TDIFest 2013 Registration is now open!
Old May 9th, 2012, 19:44   #16
40X40
Experienced
Fuel Economy: 42,with a best of 47
Ginger Rogers did everything that Gene Kelly did, but backwards and in heels. LOL
I use a pound of 60/40 Kester about every six months. Some of my connections just get soldered OR crimped, others are crimped AND soldered, still others are crimped, then soldered and then glue type heat-shrinked.
I just do the best I can for each connection. My original instruction in soldering was to NASA specs and my instructor was retired from Fermilab.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old May 9th, 2012, 20:06   #17
jimbote
jimbote's Avatar
Fuel Economy: 34-39 b.m; 46-49 a.m.
here's where I buy all my heat shrink butt connectors....they have hot glue inside that seals the connection.... http://gcs.cableorganizer.com/?q=krimpa-seal .... works out to around .25 to .30 a connector for the common sizes ....also have this torch for heat shrinking em' .... http://www.eddyproducts.com/ItemDetail.aspx?itemId=03
check out my for sale thread "The junk man cometh'!!!"
jimbote is online now   Reply With Quote
Old May 10th, 2012, 04:03   #18
burpod
teh stallionz!!1
burpod's Avatar
Fuel Economy: 63/48/33
oooohhh.. nice link jimbote, i'll be saving that for the future i'd love to use nice butt connectors for certain connections, and the oem vw ones are nice, just so much $$
82 rabbit AHU 17/22 26psi vwmikel tuned
88 scirocco AHU 2260 build... build delayed
1998 jetta AHU vnt unicorn
boring cars: 05 jetta tdi w/17/22 etc & 06 golf tdi w/vnt17
burpod is offline   Reply With Quote
Old May 10th, 2012, 04:10   #19
PDJetta
PDJetta's Avatar
If I could find some professional wire connectors and a good crimping tool, I'd propably use them. My experience from the 1980s with those Radio Shack krimp connectors is that after a while the wire fails to make proper connection in the connector and/or the wire pulls out of the connector. For a while there I was using those connectors, but soldering them to the wire.
With that said, I do make automotive wiring connections by soldering and using heat shrink tubing. I never had one fail. Eight years ago when I bought my '04 Jetta, I installed the Phat Noise hard drive music box. Somehow I fubared the 30 plus prong connecter that attached to the CD changer plug. I simply cut it off and soldered every one of the wires to the CD changer harness. 30 or so soldered connectins. Still works fine 8 years later.
I will say that when I do solder and heat shrink, I tie secure the wire so the connection won't vibrate.
Thanks for posting the link. I'm going to read it today. I did look at the first post and this caught my eye:
"EVERY soldered joint on the V-42 we have is corroding and failing. It may have taken close to 20 years to do it, but we did not find these issues on ANY of the crimped joints... NONE." Note that the issue is corrosion. And that it takes 20 years to occurr. This has to be in the salt air/wet environment since this is on a boat. Our cars are in a totally, less corrosive, environment.
--Nate
Old May 10th, 2012, 04:48   #20
PDJetta
PDJetta's Avatar
That heat shrink torch is slick! I just ordered one. Everytime I heat shrink wrap tubing using a lit match (only gets one side well), I think, "There has to be a better way to shrink the tubing".
--Nate
Old May 10th, 2012, 05:18   #21
jimbote
jimbote's Avatar
also I use channel lock wire crimpers ....http://toolguyd.com/channellock-wire-crimper-tool/ and I always use the "non insulated" section of the tool to crimp my insulated terminals...just makes an unbeatable connection plus the glue seals up the break in the plastic jacket that part of the tool can create....
Old May 10th, 2012, 06:52   #22
VWBeamer
Fuel Economy: 42.79 mpg Woot!
I agree, soldier joints fail because people are not soldiering correctly.
I work on military aircraft and almost all connections are soldiered.
I want to add that after soldiering, any excess flux needs to be removed. It attracts and holds moisture and this is what is causing corrosion. If it's removed with a solvent then the corrosion problem is reduced greatly.
Originally Posted by N41EF View Post
Just my somewhat quallified opinion here. A boat or car in a salt environment will have corossion everywhere. If exposed the tin and lead in solder will weaken and break down, causing a weak joint and poor electrical connection. We saw this on magnetic amplifiers on the submarines built in the early 60's. Through quality assurance we developed procedures and methods for repairs and instalation to prevent the failures. Convormal coating, or heat shrink was used to protect the solder joint.
NASA also followed suit, after wiring problems in the Apollo program they got pretty serious about it.
Immpoper solder joint allow for "wicking" where the solder runs up the wire under the insulation. It is caused by using too much heat or having the heat applied for too long. Most of this can be prevented by using eutectic solder 63/37 which has no plastic region and goes from liquid to solid as it cools. Use a 25w iron an keep the heat on the joint for the minimal time. You can buy 63/37 solder at radio shack, it isn't much more expensive than the cheap stuff.
Food for thought, in a the nuclear program the only termination allowed for a wire was for it to be soldered to a terminal or in a properly crimped mil-spec lug that was screwed to terminal. Butt crimps were specificaly not allowed and if a wire required required repair it was twisted, soldered and shrink wrapped, and would be replaced when practical.
Yes, a good butt crimp using a proper crimper will give a good connection, but butt crimps also increase the bundle size. Crimps with heat shrink built in such as for boating are even better.
All being said, if I was replacing a 4 wire glow plug harness on MY car, at home, where I have all of the tools, I'd solder it , shrink it individualy and again as a bundle. In a parking lot at a GTG butt crimps and electrical tape would work.
I'm restoring a 1979 Chrysler sailboat now, replacing all of the wiring, no splices, crimped terminals to the breakers, and soldered to the end load, or again a crimped terminal.
Closing, if you have the right tools, and right materials in a clean environment solder is much better. If not a crimp isn't going to be a bad thing, but not really a permenant thing.
For the record, I'm a retired Navy Nuke, Chief Electronics Technician, and was quallified as a Electronics Technician Maintenance Technician Instructor. I've done a taught a little soldering in my time.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 4 Malone Tune.3 bar MAP, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.Summit Racing Muffler.
VWBeamer is offline   Reply With Quote
Old May 10th, 2012, 07:18   #23
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
They were pretty much being given away by Canadian Tire about a year or so ago ($10.00 and then for a short while $5.00)... I guess they weren't selling well... I bought a couple...
Yuri
Pereat mundus, fiat musica!
ymz is online now   Reply With Quote
Old May 10th, 2012, 07:33   #24
vwdieseling
vwdieseling's Avatar
TDI(s): Beetle
Fuel Economy: 37 MPG
I know that solder is not recommended for automotive connections due to its ability to attract moisture and salt corrision. There are some applications in which vibration and movement require a solder joint. I had an ABS wire at the sensor on driver side steering knuckle that had broken and needed splicing. I tried connectors of various kinds and it would always brake at splice. I finally resorted to solder and heat shrinks. I then booted it to prevent moisture. It was the only solution, though I know better. This is not a marine application, but there is potential for road salt and water to enter splices. I was trained not to do it, though the Marine Corp diesel manual gives instruction on how to. A Zinc Chloride solder does resist salt corrosion versus tin lead based.
vwdieseling is offline   Reply With Quote
Old May 10th, 2012, 08:10   #25
Herm TDI
Herm TDI's Avatar
I'll add my 2 cents to this thread.
The corrosion issue is related to the type of soldering flux paste used.
Many brands of soldering paste contain Zinc and Ammonium Chloride compounds. It is these compounds that cause galvanic corrosion within the solder joint.
The use of "acid free" soldering flux will make a lifetime solder joint.
The other issue is contamination during the soldering process. Keep the soldering tool, solder and the surface to be soldered clean and "brite".
I've used soldering flux such as
I've never had a single solder joint that failed as a results of corrosion or a cold joint.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old May 10th, 2012, 08:24   #26
JSWTDI09
JSWTDI09's Avatar
I also know that butt connectors is the recommended way to connect wires in a car. However, there is sometimes not enough room to do so. When I "upgraded" to a HomeLink visor, I had to install a new connector on the visor so that it matched my car. I tried to use a butt connector and discovered that there was not enough space above the head liner for the connector and the butt splice. I had to take it apart again and solder the wires. It was not the ideal method, but it was the only method that would work. Sometimes you just gotta do what you gotta do.
Have Fun!
Don
2009 Jetta SportWagen TDI
Candy White/Anthracite
Build date: 01/16/09; Buy date: 02/09/09
Coveted Three Pedal Version, Big hole in roof
Dieselgeek Shortshifter & Panzer Plate (my favorite & my smartest mods)
JSWTDI09 is offline   Reply With Quote
Old May 10th, 2012, 10:06   #27
JB05
Fuel Economy: 43/41/40
I have the same exact crimpers I bought directly from Channel Lock. I needed something that would fit in tight places and these did the trick. The non insulated section does seem to work better on the insulated terminals. They work pretty well on the VW type terminals as well.
JB05 is offline   Reply With Quote
Old May 10th, 2012, 10:15   #28
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: Tdi avg 48.6mpg. BMW avg 10 CPM and practically NO MAINTENANCE!
Originally Posted by whitedog View Post
There's just so much fear in that thread:
"A quick immersion in water (I don't know where from, maybe your bilge pump is shot or you're sinking) could very quickly open a live wire internally."
If you're sinking, wire corrosion is a small problem.
And:
"Some insulation might be PVC-based and as such, heating it might release Hydrogen Chloride gas...which when added to water becomes Hydrochloric acid."
Unless you solder it then immerse it in water, Hydrochorlic acid won't be an issue. Or maybe you are soldering in the rain, or possibly while sinking because you are fixing your bilge pump wiring.
And that's just in the first page.
That cracked me up
.. Awesome Club Vendors ...Buyer/Seller Feedback.. Fundraiser-buckwheatDiesel..Fundraiser-OilHammer..EnviroFit..Edmund's TCO..NIST applet..Slow Fueling Warning!..Vendor Feedback..Vendor FAQ's..What tire psi?
<--To report spammers, trolling, stealth vendors, or any problem post, click the report post icon under THEIR user name info panel
nicklockard is offline   Reply With Quote
Old May 10th, 2012, 10:27   #29
nicklockard
Torque Dorque
I'm no expert in soldering, but I did do it in a production environment for a stint during a college work-study job. I've done a smattering here and there and never had any of my joints fail. My technique for butt joints
  • clean the connection with alcohol or acetone (low residue/high purity stuff)
  • twist wires and thread into butt connector
  • Crimp on either end to proper rating w/ratcheting tool
  • tin your solder tip very well! a lot of people don't properly pre-tin the working end and this causes thermal stresses in the finished product. even heat distribution is critical to good solder work.
  • heat the ends of the butt connector and wire (jam the tip down there) and feed a tiny amount on the same end opposite from your tip. (Use low non-acid flux solder). This will bond wire to wire and both to the butt barrel.
  • Slip the heat shrink over and seal it well.
  • prior to reassembly of the wire into the bundle or into its run, make sure it is well supported for strain relief and pay attention to the turn radius if the wire is routing around other stuff. i.e. short wire run with soldered butt joint must have gentle arc or you'll have to find slack or support it well so it doesn't get pushed or turned too hard by normal contact when servicing the equipment. (basically just good routing practices.)
If you overflow too much solder or it wicks back to bond too many of the exposed threads, you can sometimes get away with using wicking wire to remove excess.
I know with a good crimp connector and tool you don't even need to, but I guess I've always had the low budget crimps and tools (I'm not a professional ET, so it's not worth the investment). Never could trust those cheapish butt connectors w/o the solder. Had most of them fail sooner or later, usually sooner.
Old May 10th, 2012, 11:03   #30
snakesausage
snakesausage's Avatar
I always solder, it is a much better electrical connection and you not have the issue with breaking the strands or making loose connections like when crimping (most of us do not have proper ratcheting crimpers). Soldering is just a more repeatable deterministic method of joining wires. If my joint is subjected to the elements I will usually put a dab of silicon calk around the wire and slide the heat shrink down over it and then force a little in each end. When I shrink it down it seals up water tight. It is messy but I have never had a solder joint fail. Using the correct flux, no clean or acid free, is key.
I build cables at work on a regular basis (for indoor use only) and on the high current connections we crimp and then solder. If you keep the heat localized (quick or low temperature) you can minimize the wicking effect.
South Bend Stage II Endurance : SEAT León Cupra R RAB : E-Code headlights : TT LCA bushings : Koni FSD : 11mm pump : 5.5L Washer Fluid Reservoir : Vented Passenger Wheel Well Liner : 03' Cup Holder Update : Aspherical mirror : Sunglasses Holder : Nokian eNTYRE 215/55R16 tires : 230,000 miles : VCDS : Metalnerd TB Tools : Bentley
snakesausage is offline   Reply With Quote
FS : ALH - Intake tube and wiring harnesses snadam Private TDI Items for Sale/Wanted 4 April 23rd, 2011 06:57
PD vs ALH wiring harnesses MPG Junkie TDI 101 0 June 20th, 2009 07:40
Fog wiring harnesses? Tybrad Ontario 1 July 9th, 2007 04:11
WTB: ALH TDI engine wiring harnesses Mark@MaloneTuning Private TDI Items for Sale/Wanted 1 February 9th, 2004 16:01
WTB: Seat Heater Switches and wiring harnesses - jbraman Private TDI Items for Sale/Wanted 1 January 2nd, 2003 18:38
Page generated in 0.17729 seconds with 10 queries
[Output: 146.82 Kb. compressed to 124.47 Kb. by saving 22.35 Kb. (15.22%)]
