Old June 9th, 2012, 03:13   #31
ryanp
ryanp's Avatar
I do agree for a control perspective that the E-actuator makes a vacuum actuator look old tech but rarely would it be possible to install the turbo in the correct orientation so alterations to the bracket at least would still be required.
The actuators fail for fun in some OE situations, Ford being the most common i know of!!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old June 9th, 2012, 05:06   #32
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
That's correct, the biggest advantage in using the modified vacuum actuator is the free clocking orientation of CHRA to suit an non OEM application....
In my case situation is a little different as I can keep stock orientation of turbo and actuator....
Regards, Alex
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old June 9th, 2012, 05:47   #33
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Originally Posted by TDIMeister View Post
Vacuum is fine if you're dealing with only one turbo and an old-tech one at that........
This is very true.. adding a second turbo definitely complicates things..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old June 9th, 2012, 06:49   #34
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Ryan, what prevents an e-actuated turbo from being oriented properly compared to a vacuum-actuated one? Or did I misunderstand?
Old June 9th, 2012, 08:29   #35
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Electronic Actuator has it's fixed mounting position, mostly on compressor housing.
Sure it can be changed by making a custom mounting bracket for a different location, but then you also have to fiddle around with correct basic setting which is not as easy like with a vacuum actuator and stop screw :-(
Old June 9th, 2012, 08:36   #36
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Now I get it. Clocking relative to the turbine/CHRA and compressor is the problem.
Old June 9th, 2012, 08:54   #37
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
http://forums.tdiclub.com/showthread...ctuator&page=2
picture of electronic controler of actuator and many info.
I have Type 1 and 2 in my hand.
Type 2 have PWM input and CAN output for information.
Is good base for Arduino project!
This is VNT boost controler for TD and m-tdi, also tdi with chip modifie without boost control.
http://dmn.kuulalaakeri.org/vnt-lda/
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old June 9th, 2012, 09:16   #38
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Originally Posted by dieseleux View Post
Yes I do remember that thread. But two years later one still cannot just go and buy one - or maybe I've been out of the loop.
Old June 9th, 2012, 12:03   #39
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
Fuel Economy: approx 50
dunno how relevent it is as my vnt is vacuum but I tune rover diesels and there is no vnt solution so i've been having to build my own.
Unfortunately I'm not a fan of arduino, nor did I even know it existed at the time, so I had to go the long route of learning electronics, coding and so forth. Even had to design my own pcb's result is it looks a bit rough -
haven't finished the software but this was an artists impression:
Eventually after a hefty amount of time i've started to see results:
Green line is requested (i intend this to be mappable to either quantity adjuster feedback line or tps so you can base target boost on load) though on that test it was set static. Blue line is actual boost, red line is an unused channel (I sometimes use it to report duty cycle back to laptop so i can check its working).
It uses a very simple mainly proportional control loop though im still working on the control engine. The units are in byte value (i.e what the controller computer sees) rather than real world values i'm afraid so it might not make much sense to you.
here's another log with duty logging enabled:
Not sure if this is of any interest to anyone, but this vnt control has been my 'baby' for about a year now, it's been slow going and i've had more failure than success, but it's getting there. All configs are held in eeprom so technically once my protocols finished it's 'mappable'.
My main aim now is to try and dampen the duty cycle response.
I have wondered how difficult it would be to make it work with an electronic actuator - pwm wouldn't be too bad i dont think, CAN would be harder but some microprocessors i use do have can support so you couldn't rule it out i guess, though it'd need new schematic.
Dakta is offline   Reply With Quote
Old June 9th, 2012, 12:47   #40
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Very, very nice work!
Old June 9th, 2012, 13:08   #41
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
cheers, these days there's quite a few vnt control projects about, but back when I started, there was none so you pretty much 'on your own' lol.
Bit of a scary experience - that 'lda' project linked above is more advanced I think, but i'm not a control engineer at the end of the day, and there was nothing else available for control so I couldn't just sit there, Ihad to do something about it.
PID really blew my head when I first started researching it, I know it's quite simple in theory but turning it all into practice *puts gun to head*
I can't do math
Old June 10th, 2012, 22:31   #42
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Veeerry interesting! Reminds me of work I did in my Master thesis developing a boost controller scheme for 2-stage turbos...
Edit: The answer to your response damping is to have an integrating component of your control system in addition to just a proportional scheme - a "PI" and not just "P" controller.
Old June 11th, 2012, 03:01   #43
dieseleux
dieseleux's Avatar
Some D need at spool time, make spool a little bit slower but add stability at target boost point, after reach this point, D is turn off or reduce.
You need state switch in programming code to change and adapt your algorithm to regulation system. (state switch like: Far lower, Near lower, on regulation, Near upper, Far Upper)
Dieseleux
Old June 11th, 2012, 04:41   #44
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
Thanks....that's interesting.
D is quite easy to implement, integral I have a bit of difficulty with because quite often (when driver is off the throttle etc) the right level of boost can't be attained exactly leading to windup, which could cause instability whilst it winds back down i've been thinking of ideas to avoid this, perhaps having a regulation mode like you say where boost is near setpoint so things like the 'I term' come into effect etc.
Old June 11th, 2012, 08:58   #45
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
One of the things I did was to implement a form of a D-type predictive feedforward that's only active when the actual boost pressure comes within a certain range below- or above the requested value. The idea is that when the actual boost is approaching the requested value, the controller measures the trajectory or slope of the transient boost. If the slope is high approaching the requested value from below, it's a good probability that an overshoot is going to occur. The same is true that if the slope is a large negative value coming from above the requested, an undershoot will likely occur. Below are pictures of the overall schematic of the controller (this is for a WG setup, but a VNT would not be much different). the PI controller in this model has built-in anti-windup. @Dieseleux: As you can see, state-switching was implemented.
Schematic of the feedforward alone:
Signal response:
As you can see, the feedforward reacts faster to open the WG between about t=1.7-1.8 seconds and begin to close it faster after the peak than with simple a PI controller alone. Beyond t=2.6 seconds the feedforward doesn't play a role. Simulations showed large improvements in stability and convergence time of the boost control with properly chosen gains. Edit: obviously you can't have a negative WG open area; the actuator signal was tapped before a limiter, so any negative signal just means zero. For context, t=0 represents a WOT load-step from second gear starting from 20 km/h.
To be clear, a proper controller, especially in the context of a two-stage turbo system, is not as simple as just having a PID controller. Here's a schematic of how BMW controls its 2-stage turbos:
GTB2056VL, PWM, CAN or other? Alcaid TDI Power Enhancements 4 November 13th, 2010 14:57
Direct bolt on turbo? gor131-x TDI Power Enhancements 13 November 15th, 2008 09:00
VNT17 Turbo (gt1749vb)-Direct Replacement for VNT15 LiquidBlackDZL Private TDI Items for Sale/Wanted 4 March 12th, 2008 17:42
Questions on Suzuki Swift DDIS (Direct injection -Turbo with intercooler) vravi General Automotive 4 March 12th, 2007 02:50
1.9L non-turbo direct injection? piper106 Other VW Group TD(I)s 4 December 2nd, 2002 04:59
Page generated in 0.17803 seconds with 10 queries
[Output: 143.15 Kb. compressed to 120.49 Kb. by saving 22.65 Kb. (15.82%)]
