Old April 20th, 2012, 11:35   #1
cassel.joshua
TDI(s): 2001 Jetta
Default 2001 Jetta no start...help!
Hey guys I have an 01 Jetta Tdi and need some help it won't start my CEL has code P0725 and the connector on my crank sensor was broke so i replaced it. It has a 3 pin connector the outer 2 wires are showing ground but the one in the middle has no power and no ground. I traced the wire back to the ECM and there is no break in the wire. I think I could need a ECM just not sure. any help???
cassel.joshua is offline   Reply With Quote
Old April 28th, 2012, 21:26   #2
cassel.joshua
TDI(s): 2001 Jetta
Any body??
Old April 28th, 2012, 21:30   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
If there's 3 wires shouldn't there be power, earth and signal? I'm wondering if there's a short in one of the other 2. Do you have some sort of wiring diagram?
Might be able to find a pin out for the ecu on here
http://www.ecuconnections.com/
Seatman is offline   Reply With Quote
Old April 28th, 2012, 21:46   #4
whitedog
Pin 3 is the ground and is connected to the shielding.
You can unplug the connector and check the continuity again to see if things change.
Winters come, and winters go.,
Summers come, and summers go.
Old May 2nd, 2012, 07:58   #5
cassel.joshua
TDI(s): 2001 Jetta
Ya I'll check it
Old May 2nd, 2012, 09:22   #6
db252
How about your p109 relay? Has yours been changed? It's a cheap diagnosis to change out and avoid possible problems in the future along with correcting this.
2012 Golf 6 Speed Tech
2005 Jetta 5 Speed
2003 Jetta 5 Speed
2001 Golf Auto
db252 is offline   Reply With Quote
Old May 3rd, 2012, 07:03   #7
cassel.joshua
TDI(s): 2001 Jetta
I have not changed the 109 but I did remove it and test it and it seems to be working fine. If the 109 was bad there would be more problems then just this one thing right? I had the wiring for the crank sensor but my small child has moved it to some place "to keep it safe" so its gone.
Old May 3rd, 2012, 07:10   #8
whitedog
You can jump the connections so that it's like the relay is in there and activated.
Old May 3rd, 2012, 14:02   #9
cassel.joshua
TDI(s): 2001 Jetta
Did that and i'm still not getting power to my crank sensor
Old May 3rd, 2012, 14:49   #10
whitedog
Are you getting power out of the ECU for the crank sensor?
Old May 4th, 2012, 06:08   #11
cassel.joshua
TDI(s): 2001 Jetta
Ok, pins 1 and 2 of the sensor go to the pins 110 and 108 of the ECM I used the volt meter to check the resistance of the wires and they checked out good .2-.3.. now on the ECM I ohmed to see from pin 110 to pin 108 on the ECM to see if there was resistance and all I got was an open circuit not sure what that means, now for the ground wire the resistance on that was at 9.3 ohms
Old May 4th, 2012, 06:18   #12
whitedog
Josh, did you get power on pins 110 or 108 on the ECU?
Old May 4th, 2012, 11:17   #13
cassel.joshua
TDI(s): 2001 Jetta
no I did not
2001 Jetta ALH slow start/difficult to start w/o ECT, worse with ECT mkr TDI 101 13 October 8th, 2010 23:01
Help 2001 Jetta won't start bakert4659 TDI 101 6 July 4th, 2007 16:46
2001 jetta won't start watty TDI 101 1 November 25th, 2006 15:57
My 2001 Jetta wont start tdi44 TDI 101 4 September 28th, 2004 18:05
Help! 2001 Jetta TDI will not start!!! erc TDI 101 2 September 4th, 2004 20:16
Page generated in 0.15384 seconds with 10 queries
[Output: 105.57 Kb. compressed to 87.79 Kb. by saving 17.78 Kb. (16.84%)]
