Old April 27th, 2012, 08:29   #1
paulbemis
Fuel Economy: 40+
Default Anti Shudder Valve replacement
After recieving the P3102 intermittently over the past year, I think my anti-shudder valve finally failed. However, I am having difficultly finding a replacement valve. The car is a 2005 Passat B5.5 PD. The VW part number stamped on the device is 03G128063. Can anyone tell me where I can get one of these units? The VAC-COM is also now reporting a P0299 and a P0101 code, but I suspect they are related to the failed anti-shudder valve.
paulbemis is offline   Reply With Quote
Old April 27th, 2012, 08:50   #2
johnboy00
I think you need a 03G128063J.
$394 @ www.ezvwparts.com
John
2005 Passat Wagon
1999.5 Golf
johnboy00 is offline   Reply With Quote
Old April 27th, 2012, 11:03   #3
paulbemis
Fuel Economy: 40+
Does anyone know the difference between the 03G128063J and the 03G128063G? Looks like the Jetta may use the same part and it is listed here for $129
Old May 1st, 2012, 11:49   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You need the J suffix valve. Your local dealer can order you one, should not take them more than a day to get one in. No difficulty at all.
oilhammer
www.cardocautomotive.com
Old May 2nd, 2012, 16:26   #5
paulbemis
Fuel Economy: 40+
Yes, I tried the 03G128063Q and it does not fit. The form and fit are exactly the same, but the 03G128063J has a 4 pin connector and the 03G128063Q is a 5 pin. Everything else looks identical. Too bad because Cory IDParts.com has the Q for $129.
Old May 2nd, 2012, 19:07   #6
Whitbread
Whitbread's Avatar
TDI(s): Several
Get a tune and have the ASV deleted. Wayyyyyyy better use of $395.
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old May 3rd, 2012, 17:57   #7
paulbemis
Fuel Economy: 40+
What does the ASV delete option entail? Does anyone have a recommendation of who could perform this service in my geo? I live in New Hampshire.
Old May 3rd, 2012, 18:51   #8
Whitbread
Whitbread's Avatar
TDI(s): Several
It's all in the software, no mechanical work needed .
Both TD Tuning and Malone have loaders you can purchase or rent (I believe) to do it at home or you can meet up with Rocketchip at a gtg or along your travels if you're anywhere near Red Lion, PA. Don't know far you are from Kyle at www.performance-diesel.com, he's a Malone dealer in Vermont.
02 Jetta TDI
Anti Shudder Valve - do I need it? panda VW MKIV-A4 TDIs (VE and PD) 5 November 28th, 2011 10:04
WTB: ALH anti-shudder valve (plastic arm) or entire EGR valve assy Boostaddict Private TDI Items for Sale/Wanted 14 March 19th, 2010 08:57
Anti-Shudder Valve, do we need it? pfiermka TDI 101 3 December 18th, 2008 11:59
WTB: ALH EGR Valve(or just intact Anti-Shudder Valve) Baumeister Private TDI Items for Sale/Wanted 2 October 3rd, 2008 12:05
Anti-Shudder Valve Chameleon VW MKIV-A4 TDIs (VE and PD) 10 February 23rd, 2003 15:11
Page generated in 0.13609 seconds with 10 queries
[Output: 84.00 Kb. compressed to 72.23 Kb. by saving 11.77 Kb. (14.01%)]
