Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old May 16th, 2012, 13:12   #1
coletraim00
Default 1982 Volkswagen Rabbit Pickup
Selling a 1982 Volkswagen rabbit pickup. It has a 1.6 liter TURBO diesel installed and a 5 speed transmission from a 92 Jetta eco-diesel. The motor was totally refreshed before installation...seals, gaskets, head gasket. It starts and runs perfectly. It has front adjustable coil over shocks, fully adjustable to go from 2" above stock height to -4". Every brake line has been replaced recently. New rotors, calipers, and pads on front, and new shoes and springs on the rear. The only significant rust on this WAS the driver floor pan. I had it cut out and a brand new OEM complete pan professionally welded in with seam sealer, primer, and undercoat. I then ordered new carpet with the mastic backing (thicker rubber backing for better sound insulation), which made a huge difference in lowering the cabin noise. I installed Ricaro racing seats. I had the side bolsters completely redone. The seats are in like new condition. Very comfortable and supportive. The driver side does have a tiny mark between the bolster and the seat. It of course has some dents and dings on it. The tailgate can be hard to open. i believe it needs new bushings. The rear fender (the lip only) has surface rust and dented. Has boost gauge and amp meter installed aftermarket. Has a new battery and new battery pan and new battery hold down. New fuel injectors. Power steering. No ac, however the controls are in the truck and you can install ac later if so desired. This truck is very reliable as a daily driver. No leaks. Clean and dry. I spent my time owning it concentrating on the mechanics. I started on the interior. All that is left to do is paint it. the strut towers are in good shape with no rust at all. If you are looking to save some money on your fuel bill, this is the thing to have. I normally get between 49-58 MPG.
Call 570-223-9898.
coletraim00 is offline   Reply With Quote
Old May 16th, 2012, 17:18   #2
dok
I do not see an asking price nor pics, therefore it doesn't exist
'96 B4V 230K mi.
'01 Jetta 210k mi.
'05 Passat 180k mi.
dok is offline   Reply With Quote
Old May 16th, 2012, 18:17   #3
coletraim00
$4500.00 First time posting. I have to figure out how to do pics!?
Old May 16th, 2012, 18:40   #4
NarfBLAST
NarfBLAST's Avatar
Fuel Economy: 5.8 - 4.5 (40 - 52)
Copy the "IMG Code" below the pics and paste:
I really like the truck, already asked my wife, she said no, I have to keep dreaming.
edit: the paint and rust look beautiful, I would not paint it.
- Paul
2001 VW Golf TDI 5MT 500,000 km <The NARFmobile picture blog thread>
NarfBLAST is offline   Reply With Quote
Old May 16th, 2012, 18:43   #5
dok
Didn't mean to be a harda**
'96 B4V 230K mi.
'01 Jetta 210k mi.
'05 Passat 180k mi.
Old May 27th, 2012, 23:26   #6
apaloosafire
TDI(s): 2000 golf
howabout a trade for this 88 gti http://forums.vwvortex.com/showthrea...1#post77570164
apaloosafire is offline   Reply With Quote
Old May 29th, 2012, 10:34   #7
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
You may want pictures of the struts on the engine bay side and right behind them since that is where the rust starts. And include and engine bay picture.
As far as the tailgate being hard to open-lets just say VW wasn't a good truck maker when it came to the tailgates and the parts that open and close. There is a metal tab that is bent toward the part that does the latching keeping things closed. If they aren't tooking the latch part and there is play there-won't open well. You can't put things agains the tailgate or it will bent those and it will still be hard to open. I have to do a special dance to get mine to work after the tabs broke off. No bushings really to worry about-but there is some bump-stops.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car-4 door, 1.9 TD aaz, 5 spd
1981 Caddy VW truck-Topper with it
2004 Golf-2 inch lift, Q-loader stage 1 tune
Vag-Com owner
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Wanted: Volkswagen Rabbit Pickup Truck KevinH TDI Cars for Sale/Wanted 0 August 15th, 2011 08:54
OH: 1982 VW Rabbit Pickup Diesel Caddy $1900 rhaus TDI Cars for Sale/Wanted 4 June 11th, 2008 17:59
1982 VW Rabbit Pickup Diesel (Craigslist ME) MikeS_18 TDI Cars for Sale/Wanted 0 September 28th, 2007 09:36
1982 Diesel Rabbit pickup near Portland, OR 06SpiceRedTDI TDI Cars for Sale/Wanted 0 July 17th, 2006 15:32
1982 VW Rabbit Pickup - Diesel FanofAllDiesels TDI Cars for Sale/Wanted 3 August 30th, 2004 09:18
Page generated in 0.17703 seconds with 10 queries
[Output: 82.88 Kb. compressed to 71.93 Kb. by saving 10.94 Kb. (13.21%)]
