Old June 7th, 2012, 06:33   #1
SheeB
Default Dirty maf with cold climate air filter
So recently I had to replace a defective maf sensor. After removing the old maf and inspecting it, I noticed a very fine layer of sand across the element. I use Mann cold climate air filters, and usually replace them every year (even though I did the CAT air filter restriction indicator mod). I do not have the snow screen though, and I'm wondering if this is an issue? I typically do not drive on sand/gravel roads either.
SheeB is offline   Reply With Quote
Old June 7th, 2012, 08:10   #2
JETaah
Fuel Economy: 53 max, 42 min, average 46
It should not be a problem.
Did you notice any dirt traces on the top side of the foam surround of the filter? If so, it means that the top filter cover was not seated properly.
Do you remove the airbox to change filters? It is easier to get it right that way.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old June 7th, 2012, 10:01   #3
SheeB
No I don't typically remove the airbox when changing the filter but as a precautionary measure, I will replace the filter anyways and remove the airbox this time around. Thanks for the tip.
Air filter extremely dirty after 4000 miles. rexdriver85 VW MKIV-A4 TDIs (VE and PD) 10 April 20th, 2012 18:24
Badly Dirty Air Filter-- Effects on FE and Smoke? Conan TDI 101 6 January 17th, 2011 14:54
check engine light and dirty air filter CheesyRider TDI 101 10 March 23rd, 2010 19:44
Air Filter not for cold climate? superskid TDI 101 12 November 24th, 2008 19:45
Why is air filter only half dirty? bigolddeerhunter TDI 101 27 April 11th, 2006 19:51
Page generated in 0.12911 seconds with 10 queries
[Output: 57.54 Kb. compressed to 52.17 Kb. by saving 5.37 Kb. (9.34%)]
