Old June 7th, 2012, 10:50   #1
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Default Somebody PLEASE do a direct PWM turbo controller already!!!
With VK turbo swaps becoming more-and-more common, I cringe at being forced to remove the electric actuator and replace it with a vacuum can actuator to get the turbo to work with these engines.
The signal from the ECU to the N75 is already PWM. The VK actuator is already PWM. How ridiculously stupid to communicate those two signals with vacuum instead!?!?!
It's like having an English-speaker wanting to say something to another English-speaker, but having a translator in another language in between. REDUNDANT!!!
Let's do it already. Let's make it a goal to get something done by TDIFest this year. This is $MONEY$ people!!!
Old June 7th, 2012, 11:03   #2
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
Sometimes opportunity doesn't knock, it just sits in the corner waiting to be noticed...
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old June 7th, 2012, 11:04   #3
snadam
snadam's Avatar
Anyone know the PWM frequency of the ECU and the turbo actuator? I suspect there's already something out there that can be used directly or adapted without much trouble. For instance this...
11 GOLF - EURO GTI SHIFT KNOB - GTI REAR SKIRT - GTI DUAL EXHAUST - HUPER OPTIK CERAMIC TINT - OTHER THAN THAT IT'S A RELIABLE CAR, I MISS MY O1' BORA
02 NB - CUSTOM PAINT - 11MM IP - 2.5" EXHAUST - BOSCH .205 - UNITRONIC - BIG BRAKES - SKID & FMJ - KONI FSD & OEM SPORT SPRINGS - HID LAMPS - BILSTEIN PSS9 COILOVERS FOR SALE
snadam is offline   Reply With Quote
Old June 7th, 2012, 11:26   #4
burpod
teh stallionz!!1
burpod's Avatar
i would love to get rid of the n75 and use an electronic actuator for my scirocco swap, since i'm planning on a 2260vk of some sort.. i'll be a guinea pig if *cough* someone wants to do my tuning
82 rabbit AHU 17/22 26psi ported head, 11mm pump, pp764s, franko6 cam, custom ce2 wired, vwmikel tuned
1998 jetta AHU 17/22 26psi pp764s etc
vwmikel tuned
88 scirocco
AHU 2056vl build... delayed...05 jetta tdi & 06 golf tdi
burpod is offline   Reply With Quote
Old June 7th, 2012, 11:27   #5
snakesausage
snakesausage's Avatar
This should be fairly simple but a lot of work.
Is the Frequency of the N75 system and the electo-mechanical system the same?
Is the duty cycle and requested boost of each system the same for both systems or for that matter are they even linear?
South Bend Stage II Endurance : SEAT León Cupra R RAB : E-Code headlights : TT LCA bushings : Koni FSD : 11mm pump : 5.5L Washer Fluid Reservoir : Vented Passenger Wheel Well Liner : 03' Cup Holder Update : Aspherical mirror : Sunglasses Holder : Michelin Defender 215/55R16 tires : 300k miles : VCDS : Metalnerd TB Tools : Bentley
snakesausage is offline   Reply With Quote
Old June 7th, 2012, 11:28   #6
FlyTDI Guy
FlyTDI Guy's Avatar
Beyond just the multiplier, range and scaling may be an issue...
Old June 7th, 2012, 11:30   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Subscribed.
oilhammer
www.cardocautomotive.com
Old June 7th, 2012, 11:38   #8
Growler
Got Soot Vendor
Growler's Avatar
I would think that the vacuum/spring system acts as a buffer of the forces required to adjust the vanes inside a pressurized turbo with a lot of exhaust volume wanting to move the vanes.
I see this needing something pretty robust and or strong(read expensive) to be able to directly compensate for the forces reacting on these vanes.
I also don't see a strong enough linear actuator that is small enough to fit in our compact install area, and be able to hold up to the heat that is nearby in the long term
with that said, someone prove me wrong..
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old June 7th, 2012, 11:42   #9
compu_85
Gadget Guy
compu_85's Avatar
Several models have direct acting servos on their turbochargers. MB uses them and I think the V6 TDI does as well?
-J
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old June 7th, 2012, 11:44   #10
oilhammer
oilhammer's Avatar
The BKW does. Two of them. They use their own paired wire engine communication bus to control them however. May not be able to work the same way.
oilhammer
Old June 7th, 2012, 11:56   #11
Ano
Ano's Avatar
TDI(s): MK1 TDI ARL
Fuel Economy: 58.8
This was a topic on this board for a while
You can`t use the VW actuator because they have a Can signal.
The Mercedes actuator used a PWM.
You can build a Frankenstein bedween Mercedes electronic and VW Mechanic that can work.
It is shown on the vid.
http://www.youtube.com/watch?v=NQ36-fiV3Vk
http://www.youtube.com/watch?v=q0qEY...eature=related
The main Problem ist to adjust the ECU to work properly.
I used the old vacuum actuator because i haven`t so much space left with this turbo.
Best regards Christian
Ano is offline   Reply With Quote
Old June 7th, 2012, 11:57   #12
oilhammer
oilhammer's Avatar
I was just pulling up a V6 CDI Sprinter wiring diagram as you posted that, Christian!
oilhammer
Old June 7th, 2012, 11:59   #13
snakesausage
So these are CAN and not PWM?
Old June 7th, 2012, 12:03   #14
oilhammer
oilhammer's Avatar
Not sure which one you have pictured, but the BKW's turbochargers (V10 T'reg here) have 4 wires to each actuator: power, ground, and hi-low CAN. Pretty simple, but you have to have the ECU to talk to them. The 5th pin is not used.
oilhammer
Old June 7th, 2012, 12:05   #15
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
I will change from vacuum actuator to electronic on my E320 EDC15.
Software architecture for EDC15 used with PWM electronic actuator is already done by OEM ;-)
Dave if you are interested I give you a hint via PM as I don't want to spread this around www yet ;-)
Regards Alex
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
GTB2056VL, PWM, CAN or other? Alcaid TDI Power Enhancements 4 November 13th, 2010 14:57
Direct bolt on turbo? gor131-x TDI Power Enhancements 13 November 15th, 2008 09:00
VNT17 Turbo (gt1749vb)-Direct Replacement for VNT15 LiquidBlackDZL Private TDI Items for Sale/Wanted 4 March 12th, 2008 17:42
Questions on Suzuki Swift DDIS (Direct injection -Turbo with intercooler) vravi General Automotive 4 March 12th, 2007 02:50
1.9L non-turbo direct injection? piper106 Other VW Group TD(I)s 4 December 2nd, 2002 04:59
Page generated in 0.18749 seconds with 10 queries
[Output: 136.41 Kb. compressed to 113.87 Kb. by saving 22.54 Kb. (16.52%)]
