redline808
2002 Jetta TDi. automatic.
was running just fine, parked it for a few days, battery went a little low, slow crank with beep noise coming from the cluster area. car starts then dies immediately, regardless of throttle position. charged the battery, cranks fine, still has long continues beep noise from cluster area. still starts then dies immediately. with the key in the on position, cluster mileage shows 000000, "km" in the left corner and "dEF" under the 000000. temp gauge needle at max horizontal to the right and the fuel gauge needle at max horizontal to the right. anti-theft key light is flashing and the glow plug light is flashing.
does anyone know what might be going on with my car?
thank you.
thank you.
