| VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta (99.5-~2005), Golf(99.5-2006), and New Beetle(98-2006). Both VE and PD engines are covered here. |
May 28th, 2012, 19:02
#1
Fuel Economy: Passat:44mpg Beetle:41mpg,Golf 52MPG
Need some AC help....
.....I suddenly heard a loud 'whirring' sound under the hood today. I panicked, and though: Uh oh. 'It's the timing belt' I stopped and checked the belt, and it seemed fine. The AC stopped working. I hear the noise again under hard acceleration from a dead stop. Does this sound like my compressor crapped out, or is there something else going on? I know *nothing* about the AC in these cars. Any advice would be very greatly appreciated. Thanks!
May 28th, 2012, 19:24
#2
Fuel Economy: yes i am anal with this, ...it is all in the book, in the car, .......
Paul
2001 Passat Wagon Quattro 94 000km's (hers)
2003 Jetta T Di 280+Km's (mine)
www.regroovenate.com
June 1st, 2012, 04:40
#3
Originally Posted by pbraunton
Looks like this is going to be fun. I'm going to look into repairing the fans. It might be possible to refurb the fans for cheap $.
June 8th, 2012, 08:02
#4
...Looks like my AC clutch is flagging in the wind. Is this an easy fix?
June 8th, 2012, 08:14
#5
Can you give a more technical description?
It is easy to replace the clutch coil, and plate, harder to replace the pulley and bearing, but still not bad at all.
June 10th, 2012, 05:41
#6
I can spin the clutch with my finger,and it spins freely.
June 10th, 2012, 06:13
#7
The clutch plate is the part on the very front that is held on to the compressor shaft by a 14mm nut. you're saying that part spins freely like the grooves that hold it on the compressor shaft are gone?
2006 pkg 2. DSG new DMF and CAM
2003 gl stock
2000 gls, T4 nozzles from Bora Parts and Franko6, Malone Tuning Stage 2
June 10th, 2012, 08:19
#8
Feels like there is nothing behind the clutch. I have a 1Z compressor sitting here to compare notes with,and I can hear the internals of the compressor moving, and I feel resistance when I turn the 1Z compressor clutch.
So.........does it look like I need to replace the entire clutch mechanism?
June 10th, 2012, 10:03
#9
take the 14mm nut off the front then remove the clutch plate and inspect the splines on the compressor shaft and the clutch plate
2003 gl stock
June 10th, 2012, 14:28
#10
The nut just turns endlessly because I can't find anything to lock down the shaft
June 10th, 2012, 20:00
#11
hmm. so the nut turns but the plate stays still?
sounds like the splines are gone probably in the plate.
2003 gl stock
June 15th, 2012, 11:49
#12
Yes.
I bit the bullet,and ordered a remanufactured compressor, and drier.
Should I have bought anything else besides those two items?
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
WTB: AHU AC to Non-AC Conversion Parts
dh13 |
Private TDI Items for Sale/Wanted |
3 |
July 30th, 2011 10:03 |
Ac clutch gone, Anyone know of a reputable shot for AC work?
redline14k |
Ontario |
2 |
May 9th, 2011 12:55 |
WTB Ac line large dia. Ac comp. to Evap.
hrtdi |
0 |
April 27th, 2011 19:40 |
99 Beetle- no headlights,w. wipers, turn lights, AC, AC fan
mauipetr |
TDI 101 |
1 |
February 3rd, 2010 13:26 |
FS AC compressor...other AC parts free
orion2.0 |
1 |
November 10th, 2007 12:57 |
