Old May 4th, 2012, 05:27   #1
Qui-Gon_Gene
Default Fuel filter brand?
Does anyone know if Pentius brand fuel filters are good? I am looking at fuel filters on rockauto.com, and the Pentius filters are less than half the price of Wix, Mann, or Beck/Arnley. I know Wix and Mann are good, but I don't know anything about Beck/Arnley or Pentius. The Pentius are tempting because of the price, but the price also makes me wonder if they are worth buying.
Any of them are cheaper than going to the local parts stores.
I also have the same brand conundrum with air filters. I am also considering an AEM or K&N washable air filter. This is my first diesel car. Are the washable air filters a good idea?
Anyone have advice for me? Thanks!
Qui-Gon_Gene is offline   Reply With Quote
Old May 4th, 2012, 06:18   #2
Hurricane Drew
Stick to the german brands. Mann, Hengst, etc. won't regret it.
Hurricane Drew is offline   Reply With Quote
Old May 4th, 2012, 06:40   #3
tdiatlast
No washable filters on TDIs. Period. Do a search to learn why.
Again...stick to OEM brands. It's not worth risking an issue to "save" a few pennies.
IMHO, of course.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old May 4th, 2012, 06:43   #4
Honeydew
Yes stick to the OE suppliers. Out of curiosity I bought Beck/Arnley primary fuel filter and oil filter for my benz from rockauto and both boxes contained Mann filters.
K&N air filters are generally not a good choice for turbo diesels. Just stick with the OE paper style, they flow and filter well and have a long service life.
Honeydew is offline   Reply With Quote
Old May 4th, 2012, 07:04   #5
jettawreck
jettawreck's Avatar
Yes, as mentioned, the service life on the filters is quite long, so a couple bucks doesn't cover the questionable factor. I do however use NAPA Gold (Wix) filters since I trust them and are available locally in my rural area.
Do a search and learn why to avoid the "reusable" air filters. The OEM intake filter system is more than adequate.
2004 Cadillac SLS (wife's)
Old May 4th, 2012, 07:08   #6
Ski in NC
Fuel Economy: 48-52 typical
So you guys think Wix is ok for VW fuel/oil filters? I use Wix for marine/industrial engine filters and always thought the quality was ok. Never thought to use them for my VW, but may on next go.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old May 4th, 2012, 07:20   #7
Hurricane Drew
I stick to the MANN brand. A catastrophic fuel related meltdown on the TDI is probably more expensive than I want to deal with by saving $5-$10 on a fuel filter.
Old May 4th, 2012, 10:00   #8
jettawreck
jettawreck's Avatar
I have used a couple of the OEM type Wix fuel filters and currently have a WIX "eqivalent" to the CAT filter unit in the '01 Jetta. I have no complaints/problems.
Old May 4th, 2012, 15:00   #9
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I recommend staying away from any oiled air filters. They are especially subject to problems with our TDI's most all K&N filters are oiled. Their dry filters are OK.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old May 6th, 2012, 19:48   #10
TornadoRed
TornadoRed's Avatar
Wix oil filters (NAPA Gold) are fine.
As for air filters, I agree with the advice to avoid K&N -- but the Amsoil Ea air filter is a totally different animal. When I run out of my current stock, I think I will give the Ea filter a try.
http://www.amsoil.com/storefront/eaa.aspx
'03 Golf with 698k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old May 17th, 2012, 16:29   #11
steffen707
I was looking at the idparts.com website and for $43 bucks they have a fuel filter, oil filter, cabin filter and air filter. They said the air filter and oil filter are made by mann, they said the fuel filter is OEM. So what exactly does that mean? Can that be trusted?
link is http://www.idparts.com/catalog/produ...roducts_id=411
steffen707 is offline   Reply With Quote
Old May 17th, 2012, 16:31   #12
steffen707
actually i think the fuel filter is mann, or for $1 more you can get a hengst.
Is this a good deal? for $43, that sounds pretty good to me, you can get another mann oil filter for another $5.95.
Old May 17th, 2012, 18:45   #13
TornadoRed
TornadoRed's Avatar
The filter change intervals are different for each, or should be unless you decide to keep it simple.
Old May 17th, 2012, 18:52   #14
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Read and understand the service intervals in your owners manual. Idparts IS a trusted vendor.
Contact the Guru nearest you and see if there is a GTG in the works. (Get ToGether..)
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old May 17th, 2012, 18:57   #15
Dunno513
Dunno513's Avatar
Fuel Economy: 44.5 lifetime
http://www.amazon.com/Mann-Filter-WK...ype=automotive
Amazon is really stepping up to the plate with their auto part selections.
Dunno513 is offline   Reply With Quote
best fuel filter brand 2010 TDI DRIVE2MUCH Fuels & Lubricants 7 July 9th, 2010 18:47
Fuel Filter Brand Jetta888 VW MKIV-A4 TDIs (VE and PD) 7 July 14th, 2007 12:48
FS: Elf 5-40, MKV Oil filter, Fuel filter, Cabin Filter BTL Private TDI Items for Sale/Wanted 1 October 24th, 2006 14:02
Fuel Filter - Purolator, anyone using this brand? rtgjetta VW MKIV-A4 TDIs (VE and PD) 3 November 10th, 2004 09:33
Page generated in 0.16725 seconds with 10 queries
[Output: 127.08 Kb. compressed to 105.99 Kb. by saving 21.09 Kb. (16.60%)]
