Old April 23rd, 2012, 21:18   #1
JimmyFrack
JimmyFrack's Avatar
Default Headrest removal without screwdriver?
Is there any reason to have to use a tool to remove the rear head rests? As far as safety or anything goes? I just picked up my wagen a few weeks ago and when I realized I had to use a screw driver to remove the headrests it kind of stinks. I was thinking of just clipping the little wire latch that holds the head rest in but I thought I might check to make sure there wasn't something I was missing why keeping the head rests locked in was a good idea?
Thank you
Jim
2010 Jetta Sedan
2012 Sportwagen
Union County, Jersey
JimmyFrack is offline   Reply With Quote
Old April 24th, 2012, 12:04   #2
timwagon
On my 2010 JSW I just push in the little tab on the right side and they slide right up and out. Did VW change the design for 2012?
I don't have any problem removing the three back headrests, it takes just a few seconds, and I do it at least once a week.
timwagon is offline   Reply With Quote
Old April 24th, 2012, 12:58   #3
atw
I used the screw driver once and have not had to use it again. They now remove with just a push on the little tabs.
atw is offline   Reply With Quote
Old April 24th, 2012, 16:07   #4
JimmyFrack
JimmyFrack's Avatar
Yeah they changed it, my 2010 sedan is just the little button but the new car is a button and a small slot that you have to put a screw driver in
2010 Jetta Sedan
2012 Sportwagen
Old April 24th, 2012, 20:00   #5
timwagon
Very strange...take a perfectly good design that works well and screw it up.
What was VW thinking?
Old April 24th, 2012, 21:13   #6
grnmtnjj
I'm away from my car so I can't give you photos. However, you can remove the spring clamps that lock into the posts. First, remove the headrests with the screwdriver. Then, looking into the hole, use the screwdriver to push the release. Pay attention to the moving part. That part can be pried out with a screwdriver or a needle-nose pliers. If you are careful, you can pull out the entire assembly (plastic clip and metal spring), which is what you want to do.
I did this for not only the center headrest, but also the two on the outside.
If it's not enough info, post back and I'll post pictures when I get back in the states next week.
This is an easy mod that everyone should do.
grnmtnjj is offline   Reply With Quote
Old April 24th, 2012, 21:59   #7
Bugdoc
Did you check the book in the glove box. (ie the owner's manual? LOL)
Bugdoc is offline   Reply With Quote
Old May 18th, 2012, 20:58   #8
wannaBeSwifter
TDI(s): none
I found a reasonably simple solution. Take a steel file and file down the
bottom edge of the slot on the left rod (the rod that requires the screwdriver). File a gentle slope and the spring catch will just slide past the groove in the rod. Going slowly, it took me about 10 minutes per headrest. No more screwdriver. Just depress the one
spring catch on the right rod, and it pulls all the way out.
wannaBeSwifter is offline   Reply With Quote
Old May 19th, 2012, 07:23   #9
tominmaggie
Fuel Economy: 45 MPG solid
I'm doing this today - thanks!!! I was at work and a friend brought me a piece of furniture that required my to go into full bed mode. Alas, I didn't have any tools! Luckily I found a floor staple and managed to fight the card headrests out. I don't ever want to go through that hassle again.
2010 JSW 6M gray/black - Traded in on 12/31/11
2012 JSW 6M white gold/corn silk beige
tominmaggie is offline   Reply With Quote
Old May 19th, 2012, 15:29   #10
hotpocketdeath
hotpocketdeath's Avatar
Invest in a Dremel, it's well worth it for jobs like this.
Although it appears I need to do this for my center headrest, the other headrests pop right out.
hotpocketdeath is offline   Reply With Quote
Old May 19th, 2012, 18:32   #11
tominmaggie
I used my dremel tool and indeed it worked perfectly! I don't know why VW designed the new models this way, but I defeated it quickly and easily.
Thanks to the forum for great advice!
Old May 19th, 2012, 19:39   #12
Kombifahrer
Kombifahrer's Avatar
http://www.golfmk6.com/forums/showthread.php?t=34784
2003 Jetta GLS TDI Wagon: 800 Mile Club, RC2, Koni Yellows, Bosal Hitch, Ventectomy, Intake Clean, EGR Delete
2014 KTM 500 EXC
2007 BMW G650 X Challenge
Kombifahrer is offline   Reply With Quote
Old May 22nd, 2012, 21:44   #13
Personne
I hate to be that guy but this subject has been visited many time before. Use the search button. Stop spoonfeeding.
Personne is offline   Reply With Quote
Old May 23rd, 2012, 07:40   #14
30Bones
30Bones's Avatar
TDI(s): 2012 JSW DSG
well some are new to the VW and their quirks. I found it irritating I needed to look into the owners manual 30 minutes after we got home to removed head rests . Genius move VW
Today is the tomorrow you worried about yesterday
30Bones is offline   Reply With Quote
Old May 23rd, 2012, 18:42   #15
30Bones
30Bones's Avatar
Originally Posted by Kombifahrer View Post
Thanks for the link. Glad that is off my to do list before my vacation.
Where to get hollow tipped Torx T-25 screwdriver? smontanaro General Automotive 4 November 7th, 2010 13:31
2010 JSW TDI Front seat Headrest Removal? jhein2580 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 May 8th, 2010 14:25
Good Old Screwdriver in Lock Trick, again.. dr_p TDI 101 40 November 27th, 2007 14:45
Screwdriver Bits Around the World dqa VW MKIV-A4 TDIs (VE and PD) 2 June 30th, 2003 16:24
Torx Screwdriver iluvmytdi TDI 101 13 March 30th, 2003 15:44
Page generated in 0.18557 seconds with 10 queries
[Output: 125.73 Kb. compressed to 104.68 Kb. by saving 21.05 Kb. (16.75%)]
