Old April 29th, 2012, 15:12   #1
sully365
Default car turning over but wont start
hi everybody
im new to this site now so dont slaughter me ha
i bought a vw jetta mkIV a year ago. 1.9 tdi 100PD and today it decides not to start.
plugged it in to VAGCOM as there was a heater plug light flashing on the dash (also engine fault light) and i got.. 01314 - Engine Control Module.
when i looked into it further it says there was no speed sensor signal but i didnt think a speed sensor would stop a car from starting?
can anybody help
sully365 is offline   Reply With Quote
Old May 2nd, 2012, 05:00   #2
sully365
replaced speed sensor on top of the gearbox and still wont start anybody??
Old May 2nd, 2012, 08:23   #3
keyfarms
Not sure which engine you have in your PD over there, but if its similiar the the North American BEW PD than it sounds like you replace the speed sensor on the transmission instead of the engine. The engine has its own sensor. Its the "Crankshaft Speed Sensor or Engine Speed Sensor". Its located behind the oil filter housing, down toward the bottom of the block toward the rear bell housing. We had one fail on our BEW PD and it shut the engine down very frequently.
keyfarms is offline   Reply With Quote
HELP! Car wont start! Evan_schulte TDI 101 0 September 29th, 2009 08:23
Car wont start? Crash0006 Atlantic Canada 3 July 6th, 2009 16:10
car wont start and very smoky if it will start puds TDI 101 4 February 12th, 2009 21:37
car wont start alternative solutions VW MKIV-A4 TDIs (VE and PD) 3 August 17th, 2008 13:12
Car wouldn't start, then did but has low power, no it wont start again bigelzworth TDI 101 3 May 27th, 2008 12:54
Page generated in 0.13112 seconds with 10 queries
[Output: 55.98 Kb. compressed to 50.87 Kb. by saving 5.11 Kb. (9.13%)]
