Old May 13th, 2012, 15:42   #1
ritsco
ritsco's Avatar
Fuel Economy: 50 MPG @ 80 MPH (I like it !)
Default 2006 Golf Hard Starting
OK, for the second time in about a month, I have had a hard time starting my 2006 Golf. First time I got back from an overseas trip, got to the airport lot at 11:30pm and went to start her up. Usually one turn of the key and she cranks right over (no matter what the temp outside). This time it tok about 5 minutes of repeated tries and ample peddle pumping to get her to kick over. Ran great after that, no other issues...........until this morning.
Got back from about 9 hours of driving around yesterday and I got home and parked her for the night. This morning, I went to turn her over and .....nothing! After about 2 minutes of trying to crank her over she started and ran great.
No smoke on either occasion and the car ran perfectly afterwards. The only piece of the puzzle that was close to the same on both occasions was that the fuel tank was at 1/4 or slightly less.
I have a feeling it maybe the lift pump, but I am not sure. Thoughts and opinions are welcome.
Thank you.
New 2015 TDI GSW SEL - Stock (for now)
2006 Golf GLS TDI Auto (hey, I like the Tiptronic)
Rocket Chip, Panzer Plate, Frost Heater, Tint, BBS RXII's, Heated Aspherical Mirrors, Euro Switch, ScanGauge II, GLI Shocks and Springs, 3 Spoke Leather Steering Wheel, BFI Upper Rear Bar, Monster Mats, Blacked out Emblems, Avg 43 mpg so far
ritsco is offline   Reply With Quote
Old May 14th, 2012, 17:28   #2
ritsco
ritsco's Avatar
Anyone?
Old May 14th, 2012, 18:07   #3
nkgagne
Fuel Economy: See Fuelly in signature
The lift pump is relatively easy to test and there are a few threads on the subject. You can check if it (a) has current, (b) is providing sufficient fuel output pretty simply. If pump isn't getting current, it's a wiring issue. If it is, but won't turn, the motor may be shot (difficult to obtain, but can be separately). If it pumps but weakly, the pickup screen may be clogged with dirt.
The other obvious thing may be a clogged fuel filter. If you can't remember even vaguely the last time you replaced the fuel filter, it would be a good idea to change it, and to perhaps also replace the thermostatic tee fitting into the filter (and the o-rings that seal it). Good luck!
Bone stock. Dieselgate Stage 1 reflash complete.
nkgagne is offline   Reply With Quote
Hard "cold" actually cool Starting - 2006 Jetta TDI 5 spd jsb VW MKV-A5 Golf/Jettas 2 January 5th, 2011 17:37
2005 golf, hard starting in cold ?? bruca003 TDI 101 9 December 15th, 2009 19:30
Mk3 Golf - misfire,smoke,hard starting Audiman TDI 101 5 September 29th, 2009 00:21
04 Golf Hard Starting Whe Hot kassel VW MKIV-A4 TDIs (VE and PD) 0 May 2nd, 2008 15:05
2004 Golf hard starting rfriend VW MKIV-A4 TDIs (VE and PD) 4 May 26th, 2005 12:01
Page generated in 0.11858 seconds with 10 queries
[Output: 59.94 Kb. compressed to 54.46 Kb. by saving 5.48 Kb. (9.15%)]
