Old June 3rd, 2012, 12:07   #1
Eliminateur
Question oil smudge in throttle body
Hello,
i was taking a look under the hood with a portable light on my jetta tdi, took out the engine cover and noticed that below the throttle body there's thick oil all smudged down the air pipe and the block itself is "sprayed" with oil (there's droplets like something once blew sprayed oil towards there with force) with the tpicenter looking like below the throttle body itself (there's a circular thingy behind it, it's very hard to see celarly).
any ideas what it is?(or if it's normal)
Eliminateur is offline   Reply With Quote
Old June 3rd, 2012, 12:11   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Wipe the oil off of all the 'thingys' and see if it comes back.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old June 3rd, 2012, 12:18   #3
slamhouse
slamhouse's Avatar
Fuel Economy: Better than 95% of cars on the road
Check your cv boots for tears or lacerations.
GDE Tune and Meguiars on the tires
slamhouse is offline   Reply With Quote
Old June 3rd, 2012, 13:29   #4
Eliminateur
the Cv boots are fine, and anyway they're waay away from there and wouldn't show the epicenter as it's showing.
Here are some pictures(very hard to get a good angle):
this is the throttle body connector from above:
This is with the cammera parallel to the block (flush with the vertical intake piping the throttle body) you can see the "explosion" of oil, the throttle body is on the right:
And this is the downpipe from the left of the body:
i'm worried about oil in the intake but the car runs perfectly fine, no apparent oil consumption, no smoke, no power loss at high revs, no engine DTCs
Old October 24th, 2012, 18:44   #5
TDI_Smog
TDI(s): 2006 jetta
Sorry to bring up an old post but I may be having a problem with my throttle body making a lot of noise. Is this near the turbo? I can't quite grasp the location of if from the pics. Thanks.
TDI_Smog is offline   Reply With Quote
Old October 24th, 2012, 18:55   #6
nord
Throttle body? Diesels don't have one. We have an ASV (Anti-Shudder Valve) high and to the left rear of our engines but that's about it. Perhaps you're using the wrong term?
nord is offline   Reply With Quote
Old October 24th, 2012, 19:36   #7
TDI_Smog
TDI(s): 2006 jetta
Ohh, you're talking about the one just before that egr valve...ok. Than it's not the shudder valve making noise because that area is quiet.
Thanks, i'll keep looking around...
Old October 26th, 2012, 02:40   #8
Ol'Rattler
Ol'Rattler's Avatar
Don't have a clue, really, about what you are referring to. could you post some pictures with more perspective of the general area in question and then pictures that show the detail you are referring to?
Like Nord said, Diesels don't have a throttle body. They are a completely different animal than a gasser.
A very common area for oil leaks on a TDI is the valve cover. My BRM had oil leaking from the valve cover at 40K miles. If you have oil present on the back side of the engine, just below the valve cover, then your valve cover is leaking.
All I did was snug the valve cover bolts and the leak stopped. A bit of warning though, just snug the valve cover bolts, tightening them to tight will strip out the drive head or snap the bolts.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
cleaning throttle body TDI_PD VW MKIV-A4 TDIs (VE and PD) 13 February 16th, 2017 09:08
Throttle body gasket? digdug VW MKIV-A4 TDIs (VE and PD) 3 September 24th, 2010 13:10
Throttle Body Cleaning DeliveryValve VW B5 Passat TDIs 8 July 18th, 2008 20:07
where is the throttle body?! petertf TDI 101 15 October 9th, 2007 08:42
Throttle Body Sensor ReddiJet General VW Discussion 2 May 30th, 2007 11:56
Page generated in 0.14255 seconds with 10 queries
[Output: 86.35 Kb. compressed to 74.69 Kb. by saving 11.65 Kb. (13.50%)]
