Old May 2nd, 2012, 14:10   #1
syrjohn
Fuel Economy: 47 mpg
Default ScanGaugeII surprise
I recently had my clutch and turbocharger replaced on my 2002 Golf TDI with 235,000 miles on it. I disconnected the SG before the work and reconnected after. Then soon after I noticed something strange about its operation.
I was driving along and noticed my Today MPG was just above 50 as I approached a 1/2-3/4 mi downhill so I did my usual downshift to avoid using the brake and let it coast in gear. When I got to the end I noticed I had lost about 1 1/2 mpg. This has never happened before. I decided to do a test on another long downhill by getting up to speed and putting it in 5th. I then switched to Gauge setting so I could get an instantaneous mpg reading. Then as I coasted down the hill I switched back and forth between in gear and out of gear. The mpg reading was roughly twice as high out of gear than in. This makes absolutely no sense. The reading should be much higher in gear since the rolling of the car is turning the engine over with no fuel. In fact, my older SG used to read 9999.9 when I coasted in gear.
Could they have set something wrong on my engine when they did the work?
syrjohn is offline   Reply With Quote
Old May 4th, 2012, 12:58   #2
jettawreck
jettawreck's Avatar
My older SG installed in the '01 reads 9999 when coasting in gear, the slightly "newer" version SG in the '03 reads a variable number in the hundreds when coasting in gear. Never figured out why, but both are quite accurate.
2004 Cadillac SLS (wife's)
Old May 4th, 2012, 15:42   #3
Honeydew
Firmware change, I think. Our older one used to read 9999 then I sent it in for a firmware update to get the x-gauge functionality. After the update it reads like yours does.
Honeydew is offline   Reply With Quote
Old May 4th, 2012, 18:08   #4
jettawreck
jettawreck's Avatar
That's what I suspect(ed).
Kind of odd that the older version is closer to correct since no fuel is being used when coasting in gear. I bought the "newer version" one used and the previous owner has already added some xgauge features, although I really don't have a use for them.
Old May 4th, 2012, 20:13   #5
Cogen Man
Cogen Man's Avatar
Fuel Economy: Better than the Toyota FJCruiser
My SGII, bought in 2008 shows 0.00 LPH(liters per hundred kilometers) when coasting in gear. When I come to a stop, foot on the break and in gear it shows 0.07 LPH the same as the cluster readout. When I had it on my previous rig a gasser it always went to 9999.9 when at a stop in gear foot on brake.
Additions: ScanGauge II, bug guard, window vent visors. That's all folks.
Cogen Man is offline   Reply With Quote
Old May 5th, 2012, 09:48   #6
syrjohn
Thank you all for your comments but I'm sorry I included the distraction about 9999.9.
The real issue I have is with the mpg being less while coasting in gear than it is out of gear. Years ago on this site I got the impression there was a fuel cut off if you put it in gear while coasting. Can anyone tell me if this is true or that I'm mistaken? The theory was that you should stay in gear going down a hill to save fuel.
Old May 5th, 2012, 10:39   #7
jettawreck
jettawreck's Avatar
I do know for a fact they (maual tranny at least) shut the fuel OFF when coasting in gear. That's why the 9999 mpg is displayed. Its as close to infinite it can display.
I have no idea why your SG reads higher in gear than when in nuetral coast, but it may be a software "estimate". I do know there is a difference between my two SG in the way they report/display this info.
Old May 5th, 2012, 14:02   #8
syrjohn
I do know for a fact they (manual tranny at least) shut the fuel OFF when coasting in gear. That's why the 9999 mpg is displayed. Its as close to infinite it can display.
Thanks for validating that point about "cut off".
Now since my SG was performing normally before the turbo replacement (in that it would indicate a few hundred mpg on an in gear coast but much fewer on a neutral coast), but now behaves just the opposite I am left to wonder if something was done during the repair to alter the automatic "cut off" feature. If any of you are experienced mechanics and know of something like that happening I'd appreciate knowing about it.
Old May 5th, 2012, 18:15   #9
jettawreck
jettawreck's Avatar
The fuel shut off soleniod is on the top of the IP (single wire attatches to it). If I recall, power to the switch/soleniod opens it. So I don't think they could have damaged it or the engine wouldn't start/run.
Know anybody that you could swap SG with for a test?
Old May 6th, 2012, 05:39   #10
syrjohn
Thanks for the feedback. I'll give it a try.
Old May 6th, 2012, 06:47   #11
40X40
Experienced
Fuel Economy: 42,with a best of 47
Reset the SGII and start over. Diesel A? and 1.9 engine size.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old May 7th, 2012, 14:36   #12
syrjohn
Bill
I've tried the last 2 suggestions and think the resetting made the most sense. After the reset I tried it down the hill and actually got a 9999 in gear. Later on it settled down to hundreds or low thousands but reading much better than when out of gear. Now I'll have to go thru the fill up recalibration. So, thanks to you all I guess my cut off must still be working.
Old May 15th, 2012, 16:57   #13
steffen707
What fuel cut off value are you using? The manual says 24 is the default. I've read some use 6. What have you guys been using?
steffen707 is offline   Reply With Quote
Old May 17th, 2012, 09:06   #14
syrjohn
I don't know much about this so can't answer for some of my repliers. Perhaps you could try a private message to some of the more experienced.
FS: ScanGaugeII FuelBurner Private TDI Items for Sale/Wanted 2 January 26th, 2010 12:12
Hooking Up ScangaugeII cswaner@peoplepc.com TDI 101 8 September 19th, 2009 11:45
ScanGaugeII upgrade Jetta_Pilot Ontario 4 May 8th, 2008 08:55
ScangaugeII Accuracy?? pamike TDI Fuel Economy 17 March 28th, 2008 21:19
ScanGaugeII vondiesel TDI 101 4 November 1st, 2007 17:11
Page generated in 0.17744 seconds with 10 queries
[Output: 126.25 Kb. compressed to 106.39 Kb. by saving 19.86 Kb. (15.73%)]
