Old May 27th, 2012, 22:27   #1
epc
Default Loose underhood insulation / mat fix?
I posted in this thread but realized later the thread isn't in the Golf Mk 6 forum, so I am asking the question here again:
The heat from the area between the firewall and the engine on the passenger side is making the mat floppy and unable to retain its shape, so the tab on the mat cannot stay inside the slot on the underside of the hood.
Any idea? I am thinking about yanking off the entire mat...
See the pic in this thread:
http://forums.tdiclub.com/showthread.php?t=339936
epc is offline   Reply With Quote
Old June 5th, 2012, 11:12   #2
canux
Default The Story so Far
So far I have put strips of velcro (the hook side) onto the hood inside the slots and then attached velcro (the coil side) over the ends of each tab. That worked for about a day (until the tabs themselves started to come apart.
My next step is going to be actually putting a hole through each tab and then a rivet to keep the velcro in place. At that point I see no way that it could fall down unless the glue on the hood started to let go.
My next project. I'll let you know how it turns out.
Oh, and I have the updated hood insulation (this is my second unit). It comes with a heat shield embedded into it. The tabs still suck, however.
canux is offline   Reply With Quote
Old June 6th, 2012, 07:26   #3
Ruff Mainer
TDI(s): 2011 2Dr 6MT
remove it. I did, got more diesel noise goodness as well.
Ruff Mainer is offline   Reply With Quote
Under Hood Insulation Coming Loose FIX!?!? gmcjetpilot Other VW Group TD(I)s 14 January 3rd, 2014 16:01
loose window, easy fix? megaladon6 TDI 101 3 December 18th, 2011 12:06
Alternator Pulley Loose - fix or replace? dezeljunky VW MKIV-A4 TDIs (VE and PD) 4 May 15th, 2011 08:52
underhood insulation sauria VW MKIV-A4 TDIs (VE and PD) 0 July 9th, 2002 18:03
Underhood Insulation Upgrade Keeps the Peace Better Than Sheriff SkyPup Turbo Steve Upgrades (non TDI Engine related) 5 September 10th, 2001 08:07
Page generated in 0.14163 seconds with 10 queries
[Output: 57.24 Kb. compressed to 52.04 Kb. by saving 5.20 Kb. (9.08%)]
