Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old April 30th, 2012, 03:44   #1
uberdorker
TDI(s): 2004 Beetle
Question How to disable the alarm
My 2004 beetle's alarm goes off at odd times without provocation. My mechanic had me take it to the dreaded dealer as he couldn't figure out how to disable it. The dealer said he couldn't fix it unless I could get the alarm to go off in the garage-and, of course, the car chose that day to remain quiet. I do have a little front end damage and the hood doesn't close perfectly-which the dealer suspects triggers the problem. I just want to disable the goddamn thing. As it is I have to leave the car unlocked (in the middle of thuggy Brooklyn--thankfully, most delinquents in my neighborhood cant drive a stick and my car is too girly for them to joyride) to stop the alarm from going off in the middle of the night (ive found lots of angry notes on the windshield in the morning). Any suggestions?
uberdorker is offline   Reply With Quote
Old April 30th, 2012, 04:20   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
The alarm keeps track of the last 4 things which set it off... you can check it with vag-com.
There is no simple way to turn the alarm off.
-J
Present:
2012 Passat SE TDI DSG. 24,000 miles. Factory Alarm & LED tails 38/48 MPG.
99.5 Jetta "GLX" TDI. 289,000 miles. Half way there!!! Power Memory Seats, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 222,222 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Old April 30th, 2012, 04:27   #3
oilhammer
oilhammer's Avatar
How about FIXING it rather than trying to disable it?
Your CCM may have already flagged a fault. Really only a handful of things can even set it off anyways.
oilhammer
www.cardocautomotive.com
Help out the TDI club raffle car! :http://forums.tdiclub.com/showthread.php?t=362827
Old April 30th, 2012, 06:38   #4
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
its probably a bad door microswitch, they are terrible, scan the car
i have replaced all 4 in our mrk4
http://www.gruvenparts.com/website/d...20-%20MKIV.htm
2004 pd 5 speed tip,malone tuning egr deletetdc powerbox PD adjust
1998 red jetta 5 speed man,TDC vp37 powerbox,vag com egr mod
bluesmoker is online now   Reply With Quote
How can I disable the alarm after using the key to get in? bigred177 VW MKIII-A3/B4 TDIs 11 February 22nd, 2012 12:50
Disable Alarm via VCDS? Lex4TDI4Life VW MKIV-A4 TDIs (VE and PD) 5 August 1st, 2011 23:18
Disable Alarm With VCDS? Chunkerz TDI 101 18 November 16th, 2010 07:11
Can I disable the "alarm" portion of A3 the keyless alarm module? 2TDIguy VW MKIII-A3/B4 TDIs 5 January 21st, 2010 06:51
Alarm System Disable Sky King VW MKIV-A4 TDIs (VE and PD) 10 March 15th, 2009 12:58
Page generated in 0.12528 seconds with 10 queries
[Output: 66.95 Kb. compressed to 60.07 Kb. by saving 6.87 Kb. (10.27%)]
