Old February 11th, 2018, 12:48   #136
barteczekk
TDI(s): audi a4
Got new turbo this can work with pwm https://drive.google.com/file/d/1Csv...w?usp=drivesdk
barteczekk is offline   Reply With Quote
Old February 11th, 2018, 13:09   #137
Demon Diesel
3pin should be PWM. Power, Ground, and PWM signal. Some use 4 wires where the 4th is status feedback to ECU.
CAN would be 4 wire. Power, Ground, CAN High, and CAN Low.
VW/Audi (no electronics) style uses 5pin. Motor +, Motor -, Position Sensor Power, Position Sensor Ground, and Pisition Sensor Signal.
Demon Diesel is offline   Reply With Quote
Old February 14th, 2018, 10:16   #138
barteczekk
TDI(s): audi a4
Ok so its pwm. Some one could help edit my edc15p to get right pwm frequency.
Old February 15th, 2018, 09:15   #139
barteczekk
TDI(s): audi a4
No one can help me with this?
Old February 15th, 2018, 12:11   #140
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Looks like you don't have to do much...
Originally Posted by Digital Corpus View Post
To revive an old thread:
I'm not done with my analysis of the various N75 PWM signals yet, but the ECU in my B4 (only know it as a FA ECU, but it's an EDC15V, right?) is capable of alternative PWM frequencies. Our stock B4 produces a 15.5 Hz signal and mine with a AFN tune produces a 300 Hz PWM signal. I've not check out a stock MK IV, but our '02 that was tuned by Leonard (Wild Rose) back in the day produced a clean 300 Hz PWM signal.
This leads me to believe it's reasonable to assume that the PWM frequency is capable of being adjusted in a tune on the newer TDIs. Anyone want to though a tune and see where this is stored?
So, if I've read everything right, all that is needed is a non-CAN controller and a proper wiring harness, no?
Originally Posted by apomiett View Post
We tested the BMW PWM actuator with pulse generator and the working range was ~290Hz to ~310 Hz. Mercedes actuator is supposed to be ~140Hz. Both actuators have same part number so you have to know what car was it from. You can simply swap the cover from BMW ectuator to VW/Audi actuator and it will work with PWM. You will get CEL from incorrect resistance but that can also be disabled.
Originally Posted by struikie View Post
I am running a BMW actuator with PWM @ 300hz indeed...
Johan got it running perfectly...
JW
Originally Posted by ivohi View Post
If anyone interested then I got gtb turbo hella actuator working on my car. It is direct fit because takes pwm with frequency 300Hz like EDC15 outputs.
Hella part number 6NW 009 228
https://www.youtube.com/watch?v=9pZFT1GeIY4
No mods, no hassle
Old February 21st, 2018, 11:17   #141
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
This may turn out to be useful to convert one PWM base frequency to another, eg 140 to 300 Hz...
https://www.banggood.com/Square-Wave...r_warehouse=CN
Old February 23rd, 2018, 04:13   #142
Digital Corpus
Digital Corpus's Avatar
Without knowing the signal requirements though, it is possible to try that board if it cannot source enough current if the electronic controller has the requirement of being driven by the signal. YMMV.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | DC Stg IV Clutch w/ 14 lb flywheel | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old February 23rd, 2018, 04:45   #143
JFettig
JFettig's Avatar
Here is the recipe for making an Audi GTB electronic conversion board:
https://www.pololu.com/product/1394
1J0973733
1J0973833
1J0973722
8d0973822
Jeep: 68087939aa - or use the VW equivalent which is preferred. Jeep connector is cheaper AND comes with wires, a piece needs to be removed for it to fit.
I don't have all the components in front of me to give you exact wiring but here is how it works.
N75 plug, one wire is +battery(T2/1), one wire is 0-12v signal(T2/2) from the ECU, a PWM signal. Add a ground wire to chassis.
+12v batt goes to VIN, the added ground goes to GND.
Put a fooler resistor(1k IIRC) across the two N75 wires so that the ECU is happy
Make up a voltage divider circuit to turn the 0-12v signal to 0-4.5v, that goes to the RX signal. .47v/v is what I used.
The 2x3 header on the JRK has a 5v output, groud, then feedback input - these go to the turbo connector, it has a 0-5v position sensor in it.
feedback: T6/4
+5v: T6/5
gnd T6/3
A and B on the JRK also goes to the turbo - this goes to the motor leads on the servo. Pins 1 and 2
From there, you get to play with the software, I don't know where my settings would be saved.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
GTB2056VL, PWM, CAN or other? Alcaid TDI Power Enhancements 4 November 13th, 2010 14:57
Direct bolt on turbo? gor131-x TDI Power Enhancements 13 November 15th, 2008 09:00
VNT17 Turbo (gt1749vb)-Direct Replacement for VNT15 LiquidBlackDZL Private TDI Items for Sale/Wanted 4 March 12th, 2008 17:42
Questions on Suzuki Swift DDIS (Direct injection -Turbo with intercooler) vravi General Automotive 4 March 12th, 2007 02:50
1.9L non-turbo direct injection? piper106 Other VW Group TD(I)s 4 December 2nd, 2002 04:59
Page generated in 0.15998 seconds with 10 queries
[Output: 93.30 Kb. compressed to 81.30 Kb. by saving 12.00 Kb. (12.86%)]
