| VW Passat Family (NMS and B7) TDIs (2012+) Discussion area for the 2012+ Passat TDI (North American and rest of world versions versions). The North American model was previously codenamed NMS (New Midsize Sedan) and the version the rest of the world gets is sometimes referred to as B7. |
April 20th, 2012, 20:43
#1
AdBlue consumption
How often do you need to top it up? How much does a bottle of AdBlue cost and how many do you need for each refill when the car is out of warranty? Thanks!
April 20th, 2012, 21:31
#2
veteran member
10,000 miles.... 2 to 4.5 gallons, depending on how you drive, how much soot you produce with your driving practices, how often it needs to cycle to clean up, city inefficient versus highway very efficient hot passive regens. About $12 for 2.5 gallons at Walmart.
April 23rd, 2012, 05:20
#3
My owners manual says Adblue is included in each 10k mile complementary service. The 5gallon tank is designed to last about 15k miles. As Niner said, it will vary based on how the vehicle is driven. I have seen 2.5 gallon bottles of diesel exhaust fluid (DEF) at auto parts stores for $10, and it can be pumped like fuel at some truck stops as well. Budget about 0.15 cents per mile, or negligible.
2012 Passat TDI SEL Night Blue/ Cornsilk
2011 Suburban 2500 family towing beast
April 23rd, 2012, 05:40
#4
Does AdBlue consumption increase if you drive the car hard or only if you do a lot of stop go city traffic?
April 23rd, 2012, 05:54
#5
To add the fluid on your own, you'd need to score a 1/2 gallon VW/Audi adblue bottle that you can turn into a funnel. Cannot just pour bulk fluid into the VW ablue tank, it requires a special bottle (neck "unlocks" the tank). Apparently BMW and Mercedes have standardized on the same design too (?).
Most of us don't have much to worry about for a looong while
Wonder what they use at service centers ... must have some kind of spill-proof funnels ... or they just use the 1/2 gallon bottles ...
April 23rd, 2012, 06:00
#6
Fuel Economy: 09 MB R320 Bluetec
As far as I know the special bottle does not "unlock the tank". The bottle is designed so you can invert it and not spill the contents.You first screw the bottle into place in the AdBlue filler neck. Then you push down on the bottle which then releases the AdBlue from the bottle. When you quit pushing down on the bottle it shuts off the flow of the AdBlue from the bottle and prevents spillage. At least thats how I understand it to work.
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
April 23rd, 2012, 07:21
#7
That was my understanding as well. I know I will ask for the empty bottle at my 30k free maintenance though to make a funnel. I can only imagine the problems if you spill DEF in the trunk.
April 23rd, 2012, 07:41
#8
Fuel Economy: 33.5 mpg, mostly city
FYI, with VCDS, I believe you can find the level (expressed as a percentage) in Engine -> Advanced Measuring Values -> 98-0:Sensor for reducing agent fill level. My Passat with about 3600 miles, mostly around town, shows a fill level of 77.03 %.
April 23rd, 2012, 08:05
#9
I asked for an empty jug at my 10k mile service. They gave me a 2.5gal jug, but it didn't have a special neck or anything on it, I ended up just throwing it away. I am not sure how to get one of the correct jugs, maybe my dealership has the tool you can buy and they are using different jugs.
If anyone has gotten the correct jug, please share a picture.
April 23rd, 2012, 09:02
#10
Interesting, I was planning on doing the exact same thing. I guess I'll have to be more inquisitive about the filler nozzle and not just try to score an empty bottle.
April 23rd, 2012, 09:21
#11
tdiatlast, 0.0013 dollars per mile. Or, 2,000 cents divided by 15,000 miles if you choose.
The 40k mile DSG service costs more, like 1c/mile.
April 23rd, 2012, 09:23
#12
April 23rd, 2012, 09:49
#14
5 gallons of liquid is a lot of extra weight to haul around. Hopefully they have positioned the weight so that it has a low center of gravity.
April 23rd, 2012, 10:03
#15
It's in the right rear quarter below the trunk floor. You access the tank thru the trunk and a door on the floor in the little "cubby" between the rear tire and the back of the car.
2012 Passat SEL Premium TDi Opera Red
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
2005 Ford F350 CrewCab PSD Dually
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Adblue?
cj42 |
VW Passat Family (NMS and B7) TDIs (2012+) |
74 |
November 18th, 2012 16:55 |
adblue ??
Lm2lg |
TDI 101 |
10 |
January 14th, 2012 12:21 |
adblue ??
Lm2lg |
VW Touareg TDIs |
3 |
January 13th, 2012 13:09 |
AdBlue
whizznbyu |
Audi Q7 |
45 |
November 25th, 2011 15:42 |
AdBlue Sources
Drivbiwire |
VW Touareg TDIs |
11 |
July 25th, 2009 15:06 |
