Old May 17th, 2012, 16:10   #1
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Default Windshield Washer Leak - Small
I have a 2000 Jetta with a small leak of washer fluid and somewhat low pressure spray pattern. The area where the bottle is only appears to leak under pressure and not a lot (gets wet at the base). I suspect the swivel connection in the picture below (center) as the grommets at the pump and connector for the low fluid were dry when I removed the bottle. Also, there was a piece of cloth type electrical tape on the swivel hose connector (where the hose meets the distribution tubing - center on picture).
Can someone tell me if that connection looks right (I removed the tape) and if there is tape from the factory at that connection. I do not see any hose splits, but the connection may just be leaking a little (hard to see all hooked up).
Thanks!
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Requesting help fixing leak windshield washer tank vw4life VW B5 Passat TDIs 12 January 16th, 2011 07:32
Windshield washer OriginalSterm VW MKIV-A4 TDIs (VE and PD) 4 November 28th, 2008 06:35
Windshield washer no spray, and washer tank has a leak? one.nine TDI 101 13 November 16th, 2006 16:39
windshield washer fluid leak pastvast VW MKIV-A4 TDIs (VE and PD) 6 July 14th, 2006 04:08
what do you do about small pits in your windshield? kooyajerms TDI 101 4 January 23rd, 2006 08:04
Page generated in 0.11950 seconds with 10 queries
[Output: 48.35 Kb. compressed to 45.49 Kb. by saving 2.86 Kb. (5.92%)]
