Old June 11th, 2012, 09:42   #46
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
Fuel Economy: approx 50
wow that's some pretty good info, I assume that's a matlab affair?
(my controller is nowhere near that complex lol). That said it's easy math to calculate a slope and proximity to setpoint so i'm sure dampening could be improved somewhat easily
What i'd probably do is have a subroutine that activates after a certain interval (after a new boost sample has taken place) and does a subtraction of the last measured boost sample from the current one, and that's your slope over the period (I know technically it's linear and boost could theoretically dip in that period, however with a high sample rate that becomes less important). You can then use that slope as a factor in how much you want the actuator to react against the pi terms etc can't ya. Typical D.
Dakta is offline   Reply With Quote
Old June 11th, 2012, 09:50   #47
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
It was done in GT-POWER but similar things could be done in Matlab as well. My model had both detailed engine- and vehicle physics so I can do simulations of the engine going through transient load- and speed changes as well as the accelerating vehicle accounting for driveline friction, rolling resistance, inertia, drag, road gradients (if desired), etc.
Exactly what I did! Except I'm using engine load/speed as the input signal for the PI and boost pressure for the D placed on the feedforward.
Old June 11th, 2012, 09:57   #48
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
fair does, i don't use matlab but i did once have a bit of a sniff at it, thought it might come in handy though i'm anything but a scientist lol
so whats with these electronic pwm actuators, can't they be driven with the same signal as goes to the n75 valve, or do they need a different frequency/voltage? surely we're talking some simple conversion here.
I'd be tempted to forego the controller and build an adapter board that can listen to the n75 signal perhaps nd replicate it in a format the electronic actuator can use.
Old June 11th, 2012, 10:06   #49
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Yes, the above was a bit of a tangent considering you were talking about your trials and tribulations of building your own controller. Apparently from posts above, depending on the actuator used you can directly employ the same PWM signal used to drive the N75, so long as you have a PWM and not CAN actuator. Some actuators even use the same 140 Hz base frequency, so it should be amazingly simple Some have feedback of vane position but the early ECUs have no use for this information.
Do it and I'll be a customer!
Old June 11th, 2012, 12:22   #50
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
yes, the above was a bit of a tangent considering you were talking about your trials and tribulations of building your own controller.
Don;t get me wrong, i love discussing it - there's not many people to talk to about it on the rover forums, so it's all been solo so far (which, as a non-electrical engineer or engineer in any capacity has led me to crash frequently lol)
It's nice to see it getting there though
if there's enough people wanting to fit these vnt's to justify the costs of producing a design then i'd give some serious consideration - i've re-read the thread, it seems theres several pwm actuators so i'd have to plan on how to make it all interoperable (i think thats the word). Probably can't do much about the canbus right now, though some of the microcontrollers ive used in the past do have CAN facility, i'd have to do my research in that area to be able to use it though.
Old June 11th, 2012, 12:24   #51
ryanp
ryanp's Avatar
As usual Kris, i can donate an E-actuator to help things along, i have quite a few including early types.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old June 11th, 2012, 16:24   #52
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
i'll shoot you an email Ryan, i've got to write you a response anywho :P
I am not 'waist deep' in the vag scene, so would something like this be realistically useful?
Old June 11th, 2012, 16:42   #53
snakesausage
snakesausage's Avatar
So ryan, what type e-actuator are on the GTB turbos that you source for your kits, the type 1 (I am assuming the early type) or the type 3 CAN bus?
I do agree for a control perspective that the E-actuator makes a vacuum actuator look old tech but rarely would it be possible to install the turbo in the correct orientation so alterations to the bracket at least would still be required.
Why would it be not possible to install the turbo in correct orientation to use the e-actuator? Is it interference with the exhaust header or some other part of the car or some other reason?
Edit: I see above that it is clocking of the turbine/CHRA but since you are making the header cannot the GTB factory clocking be preserved?
South Bend Stage II Endurance : SEAT León Cupra R RAB : E-Code headlights : TT LCA bushings : Koni FSD : 11mm pump : 5.5L Washer Fluid Reservoir : Vented Passenger Wheel Well Liner : 03' Cup Holder Update : Aspherical mirror : Sunglasses Holder : Toyo extenza H/P 215/55R16 tires : 250,000 miles : VCDS : Metalnerd TB Tools : Bentley
snakesausage is offline   Reply With Quote
Old June 11th, 2012, 19:58   #54
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Someone should start a requirements/specifications list of what we want this thing to do.
1) Use existing EDC15 PWM as input
1a) Details needed about what this is
2) Drive which actuator?
2a) PWM Input
2b) CAN Input
2c) Stepper Motor
3) Power source?
4) Load requirements?
5) Actuator feedback?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old June 11th, 2012, 20:07   #55
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
That'd be a good idea.
My initial idea would be to use a small low spec microcontroller to analyse the input signal and reconstruct a usable signal at high frequencies (talking about being able to recalculate signals within 1-2 cycles, including the sample time)
I have done something very similar once when trying to find a tacho signal for my rover, it didn't have a W terminal on the alternator, so i used the dash signal, that turned out to be a square signal with the tacho readout represented by it's frequency so I converted that to a more conventional signal where the frequency was fixed and the duty was modulated to represent the value.
I think I need to read up on how these actuators actually work. Direct PWM is easy enough but i think one or two types are a bit more complicated.
A full spec would be nice tho. something does however bother me -
if its such a straight forward problem why has it not been done?
either it's not a very big problem, or it's a BIG problem
Old June 11th, 2012, 20:14   #56
Fix_Until_Broke
At the moment it seems like a moving target - if we're serious about building something, we should first figure out what it is that we want to do.
Pick an ECU
Pick an Actuator
Analyze both
Design interpreter between the two
I personally like CAN based controls because there is so much you can do with them - but you have to know what you're doing (which I really don't).
Old June 11th, 2012, 20:18   #57
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
That's why i'd do that last. I've always wanted to get into the CANBUS scheme because I've always thought it would be nice if I could modulate the fuel quantites on vp44/vp30 systems 'tuning box style' (but perhaps in a more controlled and adjustable manner).
CAN would be a vastly different circuit than another controller, and if it was all included in one design you'd probably have something that cost a fair bit, so I'm in agreement of sorts that you want to pick one route through the problem, solve it, and if needed crack on with the next.
The CAN system i think would be the hardest, because there will need to be some protocol analysing and disassembly required too no doubt. Have to work out what 'ID' the actuator is listening to, whether it responds to the ecu to confirm 'orders' and all that.
I can give an indication of what my design can do, but i'm not very well informed on actuator types and signals, so i'd have to do some research to decide anything atm
Old June 11th, 2012, 21:31   #58
keaton
keaton's Avatar
TDI(s): 2005 Mk5
I have done some CAN Bus work, PID controller (mainly just PD), lots of motor controller and control systems work as well i hacked a BMW 402/403 & 413/504 ECU... so this is right up my allie
got a BSE in Electrical & Robotics
one of my CAN videos rev1
http://www.youtube.com/watch?v=2QuRBQzGs-c
My current CAN Library covers all 11-bit PIDs, working on adding all 29-bit PIDs
rev2 is much snappier, cleaner video + GPS and other goodies... soon to be HD & for sale :-D
let me know how i can help
i just haz no diesel to hook it up to for testing :-(
2015 MK6 Jetta S TDI w/DSG
2005 Chevy Corvette, 1-7/8 long tube headers, 3" Catless X-pipe, NPP Dual mode mufflers, tuned.
1996 Chevy Silverado, Headers, tuned
1960 El Camino (project)
keaton is offline   Reply With Quote
Old June 11th, 2012, 21:59   #59
Fix_Until_Broke
keaton - thats pretty cool.
If we know what frequency the bus runs at and what node addresses the turbo actuator and ECU are, the rest is easy(ish). Record all can messages on the bus and pick out the messages to/from the actuator over a wide range of commands to get a feel for the data range and resolution of the messages and if there are any enable messages or checkup bits that need to be set.. The controller (yet to be designed) then just needs to take a physical input (from N75 command) and spit out CAN messages (which is the easy part).
Old June 12th, 2012, 02:36   #60
ryanp
ryanp's Avatar
The only situation where the factory clocking would nearly work is with a top mounted turbo and all custom pipework and oil lines, might need a funky layout to work well in a packed bay too.
VAG GTB's have the CAN-BUS actuator AFAIK
GTB2056VL, PWM, CAN or other? Alcaid TDI Power Enhancements 4 November 13th, 2010 14:57
Direct bolt on turbo? gor131-x TDI Power Enhancements 13 November 15th, 2008 09:00
VNT17 Turbo (gt1749vb)-Direct Replacement for VNT15 LiquidBlackDZL Private TDI Items for Sale/Wanted 4 March 12th, 2008 17:42
Questions on Suzuki Swift DDIS (Direct injection -Turbo with intercooler) vravi General Automotive 4 March 12th, 2007 02:50
1.9L non-turbo direct injection? piper106 Other VW Group TD(I)s 4 December 2nd, 2002 04:59
Page generated in 0.19854 seconds with 10 queries
[Output: 151.02 Kb. compressed to 128.25 Kb. by saving 22.77 Kb. (15.08%)]
