Old April 26th, 2012, 18:21   #1
jerrykulseth
Default Glow Plug light keeps flashing
Hi there, i have a Question i have a 2000 tdi jetta, the Glow plug light keeps flashing. (Why)
jerrykulseth is offline   Reply With Quote
Old April 26th, 2012, 18:23   #2
aNUT
aNUT's Avatar
Fuel Economy: Great.
because your car has a bad brake light switch
www.dieselland.net
aNUT is offline   Reply With Quote
Old April 26th, 2012, 18:46   #3
jerrykulseth
Why would the brake light switch make the glow plug light flash?
Old April 26th, 2012, 19:09   #4
jerrykulseth
also when the glow plug light is flashing the engine runs very rough at idle.
Old April 26th, 2012, 19:14   #5
Vince Waldon
Vince Waldon's Avatar
A flashing glow plug light is also a form of Check Engine light... best bet is to have the car scanned for codes....especially if there are engine running symptoms associated with the light.
My random interweb guess: a QA issue... which also triggers the flashing glowplug light.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old April 26th, 2012, 19:17   #6
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
You have to scan it for fault codes. VCDS is preferred, but generic OBDII should be sufficient in this case. The flashing light means there's a severe engine management fault.
The brake light bulbs or switch failure will do it as well, do draw your attention to a potentially dangerous condition.
Yard sale - misc. mk4 TDI parts.
jcrews is offline   Reply With Quote
Old April 26th, 2012, 19:31   #7
Seatman
Seatman's Avatar
Fuel Economy: No idea
The other ones I know of so far are the #3 lift sensor injector and the tps throttle positioning sensor. As said you'll really need to scan it to see what the actual issue is.
Seatman is offline   Reply With Quote
Old April 26th, 2012, 20:12   #8
aNUT
aNUT's Avatar
well, see you didn't mention it runs like crap; so I ass-u-me'd...
www.dieselland.net
Old April 26th, 2012, 20:21   #9
RacerTodd
RacerTodd's Avatar
Fuel Economy: about 50
MOGolf posted a list of the codes that will cause a flashing glow plug light:
http://forums.tdiclub.com/showthread.php?t=67848
Todd
Seattle,WA
'86 GTI, Red of course. (exciting racey car) 274,000 miles
'01 Golf TDI, silver. (new work car) 558,000 miles!
'87 Golf, Polar Silver. (retired work car) 654,000 miles <- Gone to a new home
RacerTodd is offline   Reply With Quote
Old April 26th, 2012, 22:29   #10
jerrykulseth
I just put in a new fuel pedal in and brake relay switch also changed the battery checked the brake lights all is good, and No change. ill check for codes in the morning and let you know. thanks everyone.
Old May 24th, 2013, 17:36   #11
tdivaki
TDI(s): vw golf TDI
Default Tdi glow plug light!
Hey everyone! I have a problem and im hoping you guys can help me solve the problem, recently I had to poll the head out to clean the carbon that was build in the piston everything was going good put together and I had a hard time starting the car I thought the ail maybe was sucked in so I thought that's the problem but now in the morning its giving me hard time and during the day after the car is cooled off same thing but after it runs fine no problem after starting but the glow plug light is flashing all the time wile its running!!!!!! what should I start looking for first??
tdivaki is offline   Reply With Quote
Old May 24th, 2013, 20:11   #12
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
You need to scan for codes. That's it. Without that its just stabbing in the dark...
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old May 25th, 2013, 09:09   #13
Ol'Rattler
Ol'Rattler's Avatar
Obvious maybe, but did you reconnect the glow plugs? Was the flashing G/P light and starting issues there before pulling the head?
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old May 25th, 2013, 09:13   #14
speed185187
speed185187's Avatar
TDI(s): 03 Jetta GL
I think they just like trying to fix an electrical problem with a large hammer.
03 Jetta GL TDI reflex silver (rear ended again) OOS
2018 Subaru Outback Limited (replacement for ^^)
16 Silverado 3500 CCLB dually LML
14 BMW K1600GTL-E
speed185187 is offline   Reply With Quote
Old May 25th, 2013, 11:26   #15
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
That CEL (check engine light) is just a kid in class waving her hand trying to get you attention because she has the answer. You need to have the codes read. Some places will read them for FREE. Try Autozone or Advanced Auto Parts. Get the exact code (like P0123) not just their translation into English and post it back here.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
After battery replacement, check engine light on, glow plug light flashing ... redluv VW MKIV-A4 TDIs (VE and PD) 7 June 28th, 2011 10:59
flashing glow plug light leads to check engine light compignition TDI 101 7 August 13th, 2010 17:42
Flashing Glow plug light + Flashing Oil pressure light w/ chime short_fuse TDI 101 7 August 30th, 2009 05:27
Installed Bully Dog Flashing Glow Plug Light Engine Light On! Please Help! kartracer35 TDI 101 5 August 26th, 2008 17:52
P0571 Brake light switch code Glow plug light flashing andoo VW MKIV-A4 TDIs (VE and PD) 1 January 16th, 2007 11:23
Page generated in 0.14925 seconds with 10 queries
[Output: 123.84 Kb. compressed to 102.66 Kb. by saving 21.18 Kb. (17.10%)]
