Old April 23rd, 2012, 04:23   #1
tbone1989
tbone1989's Avatar
Default What are signs of a bad throw out bearing?
My 2011 jetta has been randomly making a weird metal scratching noise on start up, and it will last until the car warms up a little. Then is not heard. I was told it was a bad throw out bearing. My buddy looked at it lastnight and said the same. But are there any more distinct sounds it makes that I can point out to the dealer?
Torque Monster!
tbone1989 is offline   Reply With Quote
Old April 23rd, 2012, 07:17   #2
AndyBees
AndyBees's Avatar
Seems that the throw-out bearing on a 2011 should have tens of thousands of miles left in it!
I doubt if warming up the engine would have anything to do with the noise being made by a throw-out bearing. I cannot come to think there would be a connection.
Does the sound change when you depress the clutch pedal? If so, it "could" be the throw-out bearing. But, it could be a short-lived DMF (Dual Mass Flywheel) if so equipped.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old April 23rd, 2012, 07:33   #3
tbone1989
tbone1989's Avatar
Well when the clutch is all the way down, you can hear a noise from outside. Hard to explain, but is it supposed to make noise while its pressed to the floor?
Torque Monster!
Old April 23rd, 2012, 08:57   #4
AndyBees
AndyBees's Avatar
A good functioning throw-out bearing is quiet.
Typically, a bad throw-out bearing will change sounds or go silent with the clutch pedal depressed or not depressed.....one or the other will cause the sound to change! However, issues with the clutch and/or flywheel can give similar results. It seems to be either the throw-out bearing or the DMF. But, I will say, I've never experienced either with a TDI. I have had experiences with bad throw-bearings on other VWs.
throw out bearing change ? Jettaneeds VW MKV-A5 Golf/Jettas 4 June 12th, 2010 19:22
Throw Out Bearing? Jeepmb TDI 101 1 September 6th, 2008 19:34
Clutch noise... Throw out bearing??? Suggestions? jonsaxbiz@gmail.com TDI 101 7 December 25th, 2006 21:49
Definition of throw out bearing? bigdanhall TDI 101 2 March 30th, 2004 06:20
throw out bearing ? chaser55 VW MKIV-A4 TDIs (VE and PD) 3 December 9th, 2000 21:45
Page generated in 0.14294 seconds with 10 queries
[Output: 65.29 Kb. compressed to 58.33 Kb. by saving 6.95 Kb. (10.65%)]
