances of boost instability, when pushing the performance envelope of the 2260, but to eliminate it has taken a much higher reduction on boost limits than I would have thought necessary.
Regards
Chapelhill
Seat Ibiza 03 PD130. FMIC,2260Vk Turbo, Miltek turbo back exhaust.(working on someMORE!)
Mercedes E280CDI for the wife!
chapelhill is offline   Reply With Quote
Old June 12th, 2012, 19:33   #63
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
J1939/11 and 15 run at 250k but that's primairly for off highway vehicles and diesel engines. I don't remember the on highway standard, but I'd bet it has the same physical layer, just a different message structure. CANOpen can run 125, 250, 500, 1M, etc but 250 and 500 are the most common that I've seen.
It sounds like the CAN based actuator is not the most useful one due to it's orientation.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old June 13th, 2012, 06:43   #64
Scott_DeWitt
Scott_DeWitt's Avatar
Wouldn't a remote mounted actuator be feasible? Mount actuator in a more convenient location and then run a cable from actuator to turbo.
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old June 13th, 2012, 06:52   #65
Rub87
Boost input is passed trough a PT1 filter, the time can chosen in the dataset
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old June 13th, 2012, 07:16   #66
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
That's a great idea Scott!
Old June 13th, 2012, 08:28   #67
JFettig
JFettig's Avatar
^exactly what I was thinking.. a brief look at my 2056VK, it would be super easy to extend.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old June 13th, 2012, 18:23   #68
Fix_Until_Broke
Remote mounting and cable actuation opens a lot of doors for actuator options. Heck, I'd like to have that on my vacuum operated actuator for easier VNT adjustments
There are millions of gasser cruise control actuators that could be used. A large number of industrial controls with position feedback options are available.
So if it's this easy, why don't the OEM's do this? Not knocking the idea, but it seems too simple to have not been thought of before.
The spring on the actuators is pretty stiff so you'd probably need a guided cable assembly, one that would be relatively low friction and take the heat. A shifter cable would be a great example - guided for push/pull, takes a lot of force, smooth/low friction - I'm not sure if it would take the heat or not?
Tangent thought - Attention vendors - build a remote actuator kit where the cable mounts to the existing actuator bracket on the turbo and you can remote mount your existing VNT actuator on the firewall or valve cover or wherever you want for easy adjustments. Sell it for $100 and you'd have people beating your door down to buy it.
Old June 13th, 2012, 18:40   #69
john.jackson9213
TDI(s): 1996 B4V
Just a thought, deliver a solution for $100 and you would not cover the customer support costs.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old June 13th, 2012, 20:05   #70
Fix_Until_Broke
My suggestion was off topic of this thread - sorry about that.
A cable, one bracket and maybe a jam nut or two should be able to be sold for $100, make a decent profit and cover customer support.
This is not a solution for the EDC15 ECU to drive the newer actuators discussed on topic in this thread.
Old June 13th, 2012, 22:51   #71
Rub87
It has been done driving such an actuator, ask T3-UN1 ( I think his nick was like that) then I would use the precontrol maps of a car originally equipped with such an actuator as starting point, as 100% means there vanes closed, while in edc15, 80% already means vanes to the stopscrew.
now one would need to use the N75 map also for stopscrew setting, or be careful with it, as when you command the actuator to pos x and it it his the stopscrew before reaching pos x it will stop working I think
Good and cheap PWM actuator can be found on the KKK bv50 etc from early audi 3l, turbos fail often so actuator should be cheap, ideally to be used with the cable idea
Old June 14th, 2012, 00:16   #72
brum
Fuel Economy: from 5l/100km to 6.5l/100km
Originally Posted by ryanp View Post
The only situation where the factory clocking would nearly work is with a top mounted turbo and all custom pipework and oil lines, might need a funky layout to work well in a packed bay too.
VAG GTB's have the CAN-BUS actuator AFAIK
About the CAN-BUS actuators on VAG GTB turbos - I have two and they are with 5 pins, two directly wired to the motor and 3 wired to the position sensor. So these are for sure type 1.
brum is offline   Reply With Quote
Old June 14th, 2012, 00:45   #73
Rub87
not much to do with these as the motor controller aint there =) better take one off MB or volvo etc
Old June 18th, 2012, 17:32   #74
Digital Corpus
Digital Corpus's Avatar
I case CAN operation is still on the table, I had someone point me over towards Microchip's PIC32 line of MCUs for a project of my own. They have up to 2 CAN busses per chip, though their compiler is where they make the money and there isn't a simple alternative.
Keep in mind that running a remote cable ot the turbo needs to be able to withstand a tremendous about of heat and the cable length can influence the maximum bandwidth. Shielding the cable in a sheath of metal weave can help with both.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | DC Stg IV Clutch w/ 14 lb flywheel | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old June 19th, 2012, 06:12   #75
yatzee
yatzee's Avatar
TDI(s): see sig
Subscribed
2005 C230 6 spd, 1994 E280 5 spd, 1991 405 mi16, 1986 190e 2.3-16. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
GTB2056VL, PWM, CAN or other? Alcaid TDI Power Enhancements 4 November 13th, 2010 14:57
Direct bolt on turbo? gor131-x TDI Power Enhancements 13 November 15th, 2008 09:00
VNT17 Turbo (gt1749vb)-Direct Replacement for VNT15 LiquidBlackDZL Private TDI Items for Sale/Wanted 4 March 12th, 2008 17:42
Questions on Suzuki Swift DDIS (Direct injection -Turbo with intercooler) vravi General Automotive 4 March 12th, 2007 02:50
1.9L non-turbo direct injection? piper106 Other VW Group TD(I)s 4 December 2nd, 2002 04:59
Page generated in 0.17952 seconds with 10 queries
[Output: 144.15 Kb. compressed to 122.46 Kb. by saving 21.69 Kb. (15.05%)]
